Old Dec 08, 2007, 08:10 PM
CUBANO8 is offline
Find More Posts by CUBANO8
Joined Oct 2003
Phoenix,
Thanks for the video and all the info.
Guys, I went to Barnes&Noble book store today, and I happend to find this incredible bargain book Titled "B-17 Combat Missions" for $12.98.
This is a modelers delight, it has the most incredible details of the interior of the B-17 that I've seen in a while, lots of pics.
Next time your at your local book store check it out.
Here are some samples:
CUBANO8 is offline Find More Posts by CUBANO8
Old Dec 08, 2007, 11:58 PM
Matt Halton is offline
Find More Posts by Matt Halton
Wannabe B-26 pilot!
Matt Halton's Avatar
Southwold, Suffolk, UK.
Joined Nov 2002
150? Can you make it 120 and I'd buy one from you!
Matt Halton is offline Find More Posts by Matt Halton
Old Dec 11, 2007, 12:15 AM
Wannabe B-26 pilot!
Joined Nov 2002
I'll be getting one of these mid Jan..Will post lotsa luverly pics
Thanks Scott!
Old Dec 11, 2007, 11:58 PM
gunracer is offline
Find More Posts by gunracer
diligentia vis celeritas
gunracer's Avatar
Corona, CA
Joined Feb 2006
it's now listed on nitroplanes' site...
http://www.nitroplanes.com/nitromode...-arf-kit-.html
gunracer is offline Find More Posts by gunracer
Old Dec 12, 2007, 08:33 AM
Robert Stinson is offline
Find More Posts by Robert Stinson
Ahhgh! Not ANOTHER new plane!
Robert Stinson's Avatar
San Diego, CA
Joined Dec 2001
I've ordered mine - thanks for the heads-up! $199 +tax +s&h.
I recently completed a Great Planes DC-3, and did some propeller power testing for it. Master Airscrew makes 3-bladed propellers in 6x4, 6x4 pusher, and 7x4 sizes, also 8x6. 6x4s and 6x4 pushers would be ideal for this project; counter-rotating 3-bladed props!
However. A 400T with the 7x4x3 on 3S generated 73 watts, not enough I fear for this plane. It'd be less than 300W overall. on the DC-3, I went for a 400F with the 6x4x3s, getting about 21A each at WOT. Obviously, I didn't open the throttle that far under normal circumstances. This wouldn't work for the B-17, since with 4 motors you'd be pulling over 80A peak. You'd fry the battery!
What would be ideal is a motor with output in between the 400F and 400T on 3S. Another option would be to try the 400T with the 7x4x3 on a 4S system, hopefully to get around a 10A draw for each motor. Maybe someone could do some bench testing?
Robert Stinson is offline Find More Posts by Robert Stinson
Old Dec 12, 2007, 08:43 AM
CUBANO8 is offline
Joined Oct 2003
Thanks gunracer, i got my order in too.
Old Dec 12, 2007, 11:22 AM
San Diego, CA
Joined Dec 2001
For those who want to model the plane as it comes, without the chin turret, here's a reference pic..early markings, too.
Old Dec 12, 2007, 11:48 AM
aferguson is offline
Find More Posts by aferguson
Joined Apr 2006
oh goody.......i'll be getting one too, as soon as i recover from Christmas spending.
aferguson is offline Find More Posts by aferguson
Old Dec 12, 2007, 12:04 PM
gunracer is offline
gunracer's Avatar
Corona, CA
Joined Feb 2006
don't know if the retracts come with the kit...adding details will add weight so she'll probably be at or over 5 lbs when all's said and done...at 5 lbs all up, 400 watts would be the minimum i'd be looking at...for 3 cells, the bp motors (2212-10, 2212-13) on mas 7x4x3 look like they should work...
Old Dec 12, 2007, 12:05 PM
San Diego, CA
Joined Dec 2001
Did some more testing. Using a 7x4x3 on 4S with an Aurora 400T was too much - close to 200 watts. However, the good news is that I put the 6x4x3 on with 4S and got the following: 9.99 Amps and 144 Watts peak! I only ran it for 10 seconds, but the motor seemed fine - not hot or anything. I'm sure if I kept up constant voltage it'd damage the motor, but for takeoffs and emergencies, I think it'll work. Woohoo! 3-bladed props!
Old Dec 12, 2007, 10:54 PM
Wannabe B-26 pilot!
Joined Nov 2002
Cool, we'll be seeing lots of them soon eh?
We'll need to get a new thread going.
I'm told no retracts included in the kit.
Old Dec 13, 2007, 05:55 AM
Scott Cuppello is offline
Find More Posts by Scott Cuppello
Commercial UAV Pilot
United Kingdom, England, Carlisle
Joined Mar 2007
No, I used cheapie CMPro retracts, more than enough. Like I said in the other bit, I used 4 x 2012-10 [1340kv] motors on 3s, with 8x6 props, getting a total of [550w for 1st 30 sec's dropping to] 480w....but watch this.....it's a little odd, on the set up just mentioned, it will fly around on 1/2-1/3 throttle, on 8x4 three blade props, power was down to 400w.....and it just wouldn't ROG......on 7x5 props, it flew soooooo slowly, just above the stall......go figure. Bear in mind, there is no room for anything bigger than 400's.
Scott Cuppello is offline Find More Posts by Scott Cuppello
Old Dec 13, 2007, 07:32 AM
FLL is offline
FLL
Find More Posts by FLL
FLL
Towaco, NJ
Joined Mar 2003
Can't believe it's taken this long for an ARF B-17 to come to market.
Frank
FLL is offline Find More Posts by FLL
Old Dec 13, 2007, 07:41 AM
shschon is offline
Find More Posts by shschon
shschon's Avatar
United States, CA, SF
Joined Aug 2004
Sounds like not enough pitch speed to go above stall speed. It may also be due to not enough rpm since it sounds like you are using the same motor and battery. For smaller props/lower pitch props you often need to ramp up voltage or change gear ratio to get more rpm.
Another possibility is that some props are reversed and/or motors are turning in the opposite/wrong direction so you are losing lots of thrust without knowing. On a single motor plane this kind of oversight is easy to catch, but for 4 engine plane it is harder to notice because you may have more motors configured correctly and the plane can still move forward.
shschon is offline Find More Posts by shschon
Old Dec 13, 2007, 07:59 AM
San Diego, CA
Joined Dec 2001
The 3-bladed props are very inefficient at 400T/3S speeds - just not the right blade airfoil for slow rpm's - like trying to fly a hotliner at 30mph. That's why I upped the rpm with the 4S.
Seeking Electric Flying Fortress B 17 Model wile_e_coyote North Coast Electric Flyers 87 Aug 02, 2014 12:24 AM
Discussion Sterling B-17 rubber power model rcozstyle Electric Plane Talk 2 Jul 11, 2007 12:00 AM
For Sale Ready to Fly B-17 - 65" Fundy Aircraft - Electric - Airplanes (FS/W) 5 Sep 12, 2006 10:43 PM
Discussion B-17 Model Owners - Watch Out! kdahlhaus North Coast Electric Flyers 0 Mar 07, 2006 08:55 AM
Monaville, TX (C) 17th Annual B-17/Big Bird (Scale) Fly-In. Hobbygroup Electric Flight Events 0 Sep 16, 2005 08:01 PM
