Old Jul 07, 2007, 08:36 PM
firetrappe is offline
Find More Posts by firetrappe
Build 2 Bounce!
Birmingham, UK
Joined Jul 2006
Build Log
Sumo 3D - Free Plans, Build Guide and Video
A number of people expressed an interest in my latest EPP scratchbuild, so I thought I’d start a new build thread. For anyone that’s interested in building a Sumo 3D I’ll list the basic order of construction and techniques that worked for me.
Specs :
Wingspan : 25½”
Length : 22”
AUW : 6.2oz (including 2S300 lipo @ 24g)
Setup:
Motor : KH257 17T (soon to be 1500kv HXT Blue Wonder)
Prop : GWS 8043 sf
Servos : 3x Bluebird 306
Rx : Spektrum AR6100
Esc : Castle Creations TB9
Sumo 3D - Backyard testing (3 min 18 sec)
Sumo 3D - Park Flying (3 min 43 sec)
Build Guide in PDF format by RdJay : http://www.rcgroups.com/forums/showa...mentid=1542927
Micro Sumo
Specs :
Wingspan 20"
AUW : 92g (3.25oz)
Setup :
3x BA3.6 servos
1x Spektrum AR6100 rx
1x 1811-2000 motor (https://www.unitedhobbies.com/UNITE...?idProduct=5358)
1x HW 6A esc (https://www.unitedhobbies.com/UNITE...?idProduct=4318)
1x gws 7035 prop
1x 2S300 lipo
Micro Sumo 3D - Backyard flying (4 min 41 sec)
Micro Sumo Combat (1 min 53 sec)
firetrappe is offline Find More Posts by firetrappe
Last edited by firetrappe; Dec 21, 2007 at 05:34 AM. Reason: Micro plans and videos added
Old Jul 07, 2007, 08:41 PM
Build 2 Bounce!
Birmingham, UK
Joined Jul 2006
Build Details
1. Print the plans, check the scale is correct and tape the pages together using the first page of the plans to help.
2. Cut the parts out of EPP. I managed to cut all the parts out of 2 sheets of 6mm x 35.5” x 11.5” EPP. The pictures below show that the wing and h/stab were cut in 2 sections and later joined at the aileron hinge line.
3. Cut 45° bevels the full length of the aileron hinge line, elevator hinge line and rudder hinge lines (upper and lower halves of the fus). Then cut bevels in the ailerons, elevator halves and rudder to match. Check the photos in the first post to make sure you bevel the correct side of each surface.
4. Glue 3mm x 0.5mm carbon fibre strips to the bevels you cut on the wing, h/stab and rudder.
5. Join the 2 elevator halves together by gluing another strip of 3mm x 0.5mm carbon along the bevels (use the h/stab to get the spacing between the 2 halves right). Use a length of .032 diameter music wire (I used wire from a Dubro micro pushrod system) to further reinforce the elevator halves. If you look at the photo below you will see it goes from the t/e tip of one elevator half to its l/e root, is bent to follow the hinge line and then bent again from the other elevator l/e root to its t/e tip. The wire is taped to the top surface of the elevator to spread the load put on it during vertical takeoffs.
6. Using strapping tape, create the hinges between the elevator and h/stab and the ailerons and wing.
Old Jul 07, 2007, 08:42 PM
Build 2 Bounce!
Birmingham, UK
Joined Jul 2006
7. Join the wing and h/stab sections together at the aileron hinge line. I cut another bevel in the h/stab section to mate with the bevel already cut in the aileron hinge line. Yes, the bevels shorten the overall length of the horizontal part of the fuselage but not enough to matter.
8. Glue the upper half of the fuselage to the horizontal section making sure that the prop slots are aligned. I marked and cut holes in both sections for the aileron servo before gluing to make life easier later on. Notice that the hole in the wing is twice the width of the servo so that it can be easily fitted (or removed) once the model is complete. Keep the piece of foam you cut out to plug the hole once the servo is fitted.
9. Fit the motor mount tube. I found it best to do this with the motor and prop attached, you don’t want to come to fit the motor and realise the mount is in the wrong place! Aim to position the mount so that the prop will be central to the slot, if the prop bends in flight it’s going to bend backwards, so if it ends up towards the front of the slot it’s better than towards the back. I didn’t build in any down or right thrust and it seems to fly fine.
