Old May 24, 2001, 11:23 PM
sf_247 is offline
Find More Posts by sf_247
Austin, Texas USA
Joined Mar 2001
NEW CP-2400SCR versus RC2400
OK. Here we go: http://www.eflightpower.com/cp_rc_2400_1.htm
<img src="http://www.eflightpower.com/media/tests/CP2400_vs_RC2400_comp.gif" width="573" height="638">
These are 8 cell packs at about 10 amps. Higher amps will be used for more testing, about 20. The AF 112D charger puts about 2800 mah in them at 3.6 amps current.
The same charger at the same current and same discharge load was used on all tests.
Very interesting, eh. Almost identical, and so far better, than the RC2400 we have tested. These are 2 packs of the RC2400 and 2 packs of the CP-2400SCR, charged/discharged at least 5 times.
Shawn
Eflightpower.com
sf_247 is offline Find More Posts by sf_247
Old May 25, 2001, 07:15 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I'd like to see 30 and 40A curves.
..a
Old May 25, 2001, 08:10 AM
Ralph Weaver is offline
Find More Posts by Ralph Weaver
Ralph Weaver's Avatar
Indianapolis, IN USA
Joined Nov 2000
Here's 20A. At 20A, the RC2400 is 4.4mOhm, the CP-2400SCR is 5.3mOhm. This difference will show up more at higher currents.
I've got 35A done, I'll post it tonight.
See complete data at www.magtechinc.net/Cells.htm
Ralph Weaver is offline Find More Posts by Ralph Weaver
Old May 25, 2001, 10:04 AM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
500A and real 500AR test the same at 5A, but 500A completely falls apart at 10A. Don't even bother running the 500A at 15 or 20A which the 500AR would tolerate well.
A curve at 30-40A is much more realistic.
Greg
gkamysz is offline Find More Posts by gkamysz
Old May 25, 2001, 04:03 PM
sf_247 is offline
Austin, Texas USA
Joined Mar 2001
Well, here is the curve for 2 CP and 2 RC packs for 25 amps. I do not think that the second CP pack peaked correctly, it was not as warm as the others. 35 AMP tests will be coming tomorrow.
<img src="http://www.eflightpower.com/media/tests/cp_rc_25amp.gif" width="515" height="517">
Shawn
Eflightpower.com
[This message has been edited by sf_247 (edited 05-25-2001).]
Old May 25, 2001, 06:14 PM
sf_247 is offline
Austin, Texas USA
Joined Mar 2001
Here are the results for 35 amps. I ran a 180 second test at 35 amps for each pack. The packs were peak charged on an AstroFlight 112D at 3.6 amps. All I can do is post the data. This is very interesting.
RALPH- Interesting how you got such different results. Were the RC2400 cells you used "zapped" or "matched" ?
<img src="http://www.eflightpower.com/media/tests/cp_rc_35.gif" width="515" height="517">
Shawn
Eflightpower.com
Old May 25, 2001, 07:33 PM
jsc is offline
jsc
Find More Posts by jsc
jsc
Where does it all end?
Boise/Nampa Idaho
Joined May 2000
What type of equipment are you guys using to do these tests, and what type of software, and URL's? Thanks
Jeff
jsc is offline Find More Posts by jsc
Old May 25, 2001, 08:23 PM
sf_247 is offline
Austin, Texas USA
Joined Mar 2001
Jeff-
The discharger I am using is a battery dump made from a bunch of auto light bulbs. One is a 10 amp, and the larger I borrowed from a local RC car shop. I took a test to get the amp draw, and the numbers seem to confirm it is about 25 amps. In parallel, the add up to 35 amps.
I am using a quality multimeter with an RS232 serial output hooked up to a laptop that takes one voltage readings every second.
That data is imported into an excel spreadsheet and graphed. The graph is what you see.
Fun stuff.
Shawn
Eflightpower.com
Old May 25, 2001, 08:32 PM
jsc is offline
jsc
jsc
Boise/Nampa Idaho
Joined May 2000
Thanks Shawn, I have a rs232 Multimeter, Craftsman, When you coming up to Waco to do some e-flying?
Jeff
Old May 25, 2001, 08:43 PM
sf_247 is offline
Austin, Texas USA
Joined Mar 2001
Soon, Jeff.
I got the Twinstar finished last week and have been having a blast with it. I have been looking at that Ripmax/Scorpio Spitfire that Hobby Lobby has for a next plane. Not that the Twinstar is boring, I couldn't be happier with it. But it is what it is, and I am feeling the need for something a little more advanced. About 8 flights and no crashes so far. I must be doing something wrong!
I know that there is some shareware out there for RS232 output if you do not have the software.
I am in the middle of also doing Sanyo 1600 NIMH VS. 600AE discharge at 10 amps. You should see the kitchen counter. The "misses" ain't pleased.
Take care.
Shawn
Eflightpwoer.com
Old May 25, 2001, 09:18 PM
sjslhill is offline
Find More Posts by sjslhill
Joined Jan 2001
We are matching these after a zap and we are seeing the following at 20 amps: Turbo Matcher 4
CP2400SCR
410-430 runtime
1.120-1.140 Average Voltage
IR 30+
R/C 2400's
420+
1.130-1.170
IR <28
Overall the R/C is a better cell but the CP will cost less.
Steve
http://sjslhill.hypermart.net
[This message has been edited by sjslhill (edited 05-25-2001).]
sjslhill is offline Find More Posts by sjslhill
Old May 25, 2001, 09:28 PM
sjslhill is offline
Joined Jan 2001
These graphs can be misleading, we have Sanyo 3000 NIMH cells at over 500 seconds at 20 amps. Different date codes produce different numbers.
Old May 25, 2001, 09:39 PM
sf_247 is offline
Austin, Texas USA
Joined Mar 2001
Hmm. All I know is that these are the numbers I am getting from a major cell supplier that we use. They just came in as soon as the supplier got the batch. I am suprised to say the least, maybe pleasantly suprised. I am not sure what to think. Especially since RALPH has such different results.
RALPH - What date codes do you have? Your CP are not performing anywhere as well (comparitively) as the RC2400 that you have.
Shawn
Eflightpower.com
Old May 25, 2001, 09:47 PM
sjslhill is offline
Joined Jan 2001
Our CP's are FD on the outside and EK on the inside. EK was a great date for R/C 2400's. The test samples of CP2400's were much better but so far these are not as good. I really think that these are very close to being the same. We will need to see more cells. I have another case coming in next week, maybe it will be a different date code.
They are still good cells....it's just that R/C 2400's so far to us are better.
Shawn
Eflightpower.com
Old May 25, 2001, 10:01 PM
sjslhill is offline
Joined Jan 2001
need to add CP2400
F/S: 2 New 10-CP-2400SCR Battery Packs Cuda Aircraft - Electric - Airplanes (FS/W) 2 Oct 20, 2004 08:28 AM
FS; New CP Hornet Kit rck Aircraft - Electric - Airplanes (FS/W) 0 May 11, 2002 02:05 PM
For Twinjet: CP 1700scr cells vs. cp 2400scr vs. RC3000NiMH erashby Foamies (Kits) 15 Feb 07, 2002 09:40 AM
CP-2400SCR 10 cell pack will not fast charge? rsieminski Power Systems 8 Jan 05, 2002 04:39 PM
CP 2400SCR Cells sjslhill Aircraft - Electric - Airplanes (FS/W) 1 Oct 04, 2001 02:16 PM
