Old Nov 07, 2002, 11:36 AM
TMP00283 is offline
Find More Posts by TMP00283
Redmond, WA
Joined Nov 2002
BEC == Voltage Regulator?
OK, finally received my Voyager, Hacker B40 + Kontronic controller. Reading the Kontronic manual, it says not to use the BEC for cell count of 9 or 10 (which is what I want to run on).
Can I make a BEC out of a voltage regulator?
Specs from a radioshack voltage regulator (from RS site)
"Overload protected. Rated 1 amp (heat sink required). 35VDC maximum input. TO-220 case. Type: 7805; Output: +5VDC"
Also, I hear of a ultimate BEC, uBEC. What does this provide over my idea of building a BEC with a RadioShack regulator?
Thanks in advance!
-Andy
TMP00283 is offline Find More Posts by TMP00283
Old Nov 07, 2002, 12:34 PM
jaggies is offline
Find More Posts by jaggies
"Watch this!" SMACK!
jaggies's Avatar
Mountain View Moffett Fd, California, United States
Joined Apr 2001
Yep. Most BECs are just 5V regulators.
Although you can use a linear regulator (7805), you need one that can handle more watts. The problem is that if the difference in the regulated voltage (5V) and the supply voltage (12-16V) is too high, the regulator will overheat and shut down. That's why they put a restriction on the number of cells on BECs.
The UBEC uses a much more efficient regulator and doesn't have this problem.
If you want to use a linear regulator, get a beefier one (3A) and be sure to put a good heat sink on it.
BTW, I use a separate 1050mAh NiMH battery on my Voyager.
--jim
jaggies is offline Find More Posts by jaggies
Old Nov 07, 2002, 01:59 PM
GKurt is offline
Find More Posts by GKurt
Chicago
Joined May 2002
Homemade linear reg
If you want to build a linear regulator yourself, here's some instructions; http://www.ikarus-modellbau.de/ubbth...b=5&o=&fpart=1
Greg
GKurt is offline Find More Posts by GKurt
Old Nov 07, 2002, 02:27 PM
onsj is offline
Find More Posts by onsj
MD
Joined Feb 2000
Andy,
Yes, you can make one. I will be making one from R.S. 7805 (+5V) with the heat sink and two capacitors. I have not yet eitch the pc board; but, I have design a layout on the computer already. It should handle the micro to mini servos plus the receiver without a problem. If you are looking at a higher voltage +6V, use the LM7806.
I am also looking at making the 3A switching voltage regulator.
This is more efficient but, the parts are higher in cost. I don't have the parts yet.
Steve
www.erols.com/onon
onsj is offline Find More Posts by onsj
Old Nov 07, 2002, 02:46 PM
K.C. is offline
Find More Posts by K.C.
Victim of Gravity
K.C.'s Avatar
Cary, NC
Joined Sep 2001
For ten cells, at 1A, you'll have about 5-7W of loss in a linear regulator. That's quite a bit in a TO-220 package unless it has good heatsinking. As Jim suggested - use one with a higher current limit and a higher junction temp rating. And HEATSINK IT. If the regulator shuts down, you'll lose your Rx response.
The UBEC uses a switching supply, which provides better efficiency - probably 80-85%, versus the 30-50% you'd get with a linear supply.
I've designed a 3A (continuous) switching supply for my e-Raptor 50. It's still on paper now, but I'll have the parts and PCB's in a week or so. Aside from the 3A of Rx power, it also provides 0.5A @ 12V for a motor cooling fan. I even added the circuitry to switch the 12V on and off from the Tx. I don't know why I'd want to turn off the cooling fan, but I figured it'd be neat to have the option. Plus - maybe I can power something else from that 12V output on another model. I'll have 9 PCB's, so I'll certainly be able to build more than one of these. I'm anxious to get my "enhanced" BEC together and test it. It oughtta work, since I design power supplies for a living!
KC
K.C. is offline Find More Posts by K.C.
Old Nov 07, 2002, 03:20 PM
TMP00283 is offline
Redmond, WA
Joined Nov 2002
Thanks for all the info
So it looks like I'll suffer from inefficiency with Radioshack regulators. I'd hate to suck up battery power just to heat up a heat sink.