Old Jul 07, 2007, 08:44 PM
Build 2 Bounce!
Birmingham, UK
Joined Jul 2006
From this point onwards I did most of the build using 2 stacks of old VHS tapes to hold the model upside-down.
10. Fit the Dohyo (sumo ring ). Whatever you find or make to use as the prop protector ring the inside diameter needs to be larger than the length of the prop slot (8.5”). Some great ideas for rings in the original thread here : http://www.rcgroups.com/forums/showthread.php?t=703113 . You’ll have to measure the outside diameter of the ring you’re using and cut identical notches in both prop slots so that the ring can be recessed. Take your time with this bit, the ring needs to keep its shape. Having the motor and prop mounted at this stage lets you use the prop to check the distance between the tips of the prop and the edge of the ring are as equal as possible in all positions. Once you’re happy then glue the ring in place.
11. Glue the lower half of the fuselage to the model. Depending on the type of ring and glue you’re using it may be easier to combine this stage with the last one to keep everything aligned properly. Make sure the prop slots, ring and rudder hinge line up nicely. It’s more important that these line up than the nose of the model, you can tidy the nose up later if necessary.
Old Jul 07, 2007, 08:48 PM
Build 2 Bounce!
Birmingham, UK
Joined Jul 2006
12. Hinge the rudder. This is done using tape as with the ailerons and elevator. You can fold the elevator back out of the way to make things easier. Check that there is enough clearance between the fuselage and the rudder for the elevator to move freely, trim some foam away where the h/stab and v/stab cross if necessary. Once the rudder is hinged you can gently stand the model on its tail, if the rudder sticks out too much for it to sit nicely then you may need to trim a little off the t/e of the rudder.
13. Strengthening the model. You’ll notice at this point that the model is very flexible. To make it more ‘crash resistant’ and prevent the model twisting from the torque of the prop during vertical takeoffs some additional strengthening is required. The weakest part of the model at this point is the join just behind the aileron servo. To improve this I added a strip of 2” wide x 5” long crossweave tape starting at the rear edge of the prop slot on both sides of the upper fuselage. I then added lengths of 1” wide filament tape from the rear of the prop slot to the rear of the fuselage on all four intersections. Two 9” lengths of 1mm c/f rod were pushed through the horizontal part of the fuselage in line with the t/e of the wing and taped to either side of the fuselage to further reduce flex. A length of 1.5mm c/f rod was similarly pushed through the lower part of the fuselage infront of the motor mount and taped to the underside of the wings to reduce wing twist. 1” wide filament tape was also applied to the edges of the prop slots to prevent the foam tearing in the event of a prop-strike. Finally, to prevent the EPP tearing on less than perfect landings I cut several lengths of filament tape to 6mm wide, these were applied around the edges of the fuselage and nose area.
Old Jul 07, 2007, 08:50 PM
Build 2 Bounce!
Birmingham, UK
Joined Jul 2006
14. Fit control horns. I used Dubro micro control horns glued to 1/64th ply (slofly method) to increase the horn’s contact area with the foam. Any lightweight horns will suffice, just make sure to glue them directly to the foam (peel back hinge tape) and ensure the pivot point between the control rod and horn falls directly over the hinge line.
15. Install servos and pushrods. The servos for the rudder and elevator can be positioned anywhere along the centreline of the fuselage. I positioned mine close to the aileron servo to try and keep all the weight as close to the centre of gravity as possible (cog 1” back from the prop seems to work well for me). With my existing setup this allows me to use lipo packs up to about 30g (~1oz), if you intend to use heavier packs then I’d recommend installing the servos further back. I used Dubro micro pushrods and EZ connectors for the pushrods. The elevator and rudder pushrods are 1.5mm c/f rods.
16. Install Rx and Esc. The Rx is attached to the side of the fuselage below the servo cluster with strapping tape. A 12” servo extension was then used to connect the Rx to the Esc. The Esc is attached to the nose of the model on the same side as the Rx with the battery lead passing through to the other side of the fuselage. You can then attach Velcro to the side of the fuselage to secure the battery.
