Old Nov 09, 2002, 06:16 AM
GUIS is offline
Find More Posts by GUIS
GUIS's Avatar
Canada, BC, Chilliwack
Joined Dec 2000
Knife-edge
How do you do a "knife-edge"? Do you have to have an aerobatic plane to do it?
Guis
GUIS is offline Find More Posts by GUIS
Old Nov 09, 2002, 09:55 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
For proper knife-edge flying you need a model with sufficient fuselage side area (as the fuselage has to provide the lift), a powerful motor and a very effective rudder to control the angle of attack of the fuselage (you also need the appropriate piloting skills, as your rudder takes over the elevator function, your elevator will become your rudder in knife-edge etc. ). It is pretty obvious that some models are better suited than others. Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Nov 09, 2002, 11:15 AM
Norm is offline
Find More Posts by Norm
Oak Harbor, Washington, United States
Joined Jan 2001
If your plane is not capable of full knife edge, you can still do a partial knife edge which looks nice and is a lot of fun. Just start by banking the plane with ailerons and use opposit rudder to keep it going straight, (technically a forward slip). Start your first pass this way using only a little bank, then increase the bank angle on supsequent passses until you reach the limit of your rudder authority to keep the plane going straight.
Norm
Norm is offline Find More Posts by Norm
Old Nov 10, 2002, 05:36 PM
GUIS is offline
GUIS's Avatar
Joined Dec 2000
Thanks Jürgen and Norm
I will try it next time!!
Old Nov 10, 2002, 06:13 PM
William A is offline
Find More Posts by William A
Tacoma, WA, USA
William A's Avatar
United States, WA, Tacoma
Joined Jun 2001
Rudder ? ah yes, the left thumb.
Try as I might though, that sucker just don't like to steer
William A is offline Find More Posts by William A
Old Nov 12, 2002, 07:57 PM
Paul Susbauer is offline
Find More Posts by Paul Susbauer
Balsa Builder
Paul Susbauer's Avatar
United States, OR, Hillsboro
Joined Apr 2001
Learn to fly heli's that will train you. You wind up flying the rudder and not realize it.
Or in normal flying, consciously make your thumb move the rudder, even if you're just jerking it around, then eventually you'll learn to manipulate it to do knife edge and all the other cool stuff (such as hovering) and such.
--Paul
Paul Susbauer is offline Find More Posts by Paul Susbauer
Old Oct 01, 2007, 07:46 PM
Murocflyer is offline
Find More Posts by Murocflyer
Promoting Model Aviation...
Murocflyer's Avatar
United States, CA, Tehachapi
Joined Nov 2005
I know this is old, but know that I have a couple of planes that I can attempt this, the search feature found it. Is there a site that discusses thumb movements to make these aerobatic maneuvers?
Frank
Murocflyer is offline Find More Posts by Murocflyer
Old Oct 03, 2007, 02:09 PM
Trisquire is online now
Find More Posts by Trisquire
Intermediate Multi
Trisquire's Avatar
Columbus, OH
Joined Mar 2005
Higher Plane Productions has a video of a fellow who lost one wing in flight on his IMAC plane. He ended up landing the plane in knife edge with fairly minimal damage. Unbelievable.
Tom
Trisquire is online now Find More Posts by Trisquire
Old Oct 03, 2007, 05:08 PM
Murocflyer's Avatar
Joined Nov 2005
So know one knows a "how to" site that describes thumb/flight control movements to show how these aerobatic movements are made?
Frank
Old Oct 04, 2007, 01:10 PM
wattsup_kz is offline
Find More Posts by wattsup_kz
Frequent Flyer
wattsup_kz's Avatar
Kalamazoo, MI USA
Joined Aug 2003
Here is a site with a few maneuvers clearly shown like that:
http://www.3dbatix.com/?view=videos&page=inst
wattsup_kz is offline Find More Posts by wattsup_kz
Old Oct 04, 2007, 06:11 PM
Murocflyer's Avatar
Joined Nov 2005
Yes it does show some, but I know there has to be a decent "how to" site in all of the whole world wide Internet. At least I have to believe there is anyway. I haven't had much luck in finding one though.
Frank
Old Oct 08, 2007, 12:18 PM
jongi is offline
Find More Posts by jongi
smothered in tradegy
suffolk/england
Joined Aug 2007
wait til you try and figure out rolling harriers and rolling loops
jongi is offline Find More Posts by jongi
Old Oct 14, 2007, 03:22 AM
rofujiyama is offline
Find More Posts by rofujiyama
rofujiyama's Avatar
Big Island,Hawaii
Joined Mar 2005
http://www.rcpilotguide.com/
Here's a link to a book that shows, diagrams and stick positions , for specific manuevers. I havent purchased it , but seems like what you are looking for.
rofujiyama is offline Find More Posts by rofujiyama
Old Oct 14, 2007, 02:52 PM
Intermediate Multi
Trisquire's Avatar
Columbus, OH
Joined Mar 2005
Originally Posted by jongi
wait till you try and figure out rolling harriers.........
I'm trying to tackle those before knife edge. Is that learning things in the wrong sequence?
Tom
Old Nov 06, 2007, 04:43 PM
wylieruneyjr is offline
Find More Posts by wylieruneyjr
Joined Nov 2006
Knife edge is easy! As you fly-by pull the nose up slightly, then roll the plane to edge with the canopy towards you, then push the rudder toward the direction you are coming FROM. If the model tries to not go straight, there are things you can adjust. Plane turns or drags in knife-edge toward the landing gear, typical, Mix-in alittle up elevator as slave to full right AND full left rudder as the master channel, or manual adjust BOTH ailerons down ward alittle. OR if The plane circles toward you in knife edge adjust the opposite as above. If you are good flyer you can just hold a little elevator, up or down durning the stunt to correct, without mixing. Once you learn the knife edge you can fly knife edge circles using the elevator. Remeber while learning this stunt always pull the nose up aprox 5% prior to starting the trick, Later this will not be needed as you will control the up pitch with the rudder. Good luck And its normal to apply the wrong rudder imput sometimes and have the plane dive. If this happens just level your wings and pull out. CANOPY TOWARDS YOU< RUDDER TOWARD WHERE YOU ARE COMING FROM. Flying RIGHT to left Aileron left to stand or bank plane on edge, Rudder to right. Flying LEFT to right Aileron right to edge, and LEFT rudder. This is with the top of plane towards yourself .
wylieruneyjr is offline Find More Posts by wylieruneyjr
IFO--Knife edge anyone?? I FO nut Parkflyers 6 Oct 25, 2002 07:03 AM
E3D Knife Edge Help Ninjak2k Sport Planes 5 Aug 23, 2002 07:02 AM
Diablotin Mini Knife Edge Roll Coupling Matt Fritz Sport Planes 17 May 09, 2002 12:19 PM
Another knife-edge qn stuartaw Competition Aerobatics 7 Feb 19, 2002 10:43 AM
What's the best way to enter a knife-edge? Ben74 Competition Aerobatics 3 Jan 26, 2002 10:25 AM
