Old Jul 12, 2007, 12:30 PM
Southern T Rex is offline
Find More Posts by Southern T Rex
Baton Rouge, Louisiana
Joined Apr 2007
Help!
rex 450 ,JR 790 Receiver , JR7202 radio Heading Lock not working
I am building a Rex 450 . Everything is ready to go , but when I power it up , the tail rotor is not "creeping " as it should when in Heading Lock mode. It stays put right in the middle. What am I missing on this? in the radio settings or in the receiver channels . I know Ail , elev, rudd, are all correct (obvious)
I am unsure of where to plug the 2 gyro plugs , what goes into Aux 1, aux 2 , and gear . Could this be the problem ! I have it set up as my Rex600 !
S Trex
Southern T Rex is offline Find More Posts by Southern T Rex
Old Jul 12, 2007, 01:13 PM
Ah Clem is online now
Find More Posts by Ah Clem
Team Compass/KBDD Team Pilot
Ah Clem's Avatar
Joined Mar 2005
Which gyro?
The 402 does not creep when it is just sitting.
One plug coming from the gyro goes into the rudder channel on your reciever. The other goes to one of the auxiliary channels to adjust the gain. If a 401, this can shift the gyro from rate mode to heading hold and also adjust the gain in each mode.
Ah Clem is online now Find More Posts by Ah Clem
Old Jul 12, 2007, 05:36 PM
TrumpetRhapsody is offline
Find More Posts by TrumpetRhapsody
TrumpetRhapsody's Avatar
Arkansas
Joined May 2007
Aux1 is taken by one of your cyclic servos (can't remember which), On the XP7202 the gyro gain wire (yellow) goes in your Aux2 slot. Check out the finless videos to help you set your gain from the radio (assuming GY401). A high quality gyro when trimmed correctly shouldn't creep like a low quality one does.
TrumpetRhapsody is offline Find More Posts by TrumpetRhapsody
Old Jul 12, 2007, 06:51 PM
Joined Apr 2007
my gyro
I am using an align rce500x gyro
thanks
don
Old Jul 12, 2007, 10:01 PM
Ginvent is offline
Find More Posts by Ginvent
Flying better than every
Ginvent's Avatar
United States, NC, Cameron
Joined May 2007
Ok on JR
ch1 (THRO)- esc lead
ch2 (AILE)- Aleron servo
ch3 (ELEV)- elavator servo
ch4 (RUDD)-the 3wire lead from gyro
ch5 (GEAR)- the single wire lead from gyro
ch6( AUX 1)-picth servo
ch7 (aux 2)- anything extra lights landing gear but this is not used for your case
I have a XP6102 but the and R700 RX but it is basically the same. you might have everything hooked up properly but im lost on the programing part in the radio as to how to set gain and such and that might be you problem but All I now is for heading hold set gain allilte above half way to get HH.
Some one help me on 401 setup on a 6102 and 7202!
Ginvent is offline Find More Posts by Ginvent
Old Jul 12, 2007, 10:51 PM
Roto Rob is online now
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
If you want to see if it "creeps" just move the tail to the side. If in HH mode the servo should travel to one side. If in rate mode it will travel towards one side and when you stop rotating the heli it should center. You can plug the gain into gear and use the gear switch. Adjust the end points on each side of the switch to control gain. Or use Aux 2 and use the gyro sens menu to control the gain and the switch used.
Roto Rob is online now Find More Posts by Roto Rob
Help! t rex 450 jr 7202 setup Southern T Rex Mini Helis 3 Jul 10, 2007 11:57 AM
Sold Brand new JR 790 receiver and electron 6 Kevdawg Aircraft - General - Radio Equipment (FS/W) 4 Nov 10, 2006 05:01 PM
For Sale JR 790 Receiver, JR 821 servos, both new bjacks Aircraft - General - Radio Equipment (FS/W) 1 Sep 07, 2006 05:09 PM
