Old Nov 12, 2002, 01:04 PM
RCFlybry is offline
Find More Posts by RCFlybry
Faster Faster!!
RCFlybry's Avatar
Kaysville Utah, U.S.A
Joined Oct 2001
Motor Suggestion for Globe Swift?
Hi all,
I am starting on a Globe Swift from a modified and rescaled set of Earl Stahl plans.
Wingspan is 35 1/2" Target weight is 12 ounces. 180 Sq" of wing area. I had a GWS 300C motor in mind swinging a 10x8 prop.
Sound like it would work to you?
For those of you not familiar with the Swift. Here's what she looks like. A definite classic!!
RCFlybry is offline Find More Posts by RCFlybry
Old Nov 12, 2002, 01:21 PM
Martin Hunter is offline
Find More Posts by Martin Hunter
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
That should be a perfect motor for that size and weight. Are you planning on retracts as well?
Martin
Martin Hunter is offline Find More Posts by Martin Hunter
Old Nov 12, 2002, 01:25 PM
RCFlybry is offline
Faster Faster!!
RCFlybry's Avatar
Joined Oct 2001
Hi Martin,
I keep turning that over in my head and am leaning towards doing it. I just hope that I would still be able to stay within my target weight if I decide on retracts.
Bryan
Old Nov 12, 2002, 01:39 PM
Leave me alone!
Joined Feb 2002
I guess it all depends on how complex you want to get. My hurricane has a 34" wingspan, about 180 sq in wing area, powered by a 370, and sits precisely at 15oz. However, that includes retracts and split flaps. Also that's with a standard sized rx (caseless, of course). Working from Earl Stahl plans is an excellent start as his planes are designed strong and light, it seems.
I've had a thought... the swift sits pretty low to the ground, doesn't it? You might want a smaller prop and lower gearing on the 300.
Martin
Old Nov 12, 2002, 02:16 PM
RCFlybry is offline
Faster Faster!!
RCFlybry's Avatar
Joined Oct 2001
I just checked it in the Cad Program and the way I have it set up the wheels should give enough clearance for a 10" prop and still be able to fit in the wing without anything conflicting with it.
Bryan
Motor Suggestion For Bi-Plane Scratch BobFlyer Foamies (Kits) 4 Nov 30, 2004 10:27 AM
motor suggestion for GWS Fly GWS (Grand Wing Servo) 0 Oct 06, 2003 07:48 PM
Motor suggestion for Aeronaut's Super Dimona TC80 casioppc Electric Sailplanes 2 Sep 18, 2003 12:59 PM
Motor suggestion for Trick 1000 with TP2100's YZ 212 Power Systems 1 Sep 08, 2003 02:38 AM
Motor suggestion for Goldberg Sr. Falcon rcav8r2 Sport Planes 9 Jan 05, 2003 10:21 AM
