Old Nov 06, 2002, 09:25 PM
SheldonYoung is offline
Find More Posts by SheldonYoung
SheldonYoung's Avatar
Vernon, BC, Canada
Joined Jan 2001
Ultracote around concave curves
Does anybody have any good ideas for getting Ultracote around the inside of a concave surface? The top wing of the SIG Smith Miniplane, a .40-size conversion, has a notch and I have no experience covering such a shape.
Some good shots of the top wing are at http://paulsplanes.fws1.com/smithminiplane.htm
SheldonYoung is offline Find More Posts by SheldonYoung
Old Nov 07, 2002, 09:57 AM
ICTHRMLS is offline
Find More Posts by ICTHRMLS
aka: Dances with Buzzards
ICTHRMLS's Avatar
TX
Joined Jun 2002
My technique uses a soft leather glove (chamois style or one of the Monokote Mitts) and a heat gun. It is hard to describe but you need to shrink the covering slightly before pressing it in place. Attach one end to a smooth/flat surface and work towards the concave curve. Working side to side heat and press the covering in place with the gloved hand. When you get to the curve you need to heat sufficiently to see the covering shink/pucker then press while still warm. Keep working side to side along the concave surface. Practice on some scrap first and it really helps if the surface is anchored/clamped in order to use both hand freely. Hope this helps........
ICTHRMLS is offline Find More Posts by ICTHRMLS
