N Lauderdale,FL,US
Joined Jun 2001
St. Mary, Maryland, United States
Joined Dec 1996
. Lets start from the beginning? Are you a mode 1 or 2 flyer? I ask because for mode 2 the throttle and rudder are on the left stick, Aileron / elevator on the right. The normal reciever slot assignments for a futaba rx if I remember right is aileron,elevator, throttle,rudder for channels 1,2,3,and 4 respectively. So, if the radio is wired normally for mode two plugging the elevator servo into #2 should give servo movement if you move the right stick up and down. If you have a non-futaba Rx than the assignments might be different. If you wanted elevator on the left stick then presumably channel 3 would work. Try checking the positions of the reversing switches? Maybe one is in the center rather than to one side and is causing non action on the elevator stick. |
| Thread Tools | |
| F/S Mid size Micro Heli (Cyber Copter) Almost ready to Fly add rx and gyro thats it! | Lv2Fly | Aircraft - Electric - Airplanes (FS/W) | 15 | Nov 21, 2003 03:22 PM |
| FS: Simple 400 - Almost ready to Fly!!! | ChrisD | Aircraft - Electric - Airplanes (FS/W) | 6 | May 16, 2003 09:08 AM |
| Almost Ready to Fly - Tiger Moth | cubsflyer | Parkflyers | 6 | Nov 13, 2002 05:27 PM |
| Need some help - EStreak almost ready to fly | Bill Germanson | Sport Planes | 5 | Apr 05, 2002 09:24 PM |
