Old Jun 29, 2007, 02:06 PM
WBFlyer is offline
Find More Posts by WBFlyer
WBFlyer's Avatar
Portland, OR
Joined Feb 2007
need the best omni directional antenna for receiver
need the best for max signal. I use the future hobbies setup and need to know the connector type as well. I think I need a polorized patch possibly.
WBFlyer is offline Find More Posts by WBFlyer
Old Jun 29, 2007, 02:53 PM
PeteSchug is offline
Find More Posts by PeteSchug
PeteSchug's Avatar
Elmhurst, NY (Queens in NYC)
Joined Apr 2004
Patch and omnidirectional are mutually exclusive.
Pete
PeteSchug is offline Find More Posts by PeteSchug
Old Jun 29, 2007, 03:39 PM
WBFlyer is offline
WBFlyer's Avatar
Portland, OR
Joined Feb 2007
somebody her said to get a polorized patch 3bdi or something and lay it on the ground flat.
Old Jun 29, 2007, 06:07 PM
Wmacky is offline
Find More Posts by Wmacky
United States, FL, Middleburg
Joined Dec 2006
Get this with a SMA male connector...Done!
http://sharperconcepts.zoovy.com/c=c.../YSC-HG2409PCR
Wmacky is offline Find More Posts by Wmacky
Old Jun 30, 2007, 03:01 AM
WBFlyer is offline
WBFlyer's Avatar
Portland, OR
Joined Feb 2007
perfect. thanks!
Old Jun 30, 2007, 11:20 PM
Mangus is offline
Find More Posts by Mangus
Mangus's Avatar
United States, WA, Seattle
Joined Dec 2006
What's the diff between right-hand, left-hand, and plain circular polarization?
Mangus is offline Find More Posts by Mangus
Old Jul 05, 2007, 05:44 PM
MtnGoat is online now
Find More Posts by MtnGoat
Tu ne cede malis
MtnGoat's Avatar
United States, WA, Lyle
Joined Dec 2000
Circular has one of two possible directions (L or R hand) and the first two examples are merely specific about the direction.
MtnGoat is online now Find More Posts by MtnGoat
Old Jul 05, 2007, 06:31 PM
Mangus is offline
Mangus's Avatar
Joined Dec 2006
Right. It should also be mentioned, however, that you can suffer a 3dB (or more) loss with mismatched polarity. In general, vertical to vertical and horizontal to horizontal are best. Circular with vertical is OK if you're alright with losing a bit of gain to pay for more consistency. In general you shouldn't mix LH with RH circular polarity, however it's not so much of an issue for us, since our Tx antennas are vertically polarized (again, generally).
Old Jul 05, 2007, 07:32 PM
Tu ne cede malis
MtnGoat's Avatar
Joined Dec 2000
Yup, cross polarizing circulars R to L or vice versa blows big time.
I used a circular polarity RX system for a bit (vertically polarized omni on plane) and liked the result, it was more stable at various aircraft attitudes compared to running Vpol Tx to Vpol Rx.
At 200mW output the 3db initial mismatch wasn't noticeable because the antenna I was using was an 8 dB unit to start with. In any event, since I wanted more solid performance with respect to aircraft attitude onboard a slope glider, I found it acceptable.
I didn't care for the pattern of the circ pol antenna I had however (I hate aiming antennas, this was a directional, 8db feed element from a dish antenna) so I got a wifi plus "Multipolarized" omni from work and that's been my standard.
I don't know what they're doing in there but it works at different angles better than the Vpol whip standard with any Rx and it doesn't have the initial cross pol loss the circular patch does.
It's very omni and doesn't care what angle the airplane is. I added a 12dB LNA with a 1.5dB noise figure, and an ISM band cavity filter to the receive chain...my 200 mW system now gets me way farther away than I'll ever need.
The antenna was a little spendy new, luckily we use them at work, I just fished one out of the dumpster and it was OK. Ditto for the LNA and filter, which are *real* spendy. Sometimes jobs are handy to have for more than one reason!
Wi FI plus omni
They also have a tiny thumb sized antenna for this band (they call it the Bullet), I have one in the lab but I've never tried it out.
Old Jul 05, 2007, 09:13 PM
jimmy sparks is offline
Find More Posts by jimmy sparks
jimmy sparks's Avatar
Melb. Australia
Joined Jul 2006
Well this interests me.
I have placed an order with Future Hobbies which is in transit. I ordered the Diversity RX and Wade recomended getting two circular polarized patch antennae (left & right, which aren't on the FH website yet) over the standard linear ones. The circular polarized ones have a beam width of approz 65 degrees both vertical and horizontal, whereas the linear only have 35 degrees vertical.
Can someone explain the best way to set these up. I assume they would be best set apart (1 foot will probably be my set up), and aimed so they have a bit of overlap in their horizontal beam coverage. Is this right?
Also is it possible to use one standard dongle (is this a whip?) antenna and one patch?
I'm new to this and this is my first system and can't find much info on using 2 circular polarised antennae, so any advice would be great.
cheers
Andrew
jimmy sparks is offline Find More Posts by jimmy sparks
Old Jul 07, 2007, 10:24 AM
Melb. Australia
Joined Jul 2006
Can no one help me here?
Don't mean to be pushy or anything.
Discussion I need the best omni-directional antenna WBFlyer FPV Talk 2 Apr 11, 2007 11:59 PM
Omni-directional antenna for bit-tx? Angry_Monk Scratchbuilt Indoor and Micro Models 4 Aug 12, 2005 04:05 PM
Directional Antenna for Cobra Walkie-Talkie uscra112 DIY Electronics 11 May 25, 2005 05:13 PM
I need help to DIY flywire antenna for 36 MHZ RX GoodHeli Radios 5 Aug 24, 2003 08:05 PM
Who makes the best rubber ducky antenna for transmitters? PDX Slope Pilot Radios 6 Sep 19, 2002 09:39 AM
