Old Jul 09, 2007, 08:24 PM
MailOrderGuy is offline
Find More Posts by MailOrderGuy
Sir Buildsalot
MailOrderGuy's Avatar
Stockbridge, GA
Joined Nov 2002
Video
My 650 Watt TwinJet w/ 2X Mega 16/15/3's can someone doppler for me?
I'm using a 3S2P 4200 Prolite and 4.75x4.75 APC props.
I want to get a idea of what speed I'm getting out of this setup.
Can anyone tell me what thrust each motor is producing??
All the videos are from the same flight, I wanted to give someone with the doppler software a good sampling.
Thanks in advance
MailOrderGuy is offline Find More Posts by MailOrderGuy
Old Jul 09, 2007, 09:16 PM
The Don is offline
Find More Posts by The Don
Park Pilot Mag. Jets Columnist
Willoughby, Ohio
Joined Jan 2002
First video I get about 93 mph and about 25000 rpm.
25000 * 4.75 /1056 = 101 mph pitch speed so 93 is about right.
Pass 2 about 93 mph
Pass 3 about 96mph
Pass 4 about 87 mph
Nice job!
Don
The Don is offline Find More Posts by The Don
Old Jul 09, 2007, 10:01 PM
Sir Buildsalot
Stockbridge, GA
Joined Nov 2002
Many thanks Don
My TwinJet sure turns heads at the flying field.
The glow guys are just amazed at my little electric plane
Old Jul 14, 2007, 10:10 PM
Sir Buildsalot
Stockbridge, GA
Joined Nov 2002
UPDATE
Bought a Bushnell radar gun today from Sports Authority.
The TwinJet was radared at 97 mph on one pass and 95 mph on another, which varifies the data in the earlier post.
Old Jul 14, 2007, 10:56 PM
msmith is offline
Find More Posts by msmith
Use whatcha got!
msmith's Avatar
Metairie, LA
Joined Sep 2000
MOG - how many amps are each motor drawing @ WOT?
thanks,
msmith
msmith is offline Find More Posts by msmith
Old Jul 15, 2007, 07:24 AM
Sir Buildsalot
Stockbridge, GA
Joined Nov 2002
thanks,
msmith
30 amps each
Old Jul 15, 2007, 11:31 AM
msmith is offline
Use whatcha got!
msmith's Avatar
Metairie, LA
Joined Sep 2000
Ugh... too much for my current battery selection...
I'm looking for 30 amps total between the two motors... Am I dreaming here? Or should I just sell the twinjet to someone local?
I'd like to try for a light build and really just use my current batteries... Not necessarily looking for blistering speed, but 50-60mph would be nice if it can be done on 30amps...
-msmith
Old Jul 15, 2007, 03:06 PM
Sir Buildsalot
Stockbridge, GA
Joined Nov 2002
-msmith
No your not dreaming, try this set up,
Two Little Screamer Park Jet motors w/ APC 6x4E props
Two CC ThunderBird 18 amp controllers.
It will keep the weight down alot and give you that 60 mph range you are looking for.
I'm speaking from expeirence, I have a single Park Jet w/ TB18 and 6x4E prop on my Micro Jet, it draws 14-15 amps at WOT.
Old Sep 01, 2007, 05:31 PM
mohillbilly is offline
Find More Posts by mohillbilly
Yep I got another one.
mohillbilly's Avatar
Springfield, Mo.
Joined Jan 2005
-msmith
Easy and cheap! I did it with 2 $6 outrunners, 18A cheap ESC, and a single 2100 3cell 15C pack.
Mo.
mohillbilly is offline Find More Posts by mohillbilly
Old Sep 20, 2007, 09:21 AM
topher39 is offline
Find More Posts by topher39
Cottonwood Arizona
Joined Aug 2003
Fast and Cheap
I put 2 2409-12 motors (1650 kv) running on 7.5 props and they about 30 amps total and the plane does 70mph. If you buy the motors from united they are $9 each, or get them from ebay for $18 each. United even has the motor and controller combo for under $20. Yes really. Been flying this setup for a year now and love it, just about unlimited vertical too. I run on a 3 cell 4000 pack and the weight is a non-issue. Put the controllers on the outside surface of the wing and they stay cool. Fast, thrust, and cheap.
topher39 is offline Find More Posts by topher39
Wanted 2x Mega 16-15-3 or16-16-3 & MiniFans ShaverR6 Aircraft - Electric - Power Systems (FS/W) 0 Dec 05, 2006 07:33 AM
Corona w/ Mega 16/15/3 Power struggle jet_jer Electric Heli Talk 26 May 21, 2003 11:08 AM
Mega 16/15/3 Y So HOT!? w/o prop? YZYgold Power Systems 15 Mar 12, 2003 05:56 PM
Twinjet or f22 and mega 16/15/3 birdseed Foamies (Kits) 0 Aug 13, 2002 02:51 PM
could I run two mega 16/15/3 motors off my white lable 70amp jeti controller joe Electric Ducted Fan Jet Talk 2 Jul 22, 2002 02:26 PM
