This thread is privately moderated by brucea, who may elect to delete unwanted replies.
Old May 30, 2008, 11:43 AM
Pickle72 is offline
Find More Posts by Pickle72
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
Fundango is dead
http://www.rcgroups.com/forums/showthread.php?t=127059
Pickle72 is offline Find More Posts by Pickle72
Old May 30, 2008, 11:45 AM
IH8VTEC is online now
Find More Posts by IH8VTEC
IH8VTEC's Avatar
WLV, CA
Joined Aug 2005
You know all we want are pics...
IH8VTEC is online now Find More Posts by IH8VTEC
Old Aug 28, 2008, 08:25 PM
habitforming is offline
Find More Posts by habitforming
ΜΟΛΩΝ ΛΑΒΕ
habitforming's Avatar
USA, KY, Hebron
Joined Dec 2005
Can I get an opinion from one of you covering experts? Trying to decide between lightweight SolarFilm and typical Ultracote for a Hobby Lobby Miss Stik Sr. (55" wingspan lightweigh RET floater).
My thread is here, post #5: http://www.rcgroups.com/forums/showthread.php?t=914623
habitforming is offline Find More Posts by habitforming
Old Aug 28, 2008, 10:46 PM
hoffboy is offline
Find More Posts by hoffboy
Pencil grip
hoffboy's Avatar
Olympia, WA
Joined Feb 2008
Old School
How about silkspan over mylar (doculam)? Beautiful, durable, and light. You can dye it whatever color you like.
hoffboy is offline Find More Posts by hoffboy
Old Aug 29, 2008, 12:34 AM
markag is offline
Find More Posts by markag
Staying away from trees..
markag's Avatar
Auburn, IN
Joined Jul 2007
habitforming:
I would go with solarfilm. The plane is on the larger parkflyer size range, and ultracote might be too heavy and too strong for the airframe. Solarfilm should be just about right. You could probably even do solite (solarfilm light) if you wanted to, but it is somewhat transparent in the lighter colors.
markag is offline Find More Posts by markag
Old Sep 02, 2008, 11:20 PM
ΜΟΛΩΝ ΛΑΒΕ
USA, KY, Hebron
Joined Dec 2005
Originally Posted by markag
habitforming:
Thanks markag
I went with AeroFILM (Solarfilm). I think it will do just fine!
Old Sep 03, 2008, 03:39 PM
7rider is offline
Find More Posts by 7rider
7rider's Avatar
USA, CA, Mountain View
Joined Dec 2007
I'm going to be covering a SOARstik wing with yellow solite on the bottom and blue transparent solite on the top. I'd like the covering to meet on the top wing spar cover and my question is how I get a straight edge on the yellow over the blue. The blue solite will be easy since it will be the first layer, and I can just cut away from the spar cover, but how do I get the straight edge with the yellow solite? I read the tutorial where the red and white meet at the top, but I didn't catch the method where you get a straight line with the top layer. My concern is that I'll cut the blue solite when I try to cut a straight edge for the yellow solite.
7rider is offline Find More Posts by 7rider
Old Sep 03, 2008, 04:11 PM
NoFlyZone is offline
Find More Posts by NoFlyZone
Joined Jul 2006
Hi 7rider,
I'm trying to visualize a wing with a yellow bottom, and blue top. But I'm having a little trouble trying to figure out why the covering on top of the wing at the spar is being cut? Isn't the whole top half of the wing being done in blue?
Please forgive me inability to visualize this...
Chuck
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Sep 03, 2008, 04:24 PM
7rider is offline
7rider's Avatar
Joined Dec 2007
On the top, I only wish to use blue from the trailing edge to the top of the wing at the spar. The yellow will wrap over from underneath, past the leading edge to the top of the wing at the spar. I thought this might give a good contrast to the top of the wing.
Old Sep 03, 2008, 06:45 PM
Joined Jul 2006
Hi 7rider,
In reply #47 in this very thread, does the plane in the picture sort of resemble what you are tryig to do?
Chuck
Old Sep 07, 2008, 12:47 PM
ΜΟΛΩΝ ΛΑΒΕ
USA, KY, Hebron
Joined Dec 2005
How to penetrate covering with a control rod?
Could someone share their thoughts on how best to pass a control rod through the covering? Should I just poke a hole and run it through? Should I put in a backing plate and drill a hole?
I'm about to cover a Miss Stik. Attached is a picture of the area I'm working with. Similar situation on the bottom, of course.
Old Sep 07, 2008, 02:31 PM
hoffboy is offline
Pencil grip
hoffboy's Avatar
Olympia, WA
Joined Feb 2008
Backing Plate with Tape?
I wonder if a layer of clear packing tape might help keep the covering from tearing?
Old Sep 07, 2008, 03:26 PM
Spackles94 is offline
Find More Posts by Spackles94
War Eagle!
Spackles94's Avatar
Birmingham, Alabama
Joined Feb 2007
You could always make a simple bracing out of two pieces of scap balsa, and put one on either side of the pushrod tubing. Therefore, when you go and cut the little hole to let the tubing go through, you can still iron the covering there and it won't tear.
That's what I've done in similar instances -- also for when I need to route servo wires from the wing to the fuselage.
Spackles94 is offline Find More Posts by Spackles94
Old Sep 07, 2008, 11:48 PM
ΜΟΛΩΝ ΛΑΒΕ
USA, KY, Hebron
Joined Dec 2005
here's what I came up with. I used an 1/8" brass tube as a punch to make the holes.
Old Sep 07, 2008, 11:52 PM
War Eagle!
Spackles94's Avatar
Birmingham, Alabama
Joined Feb 2007
Great solution -- it will work well!
You're probably going to be doing this already, but if you can, go ahead and remove the pushrods before covering. It will make your covering job much less stressful.
Journey for a beginning R/C addict soholingo Beginner Training Area (Aircraft-Electric) 842 Apr 03, 2003 11:30 AM
Best covering film for newbie? astroboy Electric Plane Talk 8 Jul 20, 2001 02:59 PM
What Covering To Use for the Chrome on my T33 Joe Elston Electric Ducted Fan Jet Talk 3 May 21, 2001 09:04 AM
covering jobs for zagis barn buster 50 Foamies (Kits) 1 May 04, 2001 08:30 PM
New covering film for light models bipeflyer Parkflyers 6 May 01, 2001 12:49 AM
