Old Jul 15, 2007, 09:52 AM
wamanning@email.com
wamanning@email.com
Guest
n/a Posts
noob question: FM radios going from 27mhz to 72mhz possible?
is it possible to get a 27mhz TX to work with a 72mhz RX (both are FM)
with a simple crystal swap in one of the units? both are FM and the
RX supports both +/- shift.
for some reason i'm thinking it's not that simple, but want to be
sure...
walter
Old Jul 15, 2007, 11:27 AM
Ed Cregger
Ed Cregger
Guest
n/a Posts
Re: noob question: FM radios going from 27mhz to 72mhz possible?
<wamanning@email.com> wrote in message
news:1184507548.995403.116030@22g2000hsm.googlegro ups.com...
> sure...
> walter
You can swap crystals within a band (27 MHz OR 72 MHz), but you cannot swap
bands unless the transmitter utilizes a module system that includes the
circuitry necessary to change bands.
Ed Cregger
Old Jul 15, 2007, 11:39 AM
Vance Howard
Vance Howard
Guest
n/a Posts
> sure...
> walter
That would be too far of a jump for just a crystal swap. It would need to
have a few other parts adjusted by a qualified technician.
Old Jul 15, 2007, 12:20 PM
Tim Wescott
Tim Wescott
Guest
n/a Posts
> sure...
> walter
No can do.
Both the transmitter and receiver contain tuned circuits that
can only be adjusted over a relatively small range of frequencies. To
make the nearly 3:1 step you need at least component changes, and will
often see different circuits used.
Tim Wescott
Control systems and communications consulting
http://www.wescottdesign.com
Need to learn how to apply control theory in your embedded system?
"Applied Control Theory for Embedded Systems" by Tim Wescott
Elsevier/Newnes, http://www.wescottdesign.com/actfes/actfes.html
Old Jul 15, 2007, 12:40 PM
42etus
42etus
Guest
n/a Posts
You are correct it's not that simple. It could be done, but it would take
much more than simply changing crystals.
42
> sure...
> walter
Posted via a free Usenet account from http://www.teranews.com
Old Jul 15, 2007, 12:53 PM
Red Scholefield
Red Scholefield
Guest
n/a Posts
An cost more than a new radio transmitter on 72 mHz. You can buy good 4
channel name brands on e-bay for little to nothing. I've got several that
I'll let go for $25 plus shipping ($8.95 Fixed rate box).
Red S.
"42etus" <paulinlapine@msn.com> wrote in message
news:469a41e2$0$16357$88260bb3@free.teranews.com.. .
> 42
>> sure...
>> walter
Old Jul 16, 2007, 10:13 AM
Ed Cregger
Ed Cregger
Guest
n/a Posts
"Red Scholefield" <redscho@bellsouth.net> wrote in message
news:fismi.58014$Fo1.38676@bignews7.bellsouth.net. ..
> Red S.
>> 42
>>> sure...
>>> walter
I have a few RTF electric models. The transmitters that come with two of
them, are simply amazing in their feel and utility. It wasn't long ago that
just a transmitter of similar apparent quality and feel would have cost more
than I paid for the whole RTF set up.
Today, with Tiger Direct selling rechargable batteries and chargers (4 AA
cells) for around $25 USD, fitting one of these transmitters with
rechargable batteries is a piece of cake and cheap. Not only that, but you
can use the rechargable batteries for other purposes when not in the
transmitter. Such as my Olympus C5050A digital camera.
Ed Cregger
Going from Sky Scooter to GWS P-51 elau Parkflyers 3 Jan 02, 2003 03:08 PM
FS: Hitec Focus 3 FM. Radios rpavich Aircraft - Electric - Airplanes (FS/W) 6 Nov 25, 2002 02:46 PM
8 plus cell charging from car battery is it possible carr Beginner Training Area (Aircraft-Electric) 5 Aug 19, 2002 10:19 PM
Going from 8 cells to 6 direct drive, bigger prop ? Al P Power Systems 2 Jan 06, 2002 10:56 AM
Going from electrics to ? MicroRotors Electric Heli Talk 0 Nov 09, 2001 03:08 PM
