Old Nov 08, 2002, 01:28 PM
sizam is offline
Find More Posts by sizam
sizam's Avatar
Mountain View, CA
Joined Aug 2002
Futaba Super 8U, is it true it either works high _or_ low band?
I have a Futaba Super 8U that came with a chan. 45 module, I've used it at 48 as well. I'm thinking of getting another module but heard that the Tx is set to be used in the upper _or_ lower end of the band and the cut-off is around 35, is that true?
sizam is offline Find More Posts by sizam
Old Nov 08, 2002, 01:36 PM
MattLarson29 is online now
Find More Posts by MattLarson29
Endangered User
MattLarson29's Avatar
United States, FL, Casselberry
Joined Jul 2002
Futaba's receivers are split into a "high" and "low" band, but the module in the transmitter contains all the RF circuitry, so you can plug in any 72 Mhz module and be fine.
Matt
MattLarson29 is online now Find More Posts by MattLarson29
Old Nov 25, 2002, 03:24 PM
sizam is offline
sizam's Avatar
Mountain View, CA
Joined Aug 2002
I see, so the Tx can do any channel, its the Rx that is limited. What about Hitec and FMA receivers? I have a superslim, is that also high OR low band? If so can I change it?
Old Nov 25, 2002, 03:56 PM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
So far I've only seen Futaba split their Rxs up into high/low band. Every other manufacturer seems to be able to cover the entire range (unless someone knows better ).
Steve
steve lewin is offline Find More Posts by steve lewin
Sold Futaba R149DP PCM Receiver 72mhz works either high or low bands - HOT DEAL ssrobzoom Aircraft - General - Radio Equipment (FS/W) 1 Feb 19, 2007 11:44 AM
Sold Futaba FP-R127DF 7 ch dual conversion rx low band chuckpee Aircraft - General - Radio Equipment (FS/W) 0 Oct 04, 2006 09:40 PM
For Sale Futaba FP-R148 DF FM Micro 8 Ch High or Low band DPage Aircraft - General - Radio Equipment (FS/W) 1 Jan 09, 2006 02:58 PM
badly need a 35mhz module for my futaba super 8u spectra will work rcaddition Aircraft - General - Radio Equipment (FS/W) 2 Dec 23, 2004 10:13 AM
high or low band??? gch Radios 1 Dec 13, 2003 11:46 AM
