Old Jul 08, 2007, 01:28 AM
WATTS2005 is offline
Find More Posts by WATTS2005
Melbourne Aust
Joined Jan 2005
Question
New Hurricane Owner With Questions?
Hello All,
I have just recieved my new Hurricane EP550 from Taiwa (wattupsrc).My next step up from flying the trex450.Would appreciate if someone could answer the following questions below as i am trying to get a better understanding of electronics on this next level of heli.
ESC / BEC HURRICANE
1) Is this correct the following ESC comes with a Bec?(pic attached)
2) If so is this good enough for non hard core flying?
3) What is the recommendation for an external BEC if it is'nt and why?
SERVOS / REC
1)Can some please recommend a good mid range servo for the hurricane?
2) Do you need all digital servo's or just 1x for the tail is enough for non hard core flying?
3) I am currently using a JR X2610 radio with Jr reciever RS77S ,is sufficient for a heli of this size?
Appreciate your response guys !
Cheers,
Watts2005
WATTS2005 is offline Find More Posts by WATTS2005
Old Jul 08, 2007, 06:32 AM
quickster47 is offline
Find More Posts by quickster47
Everyone crashes sometime
quickster47's Avatar
Orlando, FL and Washington D.C.
Joined May 2006
Watts2005,
You might want to check this thread,
http://www.rcgroups.com/forums/showthread.php?t=607690,
for tons of information on the Hurricane and I do believe, in fact, that all your questions are answered in the thread.
However, if your kit is a recent one then your ESC probably does not have a built-in BEC and you should have received a separate BEC with your kit.
And the Hurricane EP550 in its stock configuration is excellent for just loafing around yet can do some of the basic stuff, loops, rolls, and such.
Good mid range digital servo would be the Futaba S3151. Economical and perform quite well. Why skimp here and get regular old servos.
For the tail you definitely want digital and the sort of defacto standard is the Futaba GY401 gyro and S9254 servo.
http://www2.towerhobbies.com/cgi-bin...&I=LXFZP2&P=ML
The nice thing about this heli is that you have lots of choices. Not sure where you got yours from but ReadyHeli.com is very active in the Hurricane market and are working on quite a few nice mods.
Carl
quickster47 is offline Find More Posts by quickster47
Old Jul 08, 2007, 06:44 AM
Larren is offline
Find More Posts by Larren
Flying Is Fun
Larren's Avatar
Malaysia
Joined Sep 2004
Hello WATTS2005.
The ESC which you have is without a BEC. You need a seperate BEC.
Mild 3d will not be a problem even with the normal model (without any upgrades).
I am running mine with normal servos.
The 2610 is just good enough but I am not sure if it has the gyro sensor adjustment for GY401.
Larr.
Larren is offline Find More Posts by Larren
Old Jul 08, 2007, 06:50 AM
Melbourne Aust
Joined Jan 2005
Thanks Carl for the update.
And will check out those links out.Although I'M 100% sure there was no seperate bec supplied which made me think maybe the ESC has an in built Bec? Could this be possible ? The site i bought my Hurricane from has no mention of a Bec.
The following is whats listed on the site.
Hurricane 550 PRO
●The Lightest-weight medium-sized EP helicopter.(Gas power 30 ~ 46 class)
Flying weight 1950g.
●1000W(KV800) external brushless motor , 50A(25V) ESC are all included in kit.
●Factory built partly metal upgraded.
●The best power to weight ratio gives excellent 3D capability .
●The cheapest battery cost.( 2 packs 3S1P in series, even your stock batteries for 450 EP heli work fine)
●Multi-stage gear reduction system results in a streamline cabin and canopy.
●Push-pull linkages on ECCPM system limits any play for sharp control response.
●Dupont plastic and fiberglass composite main frame.
●Precision CNC anodized aluminum swash plate.
●Fully equipped ball bearings.(43 bearings)
●Seesaw head with bell-hiller system.
●Only a short time needed for completion. (90% factory assembled)
●Belt driven tail rotor.
●Extensive CNC upgrade parts and option parts available.
Specification:
●Overall length: 1060mm (including cabin & canopy)
●Main rotor diameter: 1110mm
●Main blade length: 475~550mm
●Tail rotor diameter: 222mm
●Flybar paddle: 84*45*6mm
●Tail blade length: 80mm
●Overall height: 305 mm
●Overall width: 85 mm
●Motor: KV800 external brushless motor (included)
●ESC: 50A/25V (ESC included)
●Flying weight: 1950g (It may vary according to size of a battery pack and R/C gears.)
●Main rotor blades: wooden 500mm(included) or fiber(option)
●Flying duration: 6~8 minutes with 11.1v/2200mah Li-Po battery 2 packs in series(22.2v)
Items needed for assembly:
●6 (or more) channel heli-capable transmitter (with CCPM function)
●4 servos (digital servo is recommended)
●6 (or more) channel receiver
●Gyro (heading hold gyro is recommended)
●Battery : 2 packs of Li-Po batteries (11.1v/2200mah )
●Charger: Li-Po battery charge
Old Jul 08, 2007, 06:55 AM
Melbourne Aust
Joined Jan 2005
Hello Larren,
Thanks for you advice on ESC/BEC,just replied to Carls then saw yours had arrived.
Any recommendations on BEC? Eventually i will be doing 3d stuff but not for a while.Its winter here in AUST and lost alot of flying time.
Cheers,
WATTS
Old Jul 08, 2007, 10:01 AM
Steve990 is offline
Find More Posts by Steve990
Birmingham Intl, Great Britain (UK)
Joined Jul 2004
I ordered mine from Infinity Hobby and it also came without a BEC. I'm using a spare 3A Align BEC that came off of my Trex 600 when i fitted the new Align 6A BEC, it should be more than up to the job as it managed for 11 months on a Trex 600
Steve990 is offline Find More Posts by Steve990
Old Jul 08, 2007, 10:57 AM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
I still run a regular 4 cell pack on some helis. I like BECs when run off the main pack. I can't see the reason for a separate rx lipo pack and a BEC for that??????????
FB
Fred Bronk is offline Find More Posts by Fred Bronk
Question New F5D pilot with questions GregG High Performance 43 Feb 15, 2008 04:20 AM
Discussion brand new CP2 owner with questions glgaglros Micro Helis 39 Feb 15, 2007 01:03 AM
new tmaxx owner with a few questions kidynomike Off-road Cars 4 Jun 06, 2005 08:35 AM
New member to forum with questions :D shuohan Beginner Training Area (Aircraft-Electric) 8 Apr 16, 2002 03:26 PM
Litestik questions for a New Stik owner =) jayboy Parkflyers 2 Jan 19, 2002 09:49 AM
