Old Jul 24, 2007, 07:20 AM
segraves is offline
Find More Posts by segraves
Joined Jan 2007
Tip: Hobby Lobby 40% Off Coupon
Originally Posted by Kaos2
I used a 1/8" X 3/8" spruce 36" long for the step because, you need something the correct height to create the step. This makes a very strong wing. No other reinforcement is necessary. I purchased my spruce stock at my local Hobby Lobby.
Tip: Hobby Lobby, www.hobbylobby.com, currently has a "40% off" coupon, usually offered on alternate weeks.
Cheers,
Bill Segraves
segraves is offline Find More Posts by segraves
Old Jul 24, 2007, 07:35 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Would the lift be offset by the Drag penalty ...? Sure a great way to strengthen the fuselage nose...but then ,it's more of a Doubler...and may create a stress riser if ended abruptly..??? Hmmmm???? What about an angled or even curved ending (TE)of the fuse KF strip ... flowing into the fuselage lines???? Experimenting with LAR KF ,these issues arise frequently ...Really Nice plane Kaos...!!!
gpw is offline Find More Posts by gpw
Old Jul 24, 2007, 07:41 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
When you guys buy your spruce , make sure the grain runs straight from one end to the other..grain feathering /slash grain running out is practically worthless for a spar ...read the wood !!! We always buy our wood at the LHS so we can see/select the good stuff and eliminate the junk...otherwise a bad spar wood is just weak dead weight ... FYI...
Old Jul 24, 2007, 10:27 AM
Kaos2 is offline
Find More Posts by Kaos2
Heli's don't fly voluntarily
Kaos2's Avatar
United States, TN, Columbia
Joined Apr 2007
Excellent point, GPW. I look at several pieces sometimes before I select one to purchase. If there seems to be a lot of good spar stock in a batch, I pick up several to have on hand. In addition to what GPW suggested, I'd also add that the tighter the grain (more lines) the stronger the spar will be, so I select based upon the direction the grain is running and the grain density.
Kaos2 is offline Find More Posts by Kaos2
Old Jul 24, 2007, 10:48 AM
Kaos2 is offline
Kaos2's Avatar
Joined Apr 2007
GPW, thanks for your kind words about the plane.
As far as my experimental version of the Regal goes, you can see by the attached picture that the plane I created has the step designed into the fuselage foam. Since it's not really a doubler, I doubt that my design would be any stronger than any other plane. The theory being tested here is to see if a vortex of air will form behind the step in the fuselage with the normal airstream passing by virtually frictionless, and thus reducing drag. Then there's the whole "lift thing" when flying knife edge. We'll see.
If I've misunderstood your post, please clarify.
Old Jul 24, 2007, 10:53 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
COOL !!! Hope it works as planned ... !!! another trick to put in the box...
Old Jul 24, 2007, 11:08 AM
TrumpetRhapsody is offline
Find More Posts by TrumpetRhapsody
TrumpetRhapsody's Avatar
Arkansas
Joined May 2007
Spruce huh. Well, I already glued the arrow in, so hopefully it won't be too heavy. I don't know how it would compare to the weight of a spruce spar.
EDIT: Just weighed the wing without ailerons, and it's 3.25oz, hope that isn't too heavy.
TrumpetRhapsody is offline Find More Posts by TrumpetRhapsody
Old Jul 24, 2007, 11:10 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
You guys need to weigh everything you put it on a plane , just so you'll know what's heavy and what's not ...
Old Jul 24, 2007, 08:09 PM
Kaos2 is offline
Kaos2's Avatar
Joined Apr 2007
I doubt that the weight will be an issue since the Regal has a lot of wing area. If you want to compare the weight of your arrow shaft vs. the spruce, one of my 1/8" X 3/8" X 36" spars weighs .5 oz. The reason for the 3/8 dimension was to get a step that was nearly 5/8" above the top side of the wing bottom sheet.
Old Jul 24, 2007, 11:19 PM
Kaos2 is offline
Kaos2's Avatar
Joined Apr 2007
Finally, Regal Paint
I finally got my Regal painted. I like to keep my leading edges of the wing a light color so the wing doesn't vanish from view when I drop below the tree line flying low. I also like a paint scheme that shows up well in flight, and that provides a significant difference between the upright and inverted appearance. Oh, and I like to keep it simple! I think this color scheme satisfies my rules.
Old Jul 25, 2007, 12:51 AM
Arkansas
Joined May 2007
Wow that looks awesome! What did you paint it with? I love the color changes between sections, very cool!
Old Jul 25, 2007, 06:59 AM
Kaos2 is offline
Kaos2's Avatar
Joined Apr 2007
Wow that looks awesome? What did you paint it with? I love the color changes between sections, very cool!
I paint all of my foam planes with common water based acrylic paint that's available at most craft stores. It can be thinned and shot on with an airbrush or applied with a paintbrush. This particular job was applied using masking tape and a paintbrush.
Old Jul 25, 2007, 07:45 AM
30v2 is offline
Find More Posts by 30v2
my nCPX is my sim!
30v2's Avatar
United States, TN, Tullahoma
Joined Jun 2007
Wow! She's looking good! I can't wait to get some paint on mine.
30v2 is offline Find More Posts by 30v2
Old Jul 25, 2007, 07:50 AM
Dickeroo is offline
Find More Posts by Dickeroo
Dickeroo's Avatar
Joined Dec 2006
Terrific paint job.
Hey, Ralph Lauren, step aside. Kaos2 is coming through. I can't wait to see that plane in the air doing its thing with those sharp graphics.
Dickeroo is offline Find More Posts by Dickeroo
Tony65x55 is offline
Find More Posts by Tony65x55
I'm not flying backwards!
Tony65x55's Avatar
Oshawa, Canada
Joined Sep 2004
Nice paint job. She looks great. Of course, if you'd painted it red it would fly faster.
Tony
Tony65x55 is offline Find More Posts by Tony65x55
The Mugi coroplast wing - free plans surfimp Flying Wings 159 Feb 21, 2016 08:33 AM
Build Log “BigNasty” Full fuse, full wing. Free Plans and Build Guide. WaterDog Foamies (Scratchbuilt) 969 Dec 27, 2015 05:55 PM
Any free plans for a flying wing? BJAZ Foamies (Kits) 3 Feb 03, 2005 04:49 PM
SlowStick w/Ailerons & Sym. Wing - VIDEO/PICS inside USSfishkiller Parkflyers 9 Nov 19, 2003 09:41 PM
sorta Horten--flying wing....FREE PLANS gpw Foamies (Kits) 16 Aug 11, 2002 12:14 PM
