Old Nov 11, 2002, 03:28 PM
kelvin is offline
Find More Posts by kelvin
Involuntary Beta Tester
Joined Jan 2002
Anyone Order Spring Air Retracts 603 from Horizon
Anyone order a main gear micro sytem from Horizon. Does it come with everything I need, valves, hose, air tank etc. Is the air tank the small one? Does it come with the 1/8" wire struts?
Thank you
Kelvin
kelvin is offline Find More Posts by kelvin
Old Nov 11, 2002, 04:49 PM
Kevin Murray is offline
Find More Posts by Kevin Murray
Kevin Murray's Avatar
USA, NC, Greenville
Joined Dec 1999
Hi Kelvin,
Thats where I got my set.
Yes, yes, yes, yes, yes.
A source of comresed air is all you will need.
You can either bend the 1/8" wier to form an axel , or order the bolt on stub axels.
Kevin Murray is offline Find More Posts by Kevin Murray
Old Nov 11, 2002, 09:42 PM
kelvin is offline
Joined Jan 2002
Originally posted by Kevin Murray
Hi Kelvin,
Are the bolt on stub axels a Spring Air part?
I saw a set of 501's at the local hobby store so I have an idea what comes in the set better but they didn't have the 603s.
Kelvin
Old Nov 12, 2002, 12:58 AM
CraigO is offline
Find More Posts by CraigO
Go Wallabies!
Adelaide, South Australia
Joined Dec 2000
weight
gents
I have been thinking about a set of these what does the whole kit and kaboodle weigh.
I used mechanical retracts on my 54inch mozzie and without wheels they were pretty light under 6 oz i would think. Sadly the mozzie is no more, radio interference robbed me of my baby, but i am thinking of building another, possibly slightly bigger with spring airs instead.
So back to the original question, how much did the whole thing weigh?
cheers
Craig
CraigO is offline Find More Posts by CraigO
Old Nov 12, 2002, 09:04 AM
GWRIGHT is offline
Find More Posts by GWRIGHT
Product Manager at Hobbico
GWRIGHT's Avatar
United States
Joined May 2000
just call spring-air and talk to bill. He's a really nice fellow and will explain everything that comes with the retract set. Spring-air is here in melbourne,.. actually located next-door to the place that does the laser cutting for my kits. Bill and his son are in our club and both are good pilots (and have spring-air retracts in everything of course ). I have a set of the 600 series in my OV-10 bronco. I did drill them out for 5X32 wire since i knew the bronco would be well over the weight they're intended for (It ended up 7.5 lbs). The retracts were,..if memory serves,.. roughly one ounce per,.. so 3 ounces for the three of them, plus another ounce and a half for the tank, valvle/servo (little HS81, actually had 7 HS81's in that plane).
GWRIGHT is offline Find More Posts by GWRIGHT
Site Sponsor
Old Nov 12, 2002, 11:03 AM
kelvin is offline
Joined Jan 2002
Re: weight
Originally posted by CraigO
gents
cheers
Craig
I've read that 2 603 mains and the support equipment is 4oz or maybe a little less.
http://www.rcgroups.com/forums/showt...threadid=69867
I saw some of the air tanks at the hobby store and they're very light. The retract set comes with the small tank. Ron Daniels stated in a thread that he was able to get about 20 cycles out of this tank on his 45" Tempest with 603s.
Gordon, in the UK uses 3 of them in his 6.5lb Mig15.
My Kyosho Spit may be close to 7lbs so I may have to do what Gary did for the wire struts.
Kelvin
Old Nov 13, 2002, 08:30 PM
Ron Daniels is offline
Find More Posts by Ron Daniels
Ron Daniels's Avatar
Kitchener, Ontario, Canada
Joined Jan 2001
Installed weight is about 4 ounces.
So, it is 4 ounces heavier than no gear, but probably only 1-2 ouncs heavier than fixed gear.
Very high quality stuff. I use it in a 2 3/4 lb plane.
Ron Daniels
Ron Daniels is offline Find More Posts by Ron Daniels
Old Nov 14, 2002, 10:44 AM
kelvin is offline
Joined Jan 2002
Ron Daniels
That's good news. I'm planning on attempting to mount the gear at a more scale-like position with the gear angled back around 16 degrees aft from a perpindicular line to the fuse. This will give the extended landing gear a forward position.
In order for the wheel to be parallel to the centerline when extended it will be at an angle in the wheel well when retracted from what I can visulize. I was hoping to do gear doors but won't the gear doors be at an angle and not flush with the wing surface? I guess there is no way to do it unless the landing gear rotates a little but these are not designed to do that.
Kelvin
Mini 602 Spring Air Retracts? where? demetrius Electric Ducted Fan Jet Talk 1 Nov 01, 2004 02:05 AM
Looking for Spring Air Retracts (602-603) or EJF FAA Aircraft - Electric - Airplanes (FS/W) 0 Oct 24, 2003 09:01 AM
Will spring Air retracts work on a 16 pound plane? Gary Warner Giant Scale Airplanes 2 Sep 25, 2003 05:55 PM
WTB: Spring Air Retracts 602 / 603 FAA Aircraft - Electric - Airplanes (FS/W) 0 Jun 24, 2003 04:25 PM
Spring-Air Retracts Sligh Electric Plane Talk 0 Dec 15, 2001 05:31 PM
