Old Jul 11, 2007, 10:08 PM
fenderjw is offline
Find More Posts by fenderjw
United States, SC, Gilbert
Joined Jul 2003
Help!
Sig Kadet Sr Arf Fuel Tank Removal
Bought a used Kadet Sr ARF for use as a club trainer and I can't find a downloadable manual for it anywhere
I gather from the other threads that I've searched that the CG should be 3 and 7/8ths back from the LE. That sound right?
Also, I need to remove and replace the leaking fuel tank. I don't see a removable hatch top or bottom behind the firewall and I can't get in there from the cabin to pull it out because there's a piece of light ply epoxied in behind the tank holding it in. So whaddya think? Should I cut in from the top or the bottom of the fuse to get at the tank the tank?
Thanks for any advice.
Jim
fenderjw is offline Find More Posts by fenderjw
Old Jul 11, 2007, 10:51 PM
happypappy is offline
Find More Posts by happypappy
USA, FL, Eustis
Joined Jun 2004
You should cut the piece of ply out of the way and pull it out as it was designed to do. The tank rests in a saddle that completely encircles the tank so if you cut in fromthe top or bottom you are going to have to cut this out of the way and have alot of repair to do. Set the C/G on the spar, thats close enough.
happypappy is offline Find More Posts by happypappy
Old Jul 12, 2007, 06:53 PM
vhoward1122 is offline
Find More Posts by vhoward1122
AMA # L576
vhoward1122's Avatar
United States, OR, North Bend
Joined Sep 2006
you could always email sig and see if they would send you a copy of the manual. mail@sigmfg.com .
vhoward1122 is offline Find More Posts by vhoward1122
Old Jul 12, 2007, 10:08 PM
gwinhh is offline
Find More Posts by gwinhh
Beaumont tx
I think you can find the manual at towerhobbies.com.
howell
gwinhh is offline Find More Posts by gwinhh
Old Jul 13, 2007, 07:51 AM
fenderjw is offline
Joined Jul 2003
Thanks for the info. I could not find a manual on Tower's site. I finally popped the light ply loose and pulled the tank out the rear as suggested. The builder used some hell for stout epoxy because part of the former that the light ply was attached to came of with it when I popped it loose
Thanks for the suggestions.
Jim
For Sale Sig Kadet Sr ARF - Converted to Tailwheel - RTF N925WB Aircraft - Fuel - Airplanes (FS/W) 8 May 11, 2007 04:33 PM
MaxCim system in New Kadet Sr. ARF pmmartin Electric Plane Talk 20 Mar 09, 2003 08:43 PM
