Old Jul 19, 2007, 10:55 AM
newtukatukpilot is offline
Find More Posts by newtukatukpilot
Joined Jun 2007
why is it impossible to get perfect blade tracking as well as even blade pitch??
Today I decided to try and do flips on my T Rex 450 SE. Went over Finless Bob's throttle and pitch curves video.
I set each individual blade for +11 max hi -- 0 mid stick -- and -11 max low. Went to the field and went crazy with the flips. Finally!!! I was so happy to finally get over my fear of trying to do flips cause the last time, I ended crashing (so nervous and didn't have enough altitude).
It wasn't when I decided to hover in front of me that I noticed about a 3mm or so gap between the blades. I went and tried to adjust tracking, but in doing so, I know that I messed up the pitch setup that I had previously done.
What is more important; good blade tracking or even pitch on the blades? Seems like I can't have both. Am I missing something here?
Oh yeah, the blades are 315mm carbon Align blades (could I have a bad set of blades?). Thanks
newtukatukpilot is offline Find More Posts by newtukatukpilot
Old Jul 19, 2007, 11:30 AM
Mochaboy is offline
Find More Posts by Mochaboy
Radd Graduate '06
Mochaboy's Avatar
United States, MA
Joined Aug 2006
It's not impossible. Far from it, but like anything else, it takes time and experience to do it right.
If you recall from FB's blade tracking video, he tried balancing a set of Align Carbons that were so badly out of balance CG wise, that he was considering just sending them back.
Anyway, to your problem:
1) What method did you use to balance the blades?
2) what specific tool did you use to balance the blades?
3) did you balance them staticly, or dynamically?
4) did you balance the flybar as well? People often overlook the flybar which is capable of inducing an out of pitch condition.
5) how tight are your blade grips?
Once you get the blades balanced, at zero pitch, you shouldn't have to turn the low blade by more than 2 or 3 turns to get the tracking on point.
Mochaboy is offline Find More Posts by Mochaboy
Old Jul 19, 2007, 11:33 AM
HeliSmith is offline
Find More Posts by HeliSmith
=>] Smack 3D Head [<=
HeliSmith's Avatar
United States, CA, Chico
Joined Feb 2007
Ok first you know you have dampers that need to be check regularly right?
Next hold your blade grips with one hand and turn the allen screw in one side clockwise. Is your feathering shaft bent? You will feel it if it is.
Ok now this.
Mark one blade grip as master. Get your pitch right on that blade. -11 0 +11 yada yada..
Ok now get the other blade to track the master blade.
Notes:
The short link from the lever to the blade grip will give you 2 degrees.
The long link on the pitch lever going to the swash plate will give you one.
If you are not level on your head it will mess with tracking.
HeliSmith is offline Find More Posts by HeliSmith
Old Jul 19, 2007, 11:37 AM
blade strike is offline
Find More Posts by blade strike
DJI Testing / US Support
blade strike's Avatar
United States, CA, Big Bear
Joined Jan 2006
what you need to do is make one blade grip / blade a master and mark it.
Then you adj the other blade if tracking is off... this way you know that you wont mess with your ptich rang and such...
EDITED:
LOL HS beat me to it... started typing this and had to step away from the desk
blade strike is offline Find More Posts by blade strike
Site Sponsor
DsWright is offline
Find More Posts by DsWright
ProBro #1889
DsWright's Avatar
United States, OH, Amelia
Joined Aug 2004
Also... Don't be afraid to go a 1/2 turn on the ball link if needed! you can unscrew the ball from the swash or mixing arm, put on the link from the inside, then screw it back in.
not only can this help get that perfect tracking. the ball link is less likely to pop off completely...
DsWright is offline Find More Posts by DsWright
Old Jul 19, 2007, 11:39 AM
DsWright is offline
ProBro #1889
DsWright's Avatar
Joined Aug 2004
also.... if your tracking is only out on 1 side of the rotor disk... that is something bent in the head.... usually a spindle..... true tracking problems are equal on both sides of the rotor disk while in the air.
