Nov 11, 2002, 02:52 PM
Ireland
Joined Jul 2002
Well, regarding your first point, you should try and get as much down as possible for braking. However you don't need 90 degrees, 70 or more should be plenty. If you look at the frontal area of the flap set at 70 degress, and at 90 degrees, there's very little difference. And getting the linkage to give 90 can be tricky enough...... (Or you can use trig to work it out mathematically!)
Regarding "up" flap, my Multiplex Alpina uses upward movement of the flaps to help roll response, half the travel of the adjacent alieron. The downward aileron is NOT assisted by downward flap. This setup helps avoid adverse yaw, and it works great. (It's as advised by Multiplex.) There's my 2 cents.....
