Old Jul 17, 2007, 01:06 AM
Draconious is offline
Find More Posts by Draconious
Draconious's Avatar
United States, MI, Lapeer
Joined Aug 2000
Wanted: some one with a CnC hotwire cutter to cut me up a sheet of foam...
I need a foam sheet cut up, hotwire CnC style. Not a wing, not even plane related... Basically a profile pattern, in a bunch of zigzag puzzle like shapes... should be able to cut it through a 2" sheet of foam (3x8 I think is normal?). I am unsure what foam type, this is for a prototype so anything cheap and does not break up into little beads. I do not really need a whole sheet but figured it would be more worth some ones time if I paid for the whole sheet... I will be cutting them to lengh on a band saw... the lengh will varry based on its application.
The ideal foam would be black, depron, epp or something... but anything will do right now its just going to be a product concept model...
The line I need cut is in AutoCAD... so I can make .dxf or export it... will prolly fit about 5 or 6 passess through the foam...
Preferably michigan area, but I will drive a bit to get it...
Thnx
Draconious is offline Find More Posts by Draconious
Discussion Anyone in Sydney with a cnc foam cutter? stumax Australia 9 Nov 05, 2006 03:42 AM
Can some one help me with this choper woodsy Micro Helis 22 Nov 16, 2004 04:10 AM
WTB cnc hotwire cutter charlieuk Aircraft - Sailplanes (FS/W) 1 Feb 26, 2004 01:17 AM
post any pics here of what has been done with a cnc foam cutter sylair Foamies (Kits) 0 Jun 23, 2003 06:25 PM
Sky scooter pro2 or T-IFO for some one with little experience? jra111 Parkflyers 3 Nov 17, 2002 12:10 AM
