Old Jun 16, 2001, 09:36 PM
Steve H. is offline
Find More Posts by Steve H.
Zebulon, NC
Joined Aug 2000
LMH is glo no more
Well I finally started converting my LMH thanks to some pics people have sent me and emails, it sems pretty easy to do.
I have nothing against glo, but this heli is a dumb design in that the exhaust shoots out right into the spur gear for it to throw it everywhere
This is my first heli and I was hovering fine with the glo engine and a little forward flight.
I have everything ripped out and almost done moving servos etc.
I have a couple questions though, since it seems the brushless setup is out of stock everywhere, and I dont want to jump right into that anyway, I was going to try a 20 turn Traxxas car motor, using a 13 tooth pinion on 6/6 grips, and I don't know if I should use 7 or 8 cells, in a plane I would use nothing less than 8 but thats different I guess.
Also will a regular Jeti 35 work fine for it? How do you do wattmeter tests with a heli so I dont run over the speed controls limit??
And 1 more, the piezo gyro on it was mounted on a rubbery sticky pad, I assume because of the vibration of the glo engine, can I just double side tape it to the crutch now that it will be electric?
Thanks, Steve
[This message has been edited by Cue (edited 06-16-2001).]
Steve H. is offline Find More Posts by Steve H.
Old Jun 17, 2001, 05:15 PM
Steve H. is offline
Zebulon, NC
Joined Aug 2000
Anyone out there?
Old Jun 17, 2001, 08:10 PM
JIMJAM is offline
Find More Posts by JIMJAM
JIMJAM's Avatar
Columbia, South Carolina, United States
Joined Feb 2000
Hi, I cant help you much with the brush motor setup. I tried alot of different combinations before I went brushless and all of them required some tinkering and experementing. Im not faminliar with that motor but the best luck Ive seen was with 17t and up motors. Anything with a lower wind sucked to much juice. Run times were low and everthing got really hot. I use double sided tape on all my gyros with out any problems.
JIMJAM is offline Find More Posts by JIMJAM
F Y I p471701 is no more, now gregg f gregg f Electric Ducted Fan Jet Talk 18 Dec 30, 2001 09:13 AM
the fearenstein GWS motor is no more!! aussie slowman Parkflyers 7 Dec 09, 2001 03:19 PM
No more Mongo? mikeb33 Foamies (Kits) 5 Oct 30, 2001 01:02 PM
No More Compassion With Palestinia RookieOne Life, The Universe, and Politics 17 Sep 11, 2001 01:16 PM
No more playtime for the mice, kitty is back. Fitz Walker Electric Heli Talk 3 Jul 25, 2001 11:07 PM