Happy Building!
FT.
Old Jul 07, 2007, 10:05 PM
Bill Bergman is offline
Find More Posts by Bill Bergman
Houston, Tx.
Joined Jan 2003
Do you have the plans in a non-tiled version?
Bill Bergman is offline Find More Posts by Bill Bergman
Old Jul 08, 2007, 02:05 AM
pawnking is offline
Find More Posts by pawnking
pawnking's Avatar
Clovis, Ca.
Joined Apr 2007
Thanks Firetrappe Made my weekend! I will start in the morning... O.. it's all ready morning LOL! Jim
pawnking is offline Find More Posts by pawnking
Old Jul 08, 2007, 04:12 AM
MrFlash is offline
Find More Posts by MrFlash
Flashmeister Aviation Inc
MrFlash's Avatar
Joined Aug 2005
Superb job as always FT . Those graffx are killer !!
Is this going to be the prototype for future FT VPP designs
MrFlash is offline Find More Posts by MrFlash
Old Jul 08, 2007, 05:09 AM
leadfeather is online now
Find More Posts by leadfeather
Winging it Ò>
leadfeather's Avatar
Joined May 2006
What a fun airplane! Flys great and looks virturally indestructable!
It's not too hard to envision several of these "Sumo wrestling" indoors or in a back yard.
Posted a link to your thread in the new epp thread.
Domo oragato Firetrappe-san
leadfeather is online now Find More Posts by leadfeather
Old Jul 08, 2007, 05:36 AM
JimW is offline
Find More Posts by JimW
North Kent, England UK
Joined Jan 2005
FT, Now that's what I call a backyard flyer, how do you rate the Spectrum?
Cannot make up my mind to spend ther money yet.
JimW is offline Find More Posts by JimW
Old Jul 08, 2007, 07:36 AM
Build 2 Bounce!
Birmingham, UK
Joined Jul 2006
Thx guys
Bill, I've just added full sheet plans to the first post for you.
Flash, not sure about a VPP sumo, but there is a new VPP design being discussed in Ewo's Amos thread
Dan, I hadn't though of 'Sumo Combat'..I might have to build another one for Flash just to try it out
JimW, It's early days with the Spek system for me but so far I really like it. Flash and myself got a good deal from a supplier in the US that was too good to miss compared with the UK prices.
Old Jul 08, 2007, 09:06 AM
Houston, Tx.
Joined Jan 2003
Thanks, firetrappe !!
by the way, just naiden my 3DI. It flew great. I'll post more on that thread.
Old Jul 08, 2007, 06:02 PM
marriola is offline
Find More Posts by marriola
marriola's Avatar
United States, WY, Jackson
Joined May 2007
Thanks, just waiting for the EPP I ordered to get here.
marriola is offline Find More Posts by marriola
Old Jul 08, 2007, 08:27 PM
rcallison is offline
Find More Posts by rcallison
Foam Wannabe
Joined Nov 2005
Question on your bracing technique FT,
The carbon rods that are just in front of the hinge line for the ailerons and elevator, did you glue these on? Or are they just placed there and taped over with the hinge tape?
Thanks.
Ron
rcallison is offline Find More Posts by rcallison
Build Log Infineon EPP Bipe - Free Plans, Build Guide and Video firetrappe Foamies (Scratchbuilt) 8710 Jul 14, 2016 08:07 PM
Build Log "STS" Seaplane/Airplane Free Plans, Build Guide and Videos! WaterDog Foamies (Scratchbuilt) 828 Jan 21, 2016 08:01 AM
Build Log “BigNasty” Full fuse, full wing. Free Plans and Build Guide. WaterDog Foamies (Scratchbuilt) 969 Dec 27, 2015 05:55 PM
Build Log Fly the “NASTY”! Free Plans, Build Guide, and Videos WaterDog Foamies (Scratchbuilt) 1545 Nov 23, 2015 04:56 AM
"BIGNASTY" Full fuse, full wing. Free plans, Build Guide. WaterDog 3D Flying 0 Aug 16, 2005 10:31 PM
