small hovering design using coaxial rotor with fixed props
I would appreciate some feedback on a very small hovering airframe using coaxial fixed blade rotors (no cyclic or collective) powered by brushless motors. Props will be in the range of 10-12" diameter, with total aircraft height of less than 8", and total weight, including electronics and battery less than 9-oz (250-gm). I plan to control lateral movement either with steerable aerodynamic surfaces or weight shifting once hovering issues are resolved.
I've built a couple of prototypes using the HiMax CR2816-1100 brushless coaxial motors ( http://www.nesail.com/detail.php?productID=5429 ) with 12" and 13" APC props. These motors are much heavier than what I plan to use, but they were available, and I've since located some smaller coaxial pairs which should be here soon. In any case, I can get airborne, but have not achieved stable hover. I think the main problem at the moment is top-to-bottom weight balance, but it seems that others here have worked with this type of design, so I welcome any comments / suggestions. Here are some photos of the prototypes. The first one was quite unstable, but the second one showed some promise. My thought is to nest the bottom motor in the airframe to lower the center of gravity. Also, it would be nice to find a cleaner way to stow the electronics. |
Update ...
Neither lowering the props toward the airframe or changing to smaller props seemed to improve matters. My sense is that large props and a low CG will prove to be a better combination, e.g. (from http://www.grc.nasa.gov/WWW/K-12/TRC...elicopter.html ) I'll move back to my earlier configuration, and do more work on balancing the load. |
Interesting ... there's a nice historical article about the Hiller Flying Platform here - http://www.howtoadvice.com/Sky-High - and the videos are impressive. However, there's a noteworthy quote in the article -
i look forward your finished project and I will give as much help as I can !well.. I have made a lot of research around the mid 50s HIller platform and about its unquie stability and I can tell you that after what i have read that the human NO WAY can control the stability simply by the human reaction which would be too slow and result in flipping teh platform=the platform had a natural static stability from a "gyroscopic procession" which I honestly dont get exactly but the stability is a result of two main things: 1. the intake lip around the shroud increased teh stability, so evry time the tube tilted a little the intake on that side would be much faster and do more thrust=and right the tube up again 2. the pilot standing up on the platform made a better balance due to a HIGH CG!!(which i still thing sounds strange but true) sooo what I have read is going against my experinces a little. cuz as you know having a low CG should have a "pendulum balancing effect" but no, this is not teh case here strangely.. you can chsck this my post about hiller platform http://www.rcgroups.com/forums/showthread.php?t=701480 |
I believe the stability you are observing with the Hiller-style platform is mostly due to "in ground effect" hover - see
http://cybercom.net/~copters/aero/ground_effect.html Note that this effect is observed when the blades are fairly close to the ground, as shown here - ![]() As the blades get closer to the ground, there's more air pressure which results in more lift which forces the blades back to a horizontal path. However, as the blade height increases, the ground effect is reduced. Unfortunately, ground effects don't help with my application - I need to hover well above ground level and carry a downward-looking camera. However, it's useful to consider all possible design ideas in hopes that there is a "magic bullet" in achieving hover stability. |
yeah thats right! mate but anyway it is stilll a little strange design in my own view, so the main stability is coming from teh pilot reactions plus teh ground effect or shroud shape and ground effect,, I think you should if you want and I would also lovely see a mini copy of teh hiller, so take your time and shape a good duct and inverse teh motors so teh props are facing down,, sometimes the testing is the only way to go mate !
| Thread Tools | |
| Idea Airframe design suggestions for small coaxial rotor craft ? | hg1 | Coaxial Helicopters | 1 | Jun 29, 2007 01:01 PM |
| Update on Hex Coaxial Rotor with flying vids | Krox | Coaxial Helicopters | 14 | Oct 24, 2005 05:16 PM |
| Update on Hex coaxial rotor heli with flying vids | Krox | Electric Heli Talk | 5 | Oct 13, 2005 10:50 AM |
| Fixed Props with Kontronik gearbox | ModelTony | Kontronik | 9 | Jul 08, 2004 06:44 AM |
| Using an ESC without Brake Disable with A Fixed Non Folding Prop/ Safe? | Joe Elston | Electric Plane Talk | 4 | May 10, 2001 10:35 PM |
