Old Jun 29, 2007, 10:05 PM
Munch is offline
Find More Posts by Munch
El Cajon, CA, USA
Joined Feb 2001
Question
Effect of air temp on engine power
So I left San Diego earlier this week and went to Phoenix to visit a friend. I put hawk up in the air and it was super gutless. Now mind you it's never got much power (OS .32) but this was rediculous. The thing could barely get outta its own way.
The temp was up over 110 and I know that effects power since less oxygen is in each stroke and poor heat dissipation but I didn't think it would be THAT bad.
I know....I need to move up to a .37. That will happen quite soon.
Just curious what you guys think of power and heat.
Munch is offline Find More Posts by Munch
Old Jun 29, 2007, 10:11 PM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Two problems - less power from the motor and less lift from the blades.
Also SD is more or less at Sea level , Phoenix about 1100 feet.
More nitro and/or a bigger motor
Pat MacKenzie
pmackenzie is online now Find More Posts by pmackenzie
Old Jul 06, 2007, 08:14 PM
ben1101 is offline
Find More Posts by ben1101
Joined Aug 2006
The hotter air is, the more water vapor it contains, which lowers its density which gives your engine and blades less air to bite into, which equals less power.
ben1101 is offline Find More Posts by ben1101
Old Jul 06, 2007, 11:12 PM
Andrew McGregor is offline
Find More Posts by Andrew McGregor
Christchurch, New Zealand
Joined Jun 2006
Not quite... water and temperature are separate problems (although there can be a lot more water in hotter air, I bet there wasn't in Phoenix).
Andrew McGregor is offline Find More Posts by Andrew McGregor
Old Jul 07, 2007, 12:02 PM
Munch is offline
El Cajon, CA, USA
Joined Feb 2001
All I know is that the thing was running pretty dang hot until I richened it up. Then the power fell and it was difficult to maintain headspeed while doing much of anything.
My .37 arrived yesterday. About stinking time. I've been cheap and pushed that .32 to the limit. I'm tired of gimping around.
Thanks guys
Daniel
Old Jul 08, 2007, 12:46 PM
ben1101 is offline
Joined Aug 2006
Hi Andrew, do you mean to get your density altitude?
Old Jul 08, 2007, 06:05 PM
Joined Jun 2006
Density altitude first, and then correct for humidity (I forget the correct name for that).
Old Jul 08, 2007, 08:34 PM
archiebald is offline
Find More Posts by archiebald
Kamikaze Heli Pilot
Japan
Joined Jul 2005
This document may be of interest
http://www.raptortechnique.com/highaltitude.htm
archiebald is offline Find More Posts by archiebald
Old Jul 10, 2007, 02:23 AM
ben1101 is offline
Joined Aug 2006
Been 3 years since CPL Met
Question Atmospheric effect on Engine noise level Marion Modeling Science 9 Jul 14, 2007 01:37 AM
Is there an Engine FS forum on RC Power? rcgreaves Engines 1 Mar 30, 2005 07:42 PM
Need advice on what to power scratch Air Tractor with? Boba_Fett Parkflyers 17 Jun 24, 2002 10:21 PM
Air Brakes on the Kranich dr.E Electric Sailplanes 5 Jul 26, 2001 03:34 PM
