Old Jul 18, 2007, 08:17 AM
cheez is offline
Find More Posts by cheez
two rivers, wi
Joined Jul 2007
Idea
Hb Cp2 Tools For Main Rotor Gear
I use copper wire for a shear pin on the drive gear. When you crash, it breaks. This minimizes bent shafts and is less drain on your ESC. I made a handle for the allen wrench to make it easier to handle (especially for replacing blade clamps). After a few (or many) crashes, the shaft may be deformed and hard to slide through the bearings. I made a tool for tapping gear off the shaft (hole down the middle is out of view), and a set of bars for pressing the gear back in place.
cheez is offline Find More Posts by cheez
Old Jul 18, 2007, 08:41 AM
BowerR64 is offline
Find More Posts by BowerR64
BeeZaur 480
BowerR64's Avatar
Parkville Mo.
Joined Dec 2004
I found where i had problems was where the collar clamps to the shaft and the top jesus pin hole got messed up a few times also. I usualy sand the shaft a little around those places when i put it back together (if the shaft isnt bent)
BowerR64 is offline Find More Posts by BowerR64
Old Jul 18, 2007, 09:00 AM
cheez is offline
two rivers, wi
Joined Jul 2007
use an electric drill
When the hole gets distorted, I chuck it up in a lathe. An electric drill with sandpaper works, too. Usually, it's the copper pin on the main gear that shears, the set screw on the collar distorts the shaft, and the hole for the main gear shear pin distorts. The center hub pin hole distorts also, but the pin usually stays inact. I usually only have to remove it if I need to starighten the shaft. Since I've been using copper shear pins, I haven't bent the shaft. I have a HB FP on the way, so hopefully I'll be crashing less (or at least doing less damage).
Old Jul 18, 2007, 09:22 AM
BowerR64 is offline
BeeZaur 480
BowerR64's Avatar
Parkville Mo.
Joined Dec 2004
Yeah i think it works like a lawnmower shear pin. It takes some of the load when the blads stop quickly from an impact.
Old Jul 18, 2007, 09:28 AM
cheez is offline
two rivers, wi
Joined Jul 2007
I need to try making something for the tail rotor. Either a shear pin or a friction clutch. It would save the motor more than anything.
Old Jul 18, 2007, 09:32 AM
BowerR64 is offline
BeeZaur 480
BowerR64's Avatar
Parkville Mo.
Joined Dec 2004
There is already a break away system designed for that. The rotor pushes into the rear gear with those 2 little pins and the tubing is like a shock. When the tail rotor hits somthing it pops the pins out of the gear and it pushes the tubing away then the gear just spins.
After a while the pins get warn down or the rotor chips and gets out of balance then its time for a new rotor.
Old Jul 18, 2007, 09:40 AM
cheez is offline
two rivers, wi
Joined Jul 2007
Part of the breakaway system is the motor
Idea Hb Cp2 - Tools For Main Gear cheez Mini Helis 0 Jul 17, 2007 10:15 AM
How tight is normal for the Main Rotor Holder (TRex)? hb888 Mini Helis 7 Aug 25, 2005 05:07 AM
WTT: Stock HB Tail Blade for Main Rotor Head Yoke EddieNewYork Aircraft - Electric - Helis (FS/W) 0 Jul 21, 2004 12:47 AM
HeliStar main rotor gear ratio? corey Micro Helis 2 Feb 08, 2004 11:18 PM
Main rotor gear loose on HB NewHummer Micro Helis 14 Aug 22, 2003 08:25 PM
