Old Jul 21, 2007, 11:45 PM
Neil Walker is offline
Find More Posts by Neil Walker
Texas Ranger
Neil Walker's Avatar
USA, CA, San Francisco
Joined Aug 2004
Stickers on molded wings - does it matter?
I have a nice 60" molded glider (Bird, HN 354) but it is mostly white with just a bit of red on the leading edge and tips. I'd like to put some sort of design over the top of the wing to aid in visibility - so obviously it would have to cover a significant area, for argument's sake let's say 1/4 to 1/3 of the surface. I'd like to do it in sign vinyl. I couldn't care less about the weight, but will the thickness of the vinyl and irregular pattern affect the airfoil in any way? Am I better off spending the time on a good paint job?
Neil Walker is offline Find More Posts by Neil Walker
Old Jul 22, 2007, 04:07 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Unless you are squeezing the thing to its limit for competition, it won't affect it enough to be an issue.
Old Jul 22, 2007, 06:09 PM
Texas Ranger
Joined Aug 2004
Thanks for the response. Someone else told me I should just try it and if I actually notice a difference then I should try out for the F3J team
Old Jul 22, 2007, 06:12 PM
Ricardo RW is offline
Find More Posts by Ricardo RW
.: Looking for Thermals :.
Ricardo RW's Avatar
Chile, Quinta Región de Valparaíso, Los Andes
Joined Jun 2002
I remeber seen somewhere that the height of a decal must be smaller than boundary layer, and this is important on the first quarter of the chord where the flow is laminar. Aft the 25% of the chord the air is turbulent and maybe the decal will help adding turbulance.
If I remember well I would swear that I read it from a M. Drela note, but I could be wrong.
Take care.
Ricardo RW is offline Find More Posts by Ricardo RW
Old Jul 22, 2007, 06:35 PM
Batmanwpg is online now
Find More Posts by Batmanwpg
Boar? I'm a Thermal Pig!
Batmanwpg's Avatar
Winnipeg, Canada
Joined Aug 2004
Try http://www.mh-aerotools.de/airfoils/ to find the height of the boundry layer
Batmanwpg is online now Find More Posts by Batmanwpg
Old Jul 22, 2007, 08:15 PM
jbeanelliott is offline
Find More Posts by jbeanelliott
United States, WA, Orondo
Joined Feb 2003
Question: Do model planes achieve laminar flow over the wings at the Reynolds number and speeds they fly at?
If the wings do not achieve laminar flow then does the height of the boundary layer have any meaning?
Enquiring minds want to know. Thanks. -John Elliott
jbeanelliott is offline Find More Posts by jbeanelliott
Old Jul 22, 2007, 08:35 PM
Texas Ranger
Joined Aug 2004
I remember this too from Dr. Drela but I couldn't find the original post...
Old Jul 23, 2007, 04:21 AM
MarkusN is offline
Find More Posts by MarkusN
Joined Jun 2007
Actually model aerodynamics often has the inverse problem: making sure the boundary layer transits to turbulent early enough to avoid laminar separation.
MarkusN is offline Find More Posts by MarkusN
Old Jul 23, 2007, 10:41 PM
ThermalThief is offline
Find More Posts by ThermalThief
Do it AGAIN! This time BETTER!
ThermalThief's Avatar
WA
Joined Jan 2005
If you look for sign vinyl make sure you ask for high performance or cast. These should be about 2mil in thickness and have a glossy surface.
If you get calendared or indoor grade vinyl it will be 4-6mil and may or may not be glossy depending on brand and quality. The calendared vinyl is streched to thickness during manufacture and is less stable as sun and heat can cause it to pull up edges. However, it will stick to foamies better
Ken
ThermalThief is offline Find More Posts by ThermalThief
Old Jul 24, 2007, 09:46 AM
ghoti is offline
Find More Posts by ghoti
Studies the wind
ghoti's Avatar
United States, CA, Yountville
Joined Nov 2004
If any blisters remain under the trim you can remove them by pricking them with a pin and flattening the blister with a warm covering iron. Don't overdo it and melt the foam! Try on scrap first. This will keep things smooth Bill
ghoti is offline Find More Posts by ghoti
Old Jul 24, 2007, 01:16 PM
Gary Warner is offline
Find More Posts by Gary Warner
York Electronics
Gary Warner's Avatar
Dallas Tx USA
Joined Apr 1999
Yep. The larger it is the thicker the airfoil will act. Your 'effective' airfoil shape traces the outside of the boundary layer (within about 80% of its thickness).
Gary Warner is offline Find More Posts by Gary Warner
Old Jul 25, 2007, 03:37 AM
MarkusN is offline
Joined Jun 2007
Also, because the BL is resilient, small differences in airfoil shape won't get their full effect. Say you have an airfoil with quite a bit of aft camber (which makes for lots of lift) That little twist at the trailing edge will be obscured to the flow within the "mush" of the BL and you won't achieve full lift. This is one reason why max lift usually is lower at low Re.
Old Aug 14, 2007, 04:33 PM
macboffin is offline
Find More Posts by macboffin
North London ENGLAND
Joined Dec 2006
stickers on wing.
Simple test.Trim out glider to fly straight and level. Weigh stickers for ONE wing, add to one wing, add balancing weight to other wing.Fly it, see if it pulls to one side or is inclined to drop stickered wing first at stall.
Remove balance weight, add stickers to other wing, fly again.
I doubt there will be much difference, except that turbulation effect might improve performance slightly.
macboffin is offline Find More Posts by macboffin
Discussion Does It Matter Which Side Of The Upper Rotor The FlyBar Link On The CX2 Is Connected? Mike10538 Coaxial Helicopters 1 Apr 01, 2007 10:36 PM
ok! why does everyone keep those stickers on their corona blades??? rcaddition Electric Heli Talk 9 Apr 14, 2005 05:01 PM
Gyro position on my corona, does it matter? GoodHeli Electric Heli Talk 7 Aug 27, 2003 09:06 PM
Why does nose drop in turns on flying wings? rparigoris Modeling Science 9 Sep 30, 2002 06:29 AM
Litestick Done-Does it matter where on the wing the dental floss goes? mrebman Parkflyers 4 Jul 09, 2001 03:32 PM