Old Jul 19, 2007, 11:46 AM
Joined Jun 2007
I balanced my blades using the the cheap Align blade balancer like the one FB used on his tracking vid. I did not balance the blade CG w/ a mainshaft as he did on the vid. Instead, I just did it the fast way where I would line up the blades on the balancer, put it between 2 glasses, and then added electric tape (heavier and doesn't need as much to add weight) to the lighter blade until it was balanced. Should I balance the blade CG?
I did not check flybar balance. I just made sure they were the same length on both sides w/ a vernier caliper. How would I balance the flybar? Do I just find the centerpoint and then add tape? Wouldn't that make sliding of the flybar weights impossible?
I leave my blade grips loose, so that I can tilt it over and the blade will fall over slightly. I did this to make sure that the blades can extend to it's normal position when spinning. Is that too loose, or is it more important to have both grips the same tightness or looseness?
When you say 2-3 turns, you do mean full turns and to the longer links and not the shorter link attached to the blade grips right? Thanks
Old Jul 19, 2007, 01:18 PM
arclite5 is offline
Find More Posts by arclite5
Joined Nov 2005
If your blade tracking has changed in flight, one of three issues is to blame.
1: You bent your spindle.
2: Your dampers are shredded or worn. Get new ones or get higher quality ones. Stock rubber o-ring dampers will get torn up in 3D flight regularly.
3: Your plastic ball link ends are worn. Replaced the ones that control your blade grips.
You can throw out the imbalanced blades theory unless he crashed, because they tracked true at the beginning of the flight yeah? You can also throw it out unless he has moderate vibes in his heli.
My money is on problem #1 or #2.
-Kyle
Edit: Large blade pitch changes are done on the short linkage rods. Small blade pitch changes are done on the long linkage rods.
arclite5 is offline Find More Posts by arclite5
Old Jul 19, 2007, 01:21 PM
Ah Clem is offline
Find More Posts by Ah Clem
Team Compass/KBDD Team Pilot
Ah Clem's Avatar
Joined Mar 2005
Differential throw will also do it.
As someone mentioned before me, I would check the spanwise CG and wieght first.
Ah Clem is offline Find More Posts by Ah Clem
Old Jul 19, 2007, 02:16 PM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
To balance the blades you should get the CG matched first. Then add the weight at the cg. Gyroscopic force will change the effective weight of the blade compared to the other, if the weight is added away from the cg point.
Roto Rob is offline Find More Posts by Roto Rob
Old Jul 19, 2007, 04:24 PM
Joined Jun 2007
-Kyle
My blades were tracking properly before but I think the pitch was already off then. I started messing w/ the links to set each individual blade for 3D (-11, 0, +11). I didn't check tracking at the beginning of the flight; only at the end after doing flips. I'm guessing that they were already off track at the beginning.
I'm going to rebalance the blades and do it right. I thought I'd get lucky by doing it the easy way
My dampers only have about 10 flights on them, but I do have some more stock ones so I'll change them.
I hope I don't have anything bent on the head. I do have a brand new Dragonus rotor head set that's been sitting for about a month now; maybe I'll try it out. Hope it works out.
Can't get T-rex 450x blade tracking right!! Silverstreak328 Mini Helis 0 Oct 24, 2004 04:03 PM
How to get Profi 4000 to act as teacher? Roj Radios 8 Sep 26, 2004 03:25 AM
Help! RC as well as Slowstick NOOB needs help please. gkidd Beginner Training Area (Aircraft-Electric) 15 May 09, 2004 09:13 PM
Wanted: Dumas free running kits and hardware as well as information on them Kloud Boats (FS/W) 0 Aug 11, 2003 08:49 PM
does the zagi x perform as well as zagi 400? captainjulio Foamies (Kits) 14 Aug 06, 2001 05:55 PM
