Old Nov 07, 2002, 01:09 PM
etbadger is offline
Find More Posts by etbadger
UT, USA
Joined Mar 2001
First scratch-build
Well, here is the progress so far on my first scratch-build. I'm guessing it will be ready to fly in a month or two (I'm slow).
60" wing span and 1 year of work so far.
Drive system should be 10 2400 sub-C's into a Kyosho Endoplasm in a custom built gearbox (had to learn how to use the milling machine & lathe... Must be the most expensive gearbox out there)
Outlines are based on plans by Adrian Paige, but the internals are a fair bit different.
Still need to mount the electronics (other than the embedded aileron servos) and lay-up the wheel-pants.
-eb
etbadger is offline Find More Posts by etbadger
Old Nov 07, 2002, 01:10 PM
etbadger is offline
UT, USA
Joined Mar 2001
Top
Old Nov 07, 2002, 01:33 PM
Paul Susbauer is offline
Find More Posts by Paul Susbauer
Balsa Builder
Paul Susbauer's Avatar
United States, OR, Hillsboro
Joined Apr 2001
Very nicely done, I can't wait to see her in full race config. Can you post a pic of your gearbox. I"m sure everyone would love to see it.
--Paul
www.oldschoolrc.com
Paul Susbauer is offline Find More Posts by Paul Susbauer
Old Nov 07, 2002, 01:39 PM
etbadger is offline
UT, USA
Joined Mar 2001
Well, here is a front view. I don't have a pic with me of the gearbox itself. I'll try to remember to take one tonight.
-eb
Old Nov 07, 2002, 02:51 PM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Stunning! All the best with flying her.
You're in good company here - Keith Shaw, Adrian Page (though his prototypes are all glow powered), and Greg Gimlick spring to mind as those who've tamed this flying barrel.
I still haven't plucked up courage enough to electrocute the Page Aviation GeeBee Z kit, let alone the 60" R2
Good luck
Dereck
Dereck is offline Find More Posts by Dereck
Old Nov 07, 2002, 11:11 PM
etbadger is offline
UT, USA
Joined Mar 2001
Here are a couple pics of the gearbox I just took. It was my first try at making anything of significant substance on the mill, so it isn't so pretty, but I learned a bit, and it seems to run smoothly.
-eb
Old Nov 07, 2002, 11:12 PM
etbadger is offline
UT, USA
Joined Mar 2001
And another view...
Old Nov 07, 2002, 11:19 PM
etbadger is offline
UT, USA
Joined Mar 2001
I have been severly chastised for failing to mention that this was a joint project of my WIFE and I. She did a lot of the original work cutting out stringers, frames, ribs, etc., as well as helping plot out the masking for the paint scheme.
Now perhaps she will stop hitting me...
-eb
Old Nov 18, 2002, 11:57 PM
etbadger is offline
UT, USA
Joined Mar 2001
Another week of cruddy weather, and we have decals, striping, cowl, and final painting done. Only thing left to do is make the wheel-pants.
Top right:
Old Nov 18, 2002, 11:59 PM
etbadger is offline
UT, USA
Joined Mar 2001
And the left side view:
Old Nov 19, 2002, 10:11 PM
mrittinger is offline
Find More Posts by mrittinger
Gravity sucks.
mrittinger's Avatar
United States, MI, Roseville
Joined Dec 2000
Very nice.You have big cajones doing an r1/r2!
How many watts are you pulling and what do you plan to do about a prop? (pitch/dia?)
I hear the rep as a hard ship to fly is undeserved other than a high landing speed, IE: bring it in with some real grease!
Good Luck
Mark
mrittinger is offline Find More Posts by mrittinger
Old Nov 20, 2002, 11:06 AM
etbadger is offline
UT, USA
Joined Mar 2001
Hi Mark,
Computer predictions have it pulling about 450 watts static. I don't have a watt meter, so I can't verify this (current gear ratio of about 6.2:1).
The prop on currently is a 16x10 APC, though, if I can, I would also like to try out an 18x12 (don't have one yet) as I would like to have more of the prop outside of that fuselage.
-Erik
Old Nov 20, 2002, 01:58 PM
KOMET 44 is offline
Find More Posts by KOMET 44
D.G.B.
KOMET 44's Avatar
Southington, Connecticut, United States
Joined Jun 2000
ERIK,you should buy a watt meter.BEST insurance one can have. What is the weight of the plane rite now?? .Good luck with the test flights.stefanP
KOMET 44 is offline Find More Posts by KOMET 44
need power system advice for first scratch build eran_k Foamies (Kits) 1 Jan 19, 2005 03:25 AM
Depron Biplane - My first scratch build pjsmith The Builders Workshop 0 Jun 28, 2004 05:30 AM
My first scratch build plane - MT1 tomx Parkflyers 14 Mar 28, 2003 04:59 PM
first scratch build help coolhand Electric Ducted Fan Jet Talk 7 Feb 13, 2003 02:46 PM
My First Scratch build, what do you think? MailOrderGuy Parkflyers 2 Feb 07, 2003 11:59 AM
