Old Jul 11, 2007, 11:54 AM
Brooks is offline
Find More Posts by Brooks
Damp and Dizzy member
Brooks's Avatar
Bozeman, Montana, United States
Joined Aug 2003
Measuring and increasing a tug's bollard pull
I used a rubberband and a foot ruler to measure my vac u tug's bollard pull. I taped the rubberband (a single strand of rubber from a cut rubberband) to the 0 end of the ruler. Using a string between rubber and tug, I measured the stretch of the rubberband while the tug pulled on the string.
I found that sinking the prop slightly deeper than the design waterline increased the pull by 50%. I sank the prop by putting 6oz of lead on the aft deck. While the stern is noticably deeper riding with the lead weight, the appearance of the tug was not altered enough to make it look un-tuggish. In fact, unless you notice that the normal waterline (boundary between red oxide undercoat and black hull) is no longer evident, you'd probably not think anything of it. The extra thrust makes a difference when pulling my barges. It would make a difference if you were trying to haul another boat off a sandbar, I am sure. One disadvantage of sinking the prop is that it reduces the prop-walk, or "paddlewheel" effect somewhat. If you are used to taking advantage of this effect while manuvering your tug, then you might want to practice your usual manuvers before showing off at the regatta :-).
Measuring pull with a rubberband and ruler is not as straightforward as measuing pull with a metal spring balance (fisherman's scale). Whereas the spring constant (cm of spring extention / oz of pull) is relativly stable wrt load, the rubberband constant is not. Eg. if 1 oz. pulls the spring out 1 cm, 2 oz. would pull the spring out about 2 cm. But a rubberband would behave differently, eg. for my rubberband 1 oz. = 1 cm of stretch, 2 oz.= 4 cm, 4 oz. = 16 cm of stretch. As the pull increases, a rubberband stretches more and more. This is because the cross sectional area of a rubberband decreases as weight is added. With less area to take the stress, the band elongates more. A steel spring does the same, but to a much lesser degree (although this is one reason why spring balances are not legal for selling food). All this means in practice is that you need to calibrate your rubberband with several different known weights, hopefully weights in the vicinity of the tug's actual bollard pull. I measured 3 known weights, and used my calculator's built-in linear regression program to figure out the appropriate rubberband K factor for each pondside measurement. The K was a pretty good fit to a straight line, so you could just graph the data, and skip the math, if you wanted.
You could skip the calibration altogether, and just go on rubberband stretch distance, if you were comparing 2 different props, for example. However, you might be mislead as to the magnitude of improvement in pull from a new prop; For the rubberband above, 4x the stretch might only mean 2x the pull.
Some bollard pull results for my vac u tug with standard motor, Phil Pace's 4 blade prop, 6cell NiCd battery :
Without lead weight 3.2-3.8 oz.
With lead weight 4.2-5.4 oz.
Phil's results, for comparison 4.5 oz.
Working solo, it was hard to keep the tug perfectly lined up with the ruler and rubberband, so there was some variation in recorded rubberband stretch.
If your bitts can stand it, a running start generates much more pull, say for jerking a casualty boat off a sandbar. 'With a running start, the rubberband stretched longer than the ruler, so I don't have an oz of pull figure, but it was a significant increase.
In real tows, there is a significant horsepower requirement difference between hauling several separate barges on multiple towlines, and hauling them rafted up into one big barge. My tow textbook says up to 30% of the resistance can be attributed to the drag of the towline, so dragging multiple towlines can slow you down. With the light barges I play with, this effect was evident to some degree:
Pull needed for 4 barges, each tied to the preceeding barge: 1.5-1.9 oz.
Pull needed for 1 big long barge made up from the previous 4 : 1.3 oz.
