Old Jul 05, 2007, 07:30 AM
Fly2High is offline
Find More Posts by Fly2High
Chuck 'Em and Chase 'Em
Fly2High's Avatar
United States, NY, Plainview
Joined Aug 2005
1/4 wavelength calculation and antenna length
Guys,
I was looking to determine what length my broken antenna should be (since I did not measure it before hand and the manufacturer has given me a range of lengths to work with).
I noticed that somewhere it was said the the median 1/4 wavelength is 39.75 inches which should be for about channel 36 plus or minus.
When I did the following calculation (knowing that speed of light = wavelength x freq -> c/freq = wavelength)
I did the following :
299,792,458 metres per second /freq(Hz) = meters * (100cm/ 1m) *(1in/ 2.54cm) to get the wavelength in inches * 1/4 = 1/4 wavelength in inches
ex ch 30 = 72.390 mHz = 72,390,000Hz
299792458 / 72,390,000 *100 /2.54 * 1/4 ~ 40.76 inches
channel 36 should be about 40.69 inches
why is this wavelength LONGER than what it is stated to be for the median 1/4 wavelength?
Based on this equation, ch 55 is ~ 40.48 inches
Can anyone tell me where I went wrong???
Frank
Fly2High is offline Find More Posts by Fly2High
Old Jul 05, 2007, 12:18 PM
bobthenuke is offline
Find More Posts by bobthenuke
70 is the new 50
bobthenuke's Avatar
United States, AZ, Peoria
Joined Feb 2005
Frank,
Since the frequency range for the USA and Canada is Channels 11 - 60 the median number would be a split between Channels 35 and 36. If your math is correct, then the value you quoted for the median antenna length (check on it again) is probably incorrect. Keep in mind that anything even "close" to the calculated numbers will work just fine for us. I do, however, understand your desire to get it right on.
...bob
bobthenuke is offline Find More Posts by bobthenuke
Old Jul 05, 2007, 12:26 PM
Vulture is offline
Find More Posts by Vulture
Looking for lift...
Milford, NJ
Joined Mar 2005
If I just measure an existing un-altered antenna, would that give you what you need. (I'm too lazy to do the math)
Doug
Vulture is offline Find More Posts by Vulture
Old Jul 05, 2007, 12:44 PM
F3X is offline
F3X
Find More Posts by F3X
F3X
F3X's Avatar
Joined Jun 2001
http://www.csgnetwork.com/freqwavelengthcalc.html
Go here.
F3X is offline Find More Posts by F3X
Old Jul 05, 2007, 01:28 PM
Fly2High is offline
Fly2High's Avatar
Joined Aug 2005
the claculator returned for 72.390 (ch 30) 40.779 inches. I was off by just a little
Still this doesn't make sense that they would use 39.75 inches..
Frank
Old Jul 05, 2007, 02:28 PM
IBWALT is offline
Find More Posts by IBWALT
W0X0F
IBWALT's Avatar
Joined Nov 2005
Frank, inside of your rx there is a coil with a threaded ferrite plug that can be screwed in and out. This coil is used to fine tune the antenna to the exact electrical length. In theory the antenna could be any length and the coil if it were the right size could make up the difference. However in the case of your rx the antenna is cut to an approximate length and then tuned with the coil. Just solder on a piece of wire to approximate the original length of the antenna or send it back to the manufacturer and have the antenna replaced and the rx re-tuned.
IBWALT is offline Find More Posts by IBWALT
Old Jul 05, 2007, 03:11 PM
Fly2High is offline
Fly2High's Avatar
Joined Aug 2005
You are probably right, Walt. I didn't take that into concideration. Maybe the antenna length is dependant on the ferrite plug. that may be why I read that the length is shorter than it should be.
thanks
Frank
Discussion Berg 4 Antenna Length Question Rickochet Castle Creations 2 Feb 18, 2007 05:18 AM
Question 1/4 wave receiving antenna hargard DIY Electronics 1 Apr 21, 2006 03:03 AM
WTB Full length 1/4 scale sailplane pilot Ian Noble Aircraft - Sailplanes (FS/W) 0 Feb 21, 2004 01:44 PM
Question Antenna length on GWS 4 channel reciever AudioTweaker Micro Helis 10 Sep 01, 2003 02:05 PM
Anyone do the E-conversion on Air Foil Aviation's 1/4 scale powered parachute? EFoil Electric Plane Talk 0 Jul 23, 2001 05:35 PM
