Old Jun 28, 2007, 11:02 AM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Yep, I think he means the HS for the Trex. 1800 or so would be better but sounds like you are at the gearing limit. You could dial it down some, but you could loss eff.
FB
Fred Bronk is offline Find More Posts by Fred Bronk
Old Jun 28, 2007, 06:11 PM
MommaSezNO is offline
Find More Posts by MommaSezNO
Joined Jun 2007
What you need is some flat bottom blades or at least semi's....not sure where you would find them in the 600-610mm range, but that should get you a few more minutes on top of what you're getting even now!
MommaSezNO is offline Find More Posts by MommaSezNO
Old Jun 28, 2007, 07:49 PM
dlmcmichael is offline
Find More Posts by dlmcmichael
Joined Dec 2006
QR,
On a side note, how are those DS821's with stock arms working out? I have the same setup on my new 600 (one 4 minute hover to date).
David
dlmcmichael is offline Find More Posts by dlmcmichael
Old Jun 28, 2007, 08:59 PM
QuietRiot is offline
Find More Posts by QuietRiot
QuietRiot's Avatar
United States, ID, Ketchum
Joined Dec 2003
I have no major complaints, but then I don't do extreme flying, where it really matters what servos are being used. At this point I don't have any rational reason for spending and additional $225 for the 'good ones' with the type of flying I'm doing...
QuietRiot is offline Find More Posts by QuietRiot
Old Jun 28, 2007, 09:03 PM
JustPlaneChris is offline
Find More Posts by JustPlaneChris
JustPlaneChris's Avatar
Austin, TX
Joined Sep 2005
Originally Posted by QuietRiot
JustPlaneChris, I traded in my hatch screw for an uber strong magnet and that hatch is going nowhere this time!
That's a good idea! But now we can't accuse you of having a screw loose.
-Chris
JustPlaneChris is offline Find More Posts by JustPlaneChris
Old Jun 28, 2007, 09:10 PM
badbill is online now
Find More Posts by badbill
Soylent Green is PEOPLE
badbill's Avatar
USA, GA, Centerville
Joined Dec 2002
If you're doing loops and rolls at 12 pounds, that's extreme enough to impress me. The 821's are awesome servos, despite an undeserved bad rep on the otheRR forum. I have yet to see someone over there pin down a REAL, factual instance of failure. They are plenty for a 600 size heli, esp. if you use 6 volts.
Bill Davenport
AMA 28141
badbill is online now Find More Posts by badbill
Old Jun 28, 2007, 11:30 PM
QuietRiot's Avatar
Joined Dec 2003
Bit of a misunderstanding. I own two ships, the Airwolf is using Futaba S3151 for cyclic(the good ones) and my A/P Trex 600 is using the 821's for cyclic. I can't say how the 821's would handle the paces I put my 12lb Airwolf through.
Discussion New personal Altitude Record for my Trex A/P! QuietRiot Aerial Photography 14 Jul 12, 2007 12:51 PM
Yippee! Did my second Foward Flight on my Trex 450se!!! Video brovic777 Mini Helis 21 May 28, 2007 04:49 PM
Discussion futaba s3151 servos on the cyclic of my trex 600 kogibankole Electric Heli Talk 18 Nov 23, 2006 07:41 AM
Cool Put a new paintjob on my Trex.. arclite5 Mini Helis 5 Apr 21, 2006 01:04 PM
Cool I set a new flight time record for myself! cactus Parkflyers 6 Mar 21, 2004 10:27 PM