So, to servos work consistently with different voltages (assuming enough current) on their power leads? i.e. is the turn rate different at 4.5 vs 5V?
-Andy
Old Nov 07, 2002, 03:42 PM
Steph280 is offline
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
KC,
Any chance of you publishing your design or selling it as a kit for those who likes to tinker?
Stephen
Steph280 is offline Find More Posts by Steph280
Old Nov 07, 2002, 06:15 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
With a simple BEC, you don't need a CB. Just mount the reg's to a heatsink and solder on the wires and caps.
If you want a really nice BEC, check out the UBEC at
http://www.koolflightsystems.com/ultimatebec.htm
Fred Bronk is offline Find More Posts by Fred Bronk
Old Nov 07, 2002, 07:03 PM
K.C. is offline
Victim of Gravity
K.C.'s Avatar
Cary, NC
Joined Sep 2001
I have a completed schematic, bill of materials and PCB layout - I just need to order the boards and parts, which I'll probably do on Monday. Thus by the following week I should have a board together and running.
Once I'm sure the design works properly (which I'm confident that it will), I'll publish the design for all you electronics geeks out there. There's not much to it really - a couple of buck supplies, some logic, ESD & surge protection and some filtering to mitigate conducted emmissions and susceptibility. And I managed to fit it all onto a 1.1" x 2.5" 2-layer board.
In addition to publishing schematics & such, I'll also be willing to sell off some of the raw PCB's (boards with no parts on them). I have to order a minimum number, so I'll have some extras. I've etched my own boards in the past, but got tired of the hassle. Now I prefer to let someone else make the boards now.
KC
Old Nov 07, 2002, 07:09 PM
Steph280 is offline
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
Count me in on the PCB, I will try to build a couple.
Thanks.
Stephen
Old Nov 07, 2002, 09:41 PM
K.C. is offline
Victim of Gravity
K.C.'s Avatar
Cary, NC
Joined Sep 2001
As soon as I've tested my BEC out, I'll post about it.
And I'll save a couple of PCBs for you, Stephen...
KC
Old Nov 07, 2002, 09:53 PM
Hippo is offline
Find More Posts by Hippo
The effect is sadly temporary
Hippo's Avatar
Ann Arbor, Michigan
Joined Oct 2001
You guys are doing it the hard way...
Just buy an extra GWS 2 Amp speed control. (They're really cheap, and only weigh 2 grams...) Then just cut off the motor lead. That's it. Done. BEC in one step.
I guess I'm just lazy.
-Dan
Hippo is offline Find More Posts by Hippo
Old Nov 07, 2002, 10:04 PM
Hoverup is offline
Find More Posts by Hoverup
2013 GRAND SPORT CORVETTE
Hoverup's Avatar
Golden Gulf Coast
Joined Jul 2002
Dan - Seems like the most elegant solutions are often the simplest things right under our noses. Sounds like a great idea. Good on you.
Cheers - Boyd
Hoverup is offline Find More Posts by Hoverup
Old Nov 07, 2002, 10:13 PM
Pierre Audette is offline
Find More Posts by Pierre Audette
RPV builder & operator
Pierre Audette's Avatar
Canada, QC, Gatineau
Joined Jan 2001
Nice try Hippo, but the GWS ESC can only take up to 8 cells.
Pierre Audette is offline Find More Posts by Pierre Audette
Old Nov 07, 2002, 10:18 PM
Hippo is offline
Hippo's Avatar
Ann Arbor, Michigan
Joined Oct 2001
Oops.
I guess I should read things a little closer before I open my big mouth.
Sorry.
Good Luck,
-Dan
Voltage regulator as BEC? Tuomas Pietinen High Performance 1 Mar 10, 2002 06:32 AM
7.2-7.5V Voltage regulator Bleriot Power Systems 4 Dec 13, 2001 12:22 AM
Source for RX pack voltage regulator Ben Diss Power Systems 13 Jul 24, 2001 09:35 AM
Voltage Regulator wtghost1 Electric Ducted Fan Jet Talk 3 Jun 23, 2001 11:08 AM
