Old Jun 28, 2007, 09:57 AM
YarSmythe is offline
Find More Posts by YarSmythe
RCRoundtable.com
YarSmythe's Avatar
United States, TX, Cypress
Joined Nov 2003
Build Log
Funder & Lightning
Welcome to the official build thread of the Funder & Lightning!
I designed and built this plane back in 2005. I'm a big fan of the Lockheed P-38 Lightning and wanted to build a similar flying model out of foam. The plane is very simple to build, light on the wallet for parts, and is a blast to fly!
This thread has TONS of photos & helpful ideas to help you along. To get you started quickly, here are some popular sections in this thread. If you have additional questions, you are welcome to send me a private message here on RC Groups.
Enjoy!
CONSTRUCTION LINKS:
Beginner Frequenty Asked Questions:
Q: What skill level is required to fly this aircraft?
A: I believe this design is meant for intermediate builders/pilots. However, a few folks out there have built this as their first plane and have succeeded. You should probably have some time flying a high-wing trainer before attempting to fly a plane this small and fast...and without landing gear.
Q: How many channels is this plane? Does it have rudders?
A: This is a 3-channel aircraft: Ailerons, Elevator, and Throttle. You do not need rudders to fly this aircraft.
Q: Can I buy this kit online?
A: At this time, the kit is not for sale through any retail outlet. However, I am looking for a vendor to market/package/sell this aircraft. Until then, you should print out the PDF plans and give it a try. Many new pilots say it is not a difficult plane to build.
Q: Can I use arrow shafts or CF tubing for the booms?
A: Yes you can. I prefer using basswood or spruce as it keeps the pieces 'true' and provides a larger surface area for glue.
Q: What motor do you recommend?
A: The market is flooded with 400 sized brushless outrunner motors. You have many choices and combo options. Most of us agree that a 400 size outrunner motor with a KV rating of 1000-1400 turning an 8"-9" prop is an appropriate match.
In the beginning, most of my planes were built using the Hobby Lobby 400XT 900Kv motor. It allowed you to run a larger prop (9-10") and fly at slower speeds. My favorite right now is the BP 2212-10 1400kv motor. I use one on my "Yellow Jacket" and it flies great. That, and it only costs $16!! Use a GWS 8x6" HD black prop.
Q: Where do I get the foam?
A: DOW FFF can be difficult to locate (Lowe's Hardware is a good starting place). It typically comes in a huge block of several foam sheets hinged together like an accordion (thus, fan FOLD foam). You can build 10-15 planes out of one pile. Midwest Cellfoam 88 and Depron are similar and can usually be found at your local hobby shop. I prefer CF88 but it is a bit expensive. Other people recommend paper covered foam sheets available at Hobby Lobby Crafts and Dollar Tree.
Q: What glue should I use?
A: You could assemble the entire plane with foam safe CA. I recommend using a stronger glue (epoxy or Gorilla Glue) when attaching the booms to the wing and tail. Hot Glue is another option but since it sets quickly, it isn't recommended. Hot Glue IS good for attaching servos to the foam.
VIDEOS:
Funder & Lightning - "The Joker" (2 min 25 sec)
Funder & Lightning - "Honey Bunny", 11/2011 (2 min 16 sec)
Funder & Lightning - "Honey Bunny" (3 min 24 sec)
Funder & Lightning - Yellow Jacket (2 min 27 sec)
Funder & Lightning Demonstration Video (1 min 28 sec)
Funder & Lightning - Original Design (2 min 55 sec)
** New Video of F&L #4, Orange Bang
** Video of F&L #2, Yippee!
PHOTOS:
YarSmythe is offline Find More Posts by YarSmythe
Old Jun 28, 2007, 10:00 AM
RCRoundtable.com
YarSmythe's Avatar
Joined Nov 2003
Original build of the Funder & Lightning
Here are the pics from my original design of the Funder & Lightning:
Old Jun 28, 2007, 10:04 AM
RCRoundtable.com
YarSmythe's Avatar
Joined Nov 2003
Video
Here is the first video I made using this setup.
Funder 'n Lightning Video - WMV file @ 34MB (high quality)
Funder 'n Lightning Video - WMV file @ 10MB (low quality)
Enjoy!
Old Jun 28, 2007, 10:06 AM
RCRoundtable.com
YarSmythe's Avatar
Joined Nov 2003
Dimensions
The wing is pretty much based on the Blue Funder design. I've rounded the edges....but that's about it. I still use the double-layer leading edge and a carbon fiber rod (arrow shaft) for a spar.
*** NOTE *** In version 2.0 of the plans, we increased the depth of all control surfaces to 1.5". This provides a much better roll rate.
Old Jun 28, 2007, 10:13 AM
RCRoundtable.com
YarSmythe's Avatar
Joined Nov 2003
Here are some notes about my latest version, F&L #2, Yippee!
