Old Nov 12, 2002, 08:42 PM
Joe Elston is offline
Find More Posts by Joe Elston
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
Any Ideas for which Brushless motor to run in my Vasa 65 and K&A F86??
Hi Guy's well I ordered my K&A Models F86 and Vasa 65 fan today. And I am trying to decide on which brushless motor to run in the plane? I want to use my 8 and 10 cell 1100 Hecell NIHM cell packs. So I need to keep the amp draw below 20 amps. Astro is currently (no pun intended) expirementing with a new 4 turn 020 that you can buy with or without a 25 amp ESC. I think its a sensorless motor, so I could use one of my 40 amp Kontroniks ESC's on it. But does anyone have any ideas of what other brushless motors I could run in the Vasa? I am looking for more power than a speed 400. Allot more actually and an effecient motor as well. If any of you guys have any suggestions I would appreciate them. I would like my F86 to perform like a fighter. You can see the plane here http://kamodels.com/
Thanks For any ideas or suggestions.
Joe
Joe Elston is offline Find More Posts by Joe Elston
Old Nov 12, 2002, 11:20 PM
Ed Waldrep is offline
Find More Posts by Ed Waldrep
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
Joe, I'd suggest a Kontronic Fun 400-28. In the Vasa 65 on 12xCP1300 cells it pulls about 20 amps at the start at 30 sec it's something like 17-18 amps. That's the setup I though of when first reading about the K&A Sabre the other day. On 12 1100 NiMH the amp draw may be a bit below that.
Ed Waldrep is offline Find More Posts by Ed Waldrep
Old Nov 12, 2002, 11:59 PM
bmiller is offline
Find More Posts by bmiller
SoCal, Year Round Flying!
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Joe
I run a Mega16/15/3 in my wattage sabre using the HECELL/wattage 10cell 1100nimh. It pulls about 17amps with a cutdown Ky rotor. It pulls less with the stock wattage rotor. Mine will fly with only 8 cells also.
Those K&A models are really cool and I need to get one or.... two! However they appear to be roughly the same size as the wattage sabre in which case cp1300s are probably too big/heavy for the airframe.
Also be aware that at 17+ amp draws, these 1100s need good cooling and they only last about 50 cycles(yes 50) before rapidly going downhill. IMO they're worth it for the extra runtime.
Bruce
bmiller is offline Find More Posts by bmiller
Old Nov 13, 2002, 03:08 PM
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
Vasa and brushless
Thanks Ed and Bruce. I will look into both motors including the new Astro 4 turn 020. For my new Sabre. Wow Bruce I had heard that the Hecells had a limited lifespan when pushed above 20 amps. Its a good thing I got a bunch when they where on sale
I will keep you guys posted on my progress as soon as the plane arrives.
Thanks Joe
Old Nov 13, 2002, 07:29 PM
bmiller is offline
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Here's a link for some pictures
Hellanic F-86
Old Nov 14, 2002, 09:28 PM
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
Vasa 65
Bruce, I looked at the Mega 16/15/3 for my Vasa 65 and they say to run it on 8-10 cells in a fan but do not say what the amp draw would be. Does anyone have any idea what the amp draw would be in the Vasa 65 on 10 cells? I need to keep it below 20 amps for my Hecells.
Bruce, I will make sure the cells have good cooling in the F86. I just got an email from Ken and it looks like my plane will be shipped before Thanksgiving I also will have one of the first kits out I cant wait to get it but I need to get a motor for it. So its either the Mega or the 4 turn 020.
Thanks Joe
Old Nov 15, 2002, 12:40 AM
bmiller is offline
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Gosh Joe, I don't know the numbers on the Vasa65.
Maybe someone here with motocalc can post some numbers?
Old Nov 15, 2002, 02:22 AM
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
Vasa 65
Bruce, I have Moto Calc. But it does not have the Vasa fans in the program. It has the Mega brushless motors but the fans it has are mostly Wemotec's. If I knew the numbers for the fan like diameter. Pitch and number of blades and spinner size I could plug them in and make a Vasa but I don't have that information. Does anyone know the information for the Vasa fans. Do they have a website by chance? Anyone have the URL?
Thanks Joe
Old Nov 15, 2002, 02:05 PM
astrobob is offline
Find More Posts by astrobob
Los Angeles
Joined Oct 2002
4 turn 020 with wattage fan
joe
I am still waiting to get my vasa fans from hl
maybe they will arrive next week
in thje meatime we made some more 4 turn motors
here are my results running on a power supply
8 volts 13 amps 105 watts 23,076 rpm
9 volts 16 amps 145 watts 25,862 rpm
10 volts 18 amps 186 watts 27.777 rpm
11 volts 21 amps 240 watts 30,000 rpm
12 volts 25 amps 300 watts 32,600 rpm
on 10 cells figure around 11 volts
astrobob
astrobob is offline Find More Posts by astrobob
Old Nov 15, 2002, 02:32 PM
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
4 turn 020
Thanks Bob, can you give us the motor KV and other numbers so I can plug it into Moto Calc? I wonder if the Vasa fan will perform like the Wattage?
Thanks Joe
Old Nov 15, 2002, 03:50 PM
astrobob is offline
Los Angeles
Joined Oct 2002
020 fan kv
joe
our 803w motor for wattage fan
motor kv = 3340 rpm/volt
winding resistance = 0.049 ohms
motor no load current 900 ma
we will be selling combo with
25 amp control. or motor only.
bob
Old Nov 15, 2002, 04:56 PM
XPHAM is offline
Find More Posts by XPHAM
HUNTINGTON BEACH, CA, USA
Joined Feb 2000
Hi Bruce,
Maybe 300 watts on that adapter
Phil
XPHAM is offline Find More Posts by XPHAM
Old Nov 15, 2002, 05:45 PM
bmiller is offline
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Originally posted by XPHAM
Hi Bruce,Maybe 300 watts on that adapter
Phil
On the stock wattage adapter maybe...
On a drilled out one...No way!
That Astro 4wind is a HOT motor!
Joe you can run the astro on 8 cells for a lighter AUW and lower ampdraw and it would still stomp the stock wattage motor on 10cells!
Old Nov 15, 2002, 05:56 PM
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
Motors
I got ya Bruce, but I am not running a wattage fan. I am using the Vasa 65 fan. So I am afraid the 4 turn 020 might be too hot for the Vasa and draw too many amps. More than 20 amps is not good for my Hecells I wish I had the url for the Vasa fans? Then I could plug the info into Moto Calc and test some motors?
Joe
Old Nov 15, 2002, 06:11 PM
bmiller is offline
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Then you should wait til Astrobob tests the 020 in the Vasa before making a decision.
Discussion Can a brushless motor run in reverse? Rusty-Gunn Power Systems 21 Feb 14, 2011 09:34 AM
Help! Brushless motor controll in my "Huckebein" kvaark Foamy EDFs 27 Jul 05, 2007 06:08 PM
Which brushless motor for my Clic ty8 Foamies (Kits) 1 Apr 20, 2005 05:29 PM
Which Brushless Motor for My K&A P51 Joe Elston Scale Kit/Scratch Built 2 Jul 08, 2002 04:58 PM
Which brushless motor for Kyosho Spacewalker Michael in Toronto Electric Plane Talk 11 Jan 04, 2002 12:06 AM
