Old Nov 08, 2002, 03:16 PM
CactusJackSlade is offline
Find More Posts by CactusJackSlade
Whadda YOU lookin' at?
CactusJackSlade's Avatar
United States, CA, Folsom
Joined May 2002
Question
Cirrus CS-21BB Sub-Micro HP servos - OPINIONS?
Anybody have any good/bad feedback on the Cirrus CS-21BB Sub-Micro HP servos?
My brother seems to be having problems with them not centering and buzzing, it then drains the Rx battery... but he is not sure it's the servos.
Any comments about these servos?
Thanks!
CJS
CactusJackSlade is offline Find More Posts by CactusJackSlade
Old Nov 08, 2002, 05:47 PM
TFLG is offline
Find More Posts by TFLG
TFLG's Avatar
United States, CA, Riverside
Joined Feb 2002
I tried several of the cirrus servos and found them all to be very poor in quality. Not centering was one of the worst problems I had with them. Excessive slop was another irritating problem with them. I have not tried the CS-21 but every other one I tried ended up in the garbage can.
By the way on the one's I had a problem with the centering I discovered it was a problem with the pots moving inside the case. They were only held in place with a small dab of glue which would come loose and allow the pots to move causing the servo center position to continually change.
They're cheap but they're cheap!
TFLG
TFLG is offline Find More Posts by TFLG
Old Nov 08, 2002, 08:00 PM
bjaffee is online now
Find More Posts by bjaffee
Brett
bjaffee's Avatar
So Cal
Joined Apr 2002
I've been using 21BB's for the v-tail of my Mini Acacia. The plane is DS'ed quite often, and so far the servos remain very tight and seem to center fine (this after about 6months).
bjaffee is online now Find More Posts by bjaffee
Old Nov 08, 2002, 09:35 PM
SchiessCo is offline
Find More Posts by SchiessCo
SchiessCo's Avatar
North Hills
Joined Nov 1999
I've had very good luck with CS-21's over the years, though I've never used them in anything real fast or heavy. I've had mixed luck with other Cirrus servos.
Pete
SchiessCo is offline Find More Posts by SchiessCo
For Sale 2 cirrus cs-301 9g micro servos The Snake Aircraft - General - Radio Equipment (FS/W) 0 Aug 06, 2006 12:38 AM
Wanted CIRRUS CS-4.4 Micro Servos old_dude Aircraft - General - Radio Equipment (FS/W) 1 Apr 20, 2006 10:23 AM
FS: 2 Cirrus CS-21BB servos PalouseFlyer Aircraft - Electric - Airplanes (FS/W) 1 Sep 04, 2004 06:25 PM
Question Cirrus CS-21BB Sub-Micro HP servos - Good or Bad?? CactusJackSlade Hand Launch 3 Nov 11, 2002 02:47 PM
Pair of FMA S80 sub micro BB servos $33 shipped! funfly Aircraft - Electric - Airplanes (FS/W) 1 Jul 29, 2002 08:08 PM