Brooks is offline Find More Posts by Brooks
Old Jul 11, 2007, 12:15 PM
toesup is offline
Find More Posts by toesup
USA'd ex Brit
toesup's Avatar
Back.. In California
Joined Aug 2006
Originally Posted by Brooks
Measuring pull with a rubberband and ruler is not as straightforward as measuing pull with a metal spring balance (fisherman's scale). Whereas the spring constant (cm of spring extention / oz of pull) is relativly stable wrt load, the rubberband constant is not. Eg. if 1 oz. pulls the spring out 1 cm, 2 oz. would pull the spring out 2 cm. But a rubberband would behave differently, eg. for my rubberband 1 oz. = 1 cm of stretch, 2 oz.= 4 cm, 4 oz. = 16 cm of stretch. As the pull increases, a rubberband stretches more and more. This is because the cross sectional area of a rubberband decreases as weight is added. With less area to take the stress, the band elongates more. A steel spring does the same, but to a much lesser degree (although this is one reason why spring balances are not legal for selling food). All this means in practice is that you need to calibrate your rubberband with several different known weights, hopefully weights in the vicinity of the tug's actual bollard pull. I measured 3 known weights, and used my calculator's built-in linear regression program to figure out the appropriate rubberband K factor for each pondside measurement. The K was a pretty good fit to a straight line, so you could just graph the data, and skip the math, if you wanted.
If your bitts can stand it, a running start generates much more pull...
Or you could just buy a digital fishermans scale from WalMart..
Tigger (standard Springer) pulls 1lb 8oz, Scoot (straight Kort nozzle) pulls 2lb 12oz, (tapered Kort nozzle) 2lb 14oz... Mustang Sally (proposed Springer) should easily break the 3 - 3 1/2lb barrier..
A 'running start' is a 'no no' as it will probably result in the Bitts being pulled from the deck of your tug.. or barge.. You wont see a real tug doing that!.
toesup is offline Find More Posts by toesup
Old Jul 11, 2007, 12:32 PM
Brooks is offline
Brooks's Avatar
Joined Aug 2003
With your big pull capacities, you could start a new Springer event: Salvage of sunken ship/barge/treasure. A line would run from the sunken object up to a pully suspended from a large buoy (large enough to support the sunken object if it were hauled off the bottom). The salvage line would have a small buoy attached to the end. A Springer would engage the end of the line, and try to pull the treasure to the surface. The large buoy would probably need an anchor to keep it in place while the Springer tugged away on the salvage line. Or maybe it could be a team event, with a 2nd Springer holding the large buoy in place until the treasure emerged, then helping the 1st Springer to manuver the whole gaggle to shore. A 6 pack of suitable beverages might make a good treasure to rescue :-).
I only mentioned the running start in case the value of the casulty was sufficient to risk damage to the model tug. One of the key mental steps one has to take in salvage is the shift from "retrieve the casulty just like it was" to "get it back anyway you can, broken if necessary". Whether a broken tug is acceptable is a judgement call, of course.
Old Jul 11, 2007, 01:17 PM
Capt.Crash is offline
Find More Posts by Capt.Crash
**NOT GUILTY**
Capt.Crash's Avatar
Millbrook, Alabama
Joined Jun 2004
That will not be a problem with my set up...as the tow line is not actually connected to the bollard, rather only lays on top of it then goes straight down a tube and is looped around the metal servo clevis rod that is in a hard wood block on the bottom of the glass deck. I feel pretty sure I can run at full speed and snap that line all day long with out ill effects to the tug. I built it that strong.
Now a normal tug is another matter all together.
Captain Slick
Capt.Crash is offline Find More Posts by Capt.Crash
Old Jul 11, 2007, 01:25 PM
**NOT GUILTY**
Capt.Crash's Avatar
Millbrook, Alabama
Joined Jun 2004
(I'm sure this has been done)
An ole fashioned TUG-O-WAR would be fun! Pick teams of tugs to share in the war just like humans do.
Captain Slick
Old Jul 11, 2007, 01:38 PM
Ghost 2501 is offline
Find More Posts by Ghost 2501
no wings any more, just dust!
Ghost 2501's Avatar
stoke on trent
that would be fun hoggy, or perhaps a sumo style push-out
Ghost 2501 is offline Find More Posts by Ghost 2501
Old Jul 11, 2007, 06:27 PM
toesup is offline
USA'd ex Brit
toesup's Avatar
Joined Aug 2006
Its been done guys...
http://media.putfile.com/Scoot-the-Springer
Old Jul 12, 2007, 09:30 AM
LtDoc is offline
Find More Posts by LtDoc
McAlester
Joined Nov 2004
Hmm. If you hadn't sealed that rear deck, she'da had you sunk!
