Old Jul 14, 2007, 11:01 PM
theclaw is offline
Find More Posts by theclaw
GOT WIND?
theclaw's Avatar
Escondido
Joined Jul 2006
Build Log
RiteWing 48-FT build thread
Hi all here is a prototype wing I got from Chris at http://www.ritewingrc.com/. I have decided to put up a my first build thread. Here goes here are my first couple stages. I installed the four small carbon rods top and bottom. Then I gorilla glued the two main spars in along with the two wing halfs together. Man that gorilla glue activates like crazy with sprayed with water, it sqeezed out of every nuk and craney.
theclaw is offline Find More Posts by theclaw
Old Jul 14, 2007, 11:19 PM
THUREN is offline
Find More Posts by THUREN
blah...
THUREN's Avatar
United States, OR, Bend
Joined Jun 2005
WOW very little sweep... Very cool..
I'da used goop but thats just me...It looks fast, so weight savings...... eehhhhhh......
THUREN is offline Find More Posts by THUREN
Old Jul 14, 2007, 11:52 PM
D.S. is offline
Find More Posts by D.S.
Circle Jockey
D.S.'s Avatar
A Sasquatch took my plane! Tujunga. Ca.
Joined May 2004
Originally Posted by theclaw
Discussion - RiteWing 48FT build
Forty eight feet, that's huge!!!
D
D.S. is offline Find More Posts by D.S.
Old Jul 14, 2007, 11:59 PM
theclaw is offline
GOT WIND?
theclaw's Avatar
Escondido
Joined Jul 2006
Yea I normally use hot glue for joining everything.
Trying something different with the gorilla glue. I have used gorilla glue for so many different EPP tasks and it bonds so incredibly well. Plus it will be covered in henrys 183 fibermesh soaked in 3M90. So it will have even more strength on there.
-Jason
Old Jul 15, 2007, 12:08 AM
theclaw is offline
GOT WIND?
theclaw's Avatar
Escondido
Joined Jul 2006
Here is the progress with the all the gear installed. The henrys 183 mesh covering went on very nice and flat. Man This thing is stiff as a board.
-Jason
Old Jul 15, 2007, 03:11 PM
Sor Thum is offline
Find More Posts by Sor Thum
OGT back from '92
Sor Thum's Avatar
San Jose, Ca
Joined Feb 2006
Can you explain how you did the vert attachment? Looks great!
Matt
Sor Thum is offline Find More Posts by Sor Thum
Old Jul 15, 2007, 05:02 PM
theclaw is offline
GOT WIND?
theclaw's Avatar
Escondido
Joined Jul 2006
Matt
You bet Matt,
I inserted the tail into the tube. Then mearsured how far back I wanted the tail to run. lined it up drew my lines sliced out the section. Hot gluded the tube in its postition lined up with the bottom airfoil. Then I put two slices of EPP on the top and bottom with hotglue. Solid as a rock. Then once I used the Henrys 183 it really locked that puppy down.
There you go,
-Jason
Old Jul 15, 2007, 05:08 PM
theclaw is offline
GOT WIND?
theclaw's Avatar
Escondido
Joined Jul 2006
Here is my latest photos, Man I am not even kidding when I say the henrys made it stiff as a board. I can not wait to make a combat ship with this stuff.
Now I am off to the beach for some CG balancing and flight reports.
-Jason
Old Jul 15, 2007, 06:42 PM
THUREN is offline
blah...
THUREN's Avatar
Joined Jun 2005
-Jason
Looks good!
The Henrys mehod is not the greatest for combat though...
I'm guessin 8oz of nose weight...
Old Jul 15, 2007, 07:16 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
You ar probably about rite on the weight Thuren ,The Ft is a total proto ,I sent it to claw along with the new version of the proovin phoenix fity,The FT is a version of a non released sloper that I fly.It has just slightly less sweep and zero washout than the first one .
Hope it all goes well ,I have ben slammed w buidls so I figured I would let The claw give it a go.
Hope it goes well .
ck
klique is offline Find More Posts by klique
Old Jul 15, 2007, 09:17 PM
theclaw is offline
GOT WIND?
theclaw's Avatar
Escondido
Joined Jul 2006
Well the lift was very light at little beach in Carlsbad. I Threw it out a few times, flew very steady it did bob a little bit kind of porpused, with about 12 ounces of nose weight. I did use a smaller battery pack a little extra weight was required. I need more lift and day light too dial it in real good.
Question: When they porpuse like that is it tail heavy a little?
I always mix those up. I always wind up adding or removing weight till she flys level.
-Jason
Old Jul 15, 2007, 09:29 PM
klique is offline
Mum is the word!
Joined Jun 2003
Maybe the next one we can loose one of the internal spars and put the servos up alongside the batteries.Even 2 degrees of sweep added might help if somone wants a liter build.
Jason once you get some good lift she should rock.I actualy like mine medium to heavy.
I was at carlsbad last week and it was pretty week lift When I was there too.
ck
Old Jul 15, 2007, 09:38 PM
infopimp is offline
Find More Posts by infopimp
PNF
infopimp's Avatar
Los Gatos, CA
Joined May 2005
What is your AUW?
infopimp is offline Find More Posts by infopimp
Old Jul 15, 2007, 09:49 PM
WingmanDan is offline
Find More Posts by WingmanDan
fast chevron foam
WingmanDan's Avatar
United States, CA, Laguna Niguel
Joined Jun 2005
Porpoising is typically from too much elevator... how far do ya have it dialed down?
Can't wait to hear how she flies in stronger lift... Chris designs some cool stuff!
-Dan
WingmanDan is offline Find More Posts by WingmanDan
Old Jul 15, 2007, 10:27 PM
THUREN is offline
blah...
THUREN's Avatar
Joined Jun 2005
Tell me you didn't start building yesterday?? !! ??
If so you are FAST!
If it was porpoising, and you could fly it, it was probably a combo of too much throw and a bit nose heavy. I would image your elevator throw would be 3mm(1/8") MAX with that tight sweep. Should bang a freaking TURN once dialed..
Build Log The Ritewing Build Thread Atom1025 Flying Wings 12814 Aug 23, 2016 09:19 PM
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
My Bobolink Build Thread (very Colibri like) Jim Poor Hand Launch 65 Dec 10, 2003 04:48 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
