Old Jul 21, 2007, 05:17 PM
Dale W is offline
Find More Posts by Dale W
Canada, BC, Greater Vancouver Regional District
Joined Dec 2006
Help!
"GMFC" PROBLEMS CUTTING TAPERED WING
I am having problems cutting tapered wings using gmfc pro 3.0
The wire on root x axis travels the correct distance down the cord
But the tip x axis doesn’t travel the total distance entered in to the panel parameters tip cord field
It is not missing any pulses from the controller as it always returns to the correct home position
The wing profile is the supergee 2 tip
In the Panel Parameters
Root cord 140
Tip cord 86
Leading edge sweep back 37
Panel span 245
In the panel cutting
Right wing
Top first
No trimming
Block centered in z (I placed the root of the foam block at the center of the z at a right angle)
Offset x 40
Wedge y 10
Repeat 1
The lead in angle at the trail edge is ok but always ends up cutting a narrow tip cord by cutting the lead edge to soon at the tip only.
I'm pulling my hair out ! This cnc project has had many challenges and lots of fun but this part has me stumped.
Any suggestions greatly appreciated.
Dale
Dale W is offline Find More Posts by Dale W
Old Jul 21, 2007, 05:31 PM
nauga is offline
Find More Posts by nauga
Embrace the suck
nauga's Avatar
Joined Nov 2004
Does it do the same when you cut a left panel? *Every* time I've had a problem with narrowed chord at one end or the other it's been due to binding in the lead screws somewhere.
Gilles, the author of GMFC, has helped me straighten out a few minor problems with GMFC, you might try the CNC foam cutting group on groups.yahoo.com
Nauga,
who loves his foam cutter
nauga is offline Find More Posts by nauga
Old Jul 21, 2007, 05:36 PM
nauga is offline
Embrace the suck
nauga's Avatar
Joined Nov 2004
If you check 'Block Centered in Z' then the center (spanwise) of your blank should be at the center of the Z axis. Root at center Z will make both the root and tip chord too narrow on tapered cores. Check the little diagram when you put in your offset and wedge values before selecting 'cut'.
Nauga,
a man of many reference frames
Old Jul 22, 2007, 01:56 AM
Dale W is offline
Joined Dec 2006
Thanks for the information . I tried the left wing and it did the same thing. when I use the center of the blank as the measure point to the wire instead of the root . it cuts to the lead edge on both cords . not sure what it will look like when I do a real cut on foam . the entry in to the trailing edge starts a little off kilter. I will do a test cut tomorrow .
thanks again,
Dale.
Discussion GMFC problem on tapered wing skankpile The Builders Workshop 7 Aug 20, 2006 05:35 AM
Cutting Tapered Wings ? Andycart Foamies (Kits) 3 Nov 15, 2002 04:36 PM
Cutting tapered foam wings? psbowen Foamies (Kits) 12 May 09, 2002 09:33 PM
cutting tapered foam wings inedesca Electric Plane Talk 2 Jul 21, 2001 11:55 PM