- 'Doc
LtDoc is offline Find More Posts by LtDoc
Old Jul 12, 2007, 09:56 AM
**NOT GUILTY**
Capt.Crash's Avatar
Millbrook, Alabama
Joined Jun 2004
Cool Video...
...but...that sure was a short tow rope...lol
What I have in mind is a group of boats on one side, pulling off against another group at the other end of the main rope...all at the same time. They could be bow to stern, but I think side by side, all tied to the end of the main tow line that maybe has a loop in the end to tie several tug boat tow lines to, is my vision. A true team sporting event. Choose whatever method to pick the teams, but at random would be cool or club VS club? No real limit to the number of tugs pulling at the same time in this event.
Captain Slick
Old Jul 12, 2007, 01:46 PM
RhumbLine is offline
Find More Posts by RhumbLine
RhumbLine's Avatar
SoAl
Joined Mar 2007
Tug 'o War
That sounds like the prelude to a grate how to class... "Now that we have recovered all of our boats and drained the water from them, lets dry them out and oil everything" LOL
Scott
RhumbLine is offline Find More Posts by RhumbLine
Old Jul 12, 2007, 10:16 PM
Prins Willem is offline
Find More Posts by Prins Willem
Old wreck in Milwaukee
Prins Willem's Avatar
United States, WI, West Allis
Joined May 2007
This is a happy coincidence. I was looking at a digital fish scale at K Mart last Saturday with this very thing in mind. I was thinking about mounting it to a 2x4 or a snow fence post with a pulley near the base. The towline would pull down on the scale and the towline would pass through the pulley to run horizontally out to the tug. Anyone see a flaw in this plan?
I am converting one of my old tugs from a single Graupner/Marx Z drive to twin screw conventional. The one z drive barely moved the boat. I'm hoping the twin props will give it some muscle. I hope the measuring rig will give some reliable data.
Prins Willem is offline Find More Posts by Prins Willem
toesup is offline
USA'd ex Brit
toesup's Avatar
Joined Aug 2006
Scott
No water ingress was reported in either Templeton OR Scoot during the making of that motion picture...
Old Jul 12, 2007, 10:22 PM
toesup is offline
USA'd ex Brit
toesup's Avatar
Joined Aug 2006
Originally Posted by Prins Willem
..I was looking at a digital fish scale at K Mart last Saturday with this very thing in mind. I was thinking about mounting it to a 2x4 or a snow fence post with a pulley near the base. The towline would pull down on the scale and the towline would pass through the pulley to run horizontally out to the tug. Anyone see a flaw in this plan?
I just tie my scale off to the nearest immovable object (..ok, a sun lounger ) and pull away...
Old Jul 12, 2007, 10:52 PM
Aerominded is offline
Find More Posts by Aerominded
Monterey Bay California
Joined Feb 2004
I hope you are sitting on the sun lounger, Toes!!! I know Scoot could drag one of those, "unattended", right into the pool!!!
Aerominded is offline Find More Posts by Aerominded
Old Jul 13, 2007, 07:34 AM
**NOT GUILTY**
Capt.Crash's Avatar
Millbrook, Alabama
Joined Jun 2004
I'm not a rocket scientist, but wouldn't the pully increase the pull power thereby giving you a false reading? I'm thinking a direct hookup would be more accurate.
Captain Slick
Discussion Tug's wanted! SZD16 Giant Scale Airplanes 0 Jan 21, 2007 07:05 PM
Question When should U.S. troops pull out of Iran? Accu157 Life, The Universe, and Politics 77 Oct 15, 2006 10:39 AM
Help! Letting water off a tug's deck meechingman Dock Talk 5 Aug 09, 2006 12:10 AM
Question Increasing antenna's length funfly2 Radios 8 Nov 01, 2005 12:05 AM
