Old Jul 20, 2007, 10:43 PM
Daniel Z is offline
Find More Posts by Daniel Z
Daniel Z's Avatar
Joined Dec 2004
Voxel f3p
I have decided to share with you my plane after 3 prototypes I think it is ready for your judgement
My setup
25T cdrom 9x4.7 gws
2s 450 etecs
3 pico GWS
AUW 138gms
outdoor video:
Voxel F3P (2 min 4 sec)
hope you enjoy!
Daniel Z is offline Find More Posts by Daniel Z
Old Jul 21, 2007, 02:40 AM
Geoff Woodward is offline
Find More Posts by Geoff Woodward
Electric's are cool
Joined Jun 2006
Spectacular flight
Looks light on the wing , the KE hover into the wind looks ace
The more I see these 2S planes the more impressed I am
Geoff Woodward is offline Find More Posts by Geoff Woodward
Old Jul 21, 2007, 08:21 AM
Just ShootMe is offline
Find More Posts by Just ShootMe
Joined Jan 2005
Daniel
Is that EPP foam I see?
I had trouble reading the DXF file, so I made you some PDF's
Just ShootMe
Just ShootMe is offline Find More Posts by Just ShootMe
Old Jul 21, 2007, 01:48 PM
Daniel Z is offline
Daniel Z's Avatar
Joined Dec 2004
yes, I don`t have depron where I am so I build everything from 10mm low density epp and dental floss reinforcement
as a side coment, 10mm epp can be lighter than 3mm depron
I have changed the 450 etecs (22gms without shrinking and excess of wire) for 460 hextronic (28gms - from unitedhobbies) and now I have way more power and flight times
Thanks for the pdf`s!
Old Jul 21, 2007, 06:12 PM
Joined Jan 2005
Reinforce with dental floss
Daniel
I am very interested in how you reinforce with dental floss. I was thinking about stiffening EPP in this way with Spider Wire filament fishing line just yesterday. Do you make an X across big areas or just run it like a spar? Do you do both sides? Do you in bed it in the foam or just glue it on the surface?
Regards
Just
Old Jul 21, 2007, 10:14 PM
Daniel Z is offline
Daniel Z's Avatar
Joined Dec 2004
Just,
Some time ago I have posted my aproach to the problem with some pics:
http://www.rcgroups.com/forums/showthread.php?t=545686
For wings I have also used a 1mm thick x 10cm x wingspan glued on the surface (both sides) and it worked really good ...will search for some pics of that
Old Jul 22, 2007, 06:42 AM
GallopingGhost is offline
Find More Posts by GallopingGhost
Joined Sep 2005
Originally Posted by Just ShootMe
Daniel
Regards
Just
Are you using the mono version of spider wire or the stealth braided version. I just bought a roll of the stealth for control rigging and similar reinforcement.
GallopingGhost is offline Find More Posts by GallopingGhost
Old Jul 22, 2007, 08:30 AM
Joined Jan 2005
I am using the Stealth braided version 50 Lb test. (Way overkill I know, but it is a little bigger and easier to work with and tie knots in it.) I use it now for everything even for hinge material.
Just
Old Jul 22, 2007, 01:11 PM
Joined Sep 2005
Just
50 Lb WoW! I went for the 20lb for the same reasons. I have a friend that is using 10lb but he is serious about weight. I didn't know about the braided stuff to start with and read about people using it the mono line stuff didn't seem like a good idea. Then I found the Stealth stuff. Ahhh haaa.
Old Jul 22, 2007, 03:23 PM
aerolite is offline
Find More Posts by aerolite
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
How about someone posting a photo of the box of the stealth spider wire.
That would be a great help!
Thanks Mini Ifo
aerolite is offline Find More Posts by aerolite
Old Jul 22, 2007, 06:49 PM
Joined Jan 2005
This stuff is strong and will not stretch like normal fishing line, itís braded, and based on the synthetic spider web technology.
Just
Old Jul 22, 2007, 08:41 PM
aerolite is offline
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
Thanks just shootme,
sorry about getting away from the thread topic, but this should work well.
Daniel Z, nice plane. We are dropping about 14 grams by using one of the E flight Park 250, or small hackers. These should fly this plane with no problem.
I have just ordered some of the 14g motors from united hobbies, and they look like they will be a good cheap light substitute.
Mini Ifo
Old Jul 22, 2007, 09:01 PM
Joined Sep 2005
Walmart has it now and its $11.xx which I thought was HIGH. Turns out WallyWorld isn't bad on it. I have heard of it being close to $20.00 at the fishing stores.
Old Jul 23, 2007, 07:14 AM
Daniel Z is offline
Daniel Z's Avatar
Joined Dec 2004
Mini ifo, I agree,think you could save some more using fullriver cells and lighter servos, I know I`m not using the most competitive/optimal setup
Galloping ghost, I have had very good results with dental floss, what is the advantage to use spiderwire?
Daniel
Old Jul 23, 2007, 09:54 AM
richard boyd is offline
Find More Posts by richard boyd
richard boyd's Avatar
Northern Ireland
Joined May 2006
Hi Daniel , i must say a very cool plane well done ! I have loads of EPP so this is very interesting for me , have you an AUW and how would you compare this bird to a volet or something of say a f3a depron plane ? The dreaded problem with EPP in my planes is tail wip it can be overcome allow this is at the expense of weight and we all know light is right . Again thanks for sharing with us your plane .
Richard
richard boyd is offline Find More Posts by richard boyd
Discussion Anybody flying a Voxel F3p fire_fly Indoor Pattern/F3P 6 Aug 14, 2007 11:09 PM
