Old Jul 07, 2007, 04:25 PM
Geode is offline
Find More Posts by Geode
Geode's Avatar
San Jose, CA
Joined Jan 2007
Project Rays - Hyperbolic Manta
Here is the twin brother of Manta DLG .....
Geode is offline Find More Posts by Geode
Old Jul 07, 2007, 04:29 PM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Construction
- Manta DLG wing planform with reduced chord
- Hyperbolic wing bending
- Conventional balsa build-up wing with diagonal ribs
- Balsa pod with CF rod re-enforcement
- Full flying bagged tail feathers
Control - rudder/elevator
Vitals
Span - 59 in
Area - 361 sq in
Mass - 8.0 oz (8.4 oz after CG trimming)
Loading - 3.35 oz/sq ft
Old Jul 07, 2007, 06:04 PM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Maiden
Maiden pictures .....
Old Jul 08, 2007, 06:16 AM
kimhey is offline
Find More Posts by kimhey
kimhey's Avatar
nøtterøy, NORWAY
Joined Mar 2006
I just love that wing!
Kim
kimhey is offline Find More Posts by kimhey
Old Jul 08, 2007, 12:41 PM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Hi Kim, hope you getting better now and thanks for your nice words.
Some heat gun works on wing tips to get the washout matched for left/right wings and set it ready for harder launch.
I use AG04~AG10 (6.4%~4.7% thickness) airfoils and narrower chord this time. AG04 family is really slippery at current wing loading. Should be getting better launch height. Stay tuned ....
Old Jul 08, 2007, 01:33 PM
ajroahkni is offline
Find More Posts by ajroahkni
PWP!
ajroahkni's Avatar
USA, HI, Makawao
Joined Oct 2002
Oh my, it's beautiful! You are an artist!
ajroahkni is offline Find More Posts by ajroahkni
Old Jul 08, 2007, 07:34 PM
Rogo is offline
Find More Posts by Rogo
High Planes Drifter
Rogo's Avatar
Joined Oct 2006
Very nice!
How was the wing bent - during or after spar/rib construction?
Rogo is offline Find More Posts by Rogo
Old Jul 09, 2007, 01:33 AM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Spar, LE and TE are roughly pre-bended on a hyperbolic shaped jig. The final wing planform is assembled on another jig to have all the components aligned precisely.
Geode
Old Jul 09, 2007, 01:37 AM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Launch Video
Very good weather today for launch trimming. Rendy's launch is true and straight. The launch height is also pretty good. I estimate the launch height most likely greater than 120 ft.
See video for detail ......
Hyperbolic Manta DLG - Part II (1 min 36 sec)
Old Jul 09, 2007, 03:09 PM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
I'm very impressed by the range of AG04 family. It works very nicely on MDLG as well as on 60" DLG. It's a very slippery airfoil. The lauch height is pretty good, very easy to get back from down-wind and still thermal very very well.
I did a quick comparison on AG04 vs. AG12 (popular airfoil for 60" polyhedral DLG's). It doesn't seem to have any major differences between the two. Am I missing something?
Geode
Old Jul 09, 2007, 03:17 PM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Flight Video
Another video clip .... thermal on softball field. Hope you enjoy.
Video
Old Jul 09, 2007, 08:10 PM
kostuk is online now
Find More Posts by kostuk
Joined Nov 2003
Hi Geode,
Really great version!
What thickness/width of carbon are you using on the spar?
Also I was'nt able to run your videos.
Great job!
Ray
kostuk is online now Find More Posts by kostuk
Old Jul 09, 2007, 08:43 PM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Spar is similar to Manta 1/4" x 1/16" spruce with additional CF of 1/4" wide and 0.007" thick (this CF is supposed to be used for rib cap instead of the spar).
Seems like it's corrupted during upload. Will reload the video again. Thanks.
If it is still not working, try this http://video.google.com/videosearch?q=hyperbolic+manta
Old Jul 09, 2007, 09:43 PM
PWP!
ajroahkni's Avatar
USA, HI, Makawao
Joined Oct 2002
Geode - could you share some photos/information of jigs and forming curves with wood/carbon/spars and d-boxes?
John
Old Jul 09, 2007, 10:07 PM
Geode is offline
Geode's Avatar
San Jose, CA
Joined Jan 2007
Wing Jigs
Sure, no problem. These jigs are pretty simple to made.
First one is for bending the wing LE/TE and spar. This is cut out of foam. All the LE, TE and spar go into this for a "rough" pre-bending.
The second jig is made out of balsa. This jig has all the angles for each and every rib. Precision is important for this jig to get all the angles right.
I cut the Dbox into two pieces (15" each) just to make the bending easier.
Build Log Project Rays - Manta Geode Hand Launch 646 Feb 04, 2016 10:05 AM