Setup:
- Hobby Lobby 400XT outrunner
- APC 8x6SF / GWS 9x5 HD
- Thunder Power 3S 1320 LiPo
- E-flite 20 amp speed controller (fits very well on the side, no loose cables)
- DX7 w/AR6100 receiver
- (3) Hitec HS-55 servos
Notes:
- Instead of Dow Blue FFF, I opted for Midwest CellFoam 88 - 5mm sheets. It is smoother, a bit stiffer, and regular CA seems to work just fine. Painting it was a breeze!
- Because I am not "rolling over" FFF for this wing (see the Blue Funder build thread), I purchased a piece of balsa leading edge stock to fit on the front of the wing. This not only keeps the wing stiff, but adds more strength the leading edge to fight off dings and rough landings!
- I use CA on small joints and Gorilla Glue on the main joints. You need strong glue on the spar, motor mount, vertical pieces, and tail booms.
- I'm using hot-glue to keep the servos in.
- The booms are 1/4" x 3/8" basswood.
- The motor mount shaft is 3/8" square basswood.
- The motor mount is an E-flite square mount. Only two screws fit the back of the 400XT, but that's all she needs. I like this better than a flat piece for a radial mount.
...oh, did I tell you she's fun to fly??!!
Old Jun 28, 2007, 10:15 AM
68Strat is offline
Find More Posts by 68Strat
68Strat's Avatar
United States, MA, Andover
Joined Jun 2004
I like it!
68Strat is offline Find More Posts by 68Strat
Old Jun 28, 2007, 10:20 AM
praymond is offline
Find More Posts by praymond
praymond's Avatar
New Hampshire-seacoast area
Joined Jun 2005
Man that flies smooth!! Where is the CG point??
praymond is offline Find More Posts by praymond
Old Jun 28, 2007, 10:26 AM
RCRoundtable.com
YarSmythe's Avatar
Joined Nov 2003
Directly under the carbon rod. Roughly 2.5" inches.
Old Jun 28, 2007, 10:35 AM
praymond is offline
praymond's Avatar
Joined Jun 2005
Cool, thanks. Is that KF step undeer the wing???? I'm cutting out one of these next
Prop on your Esskay???
Old Jun 28, 2007, 10:45 AM
RCRoundtable.com
YarSmythe's Avatar
Joined Nov 2003
KF step?? Not sure what you're asking.
Right now I fly the 400XT with an APC 8x6SF prop but will be trying out a 9x5 GWS HD prop soon. Someone recommended I try the HD prop which might give me better performance.
Speaking of performance:
- AUW: 12.6 ounces
- WOT: 12.5 (w/APC 8x6SF)
- Thrust: 13.9 ounces
12.5 amps exceeds the recommended power consumption from the 400XT. Supposedly the 9x5 GWSHD will bring it down to 11 amps.
Old Jun 28, 2007, 10:59 AM
praymond is offline
praymond's Avatar
Joined Jun 2005
Kline-Foggleman Wing foil, there's been a lot of builds with it, it's a steped foil, either on top or under the wing. Here's one thread on it, not only wing type planes but convertional mono and bipe planes too. http://www.rcgroups.com/forums/showthread.php?t=558321
Ya the 9050 is the ideal prop for a esskay, 20+ oz at 10+amps. the liter the plane the less the WOT amps are in the air.
Old Jun 28, 2007, 11:03 AM
RCRoundtable.com
YarSmythe's Avatar
Joined Nov 2003
I have never heard of the "KF wing foil"...but, to answer your question, yes, there is a 'step' in the wing. The first 2.5" are double layered (10mm), under the wing. The rest is 5mm to the trailing edge.
Old Jun 28, 2007, 11:27 AM
webdragon is offline
Find More Posts by webdragon
glider pilot in training
webdragon's Avatar
United States, AR, Searcy
Joined Aug 2006
I'm pretty sure i'm not the only one out here that has tried a pusher prop f&L.
So how about some pics?
http://static.rcgroups.com/forums/at...anes%20003.jpg
webdragon is offline Find More Posts by webdragon
Old Jun 28, 2007, 11:29 AM
kimhey is offline
Find More Posts by kimhey
kimhey's Avatar
nøtterøy, NORWAY
Joined Mar 2006
Real Sweet!!
Kim
kimhey is offline Find More Posts by kimhey
Old Jun 28, 2007, 12:51 PM
frankyfly is offline
Find More Posts by frankyfly
frankyfly's Avatar
Italy
Joined Sep 2004
My compliment Yars, that's a nice little "boomer".
I want to build one ASAP.
Franky
frankyfly is offline Find More Posts by frankyfly
Discussion Funder & Lightning SPAD Edition maybeso SPAD - Simple Plastic Airplane Designs 3 Oct 27, 2009 03:36 PM
Video Funder 'n Lightning YarSmythe Electric Plane Talk 17 Aug 27, 2007 09:38 PM
Video Funder 'N Lightning troynh Electric Plane Talk 0 Jul 16, 2007 11:55 AM
