Old Jun 27, 2007, 11:10 AM
hg1 is offline
hg1
Find More Posts by hg1
hg1
hg1's Avatar
San Luis Obispo, California
Joined May 2007
Idea
Airframe design suggestions for small coaxial rotor craft ?
I would greatly appreciate some feedback on a very small hovering airframe using coaxial fixed blade rotors (no cyclic or collective) powered by brushless motors. Steering will be accomplished by steerable aerodynamic surfaces or weight shifting. Props will be in the range of 10-12" diameter, with total aircraft height of less than 8", and total weight, including electronics and battery less than 9-oz (250-gm). I have a pretty clear idea of what I want to do about motors, props and electronics, but not much experience with airframes, so comments and suggestions are welcome.
Howard
ps: I attached a photo of a prototype ... this particular model was not stable - the props were too small, the motors and frame too heavy, and the weight balance was completely wrong, but it was a useful starting point. My next step is to experiment with stabilizing wings under the props.
hg1 is offline Find More Posts by hg1
Old Jun 29, 2007, 01:01 PM
hg1 is offline
hg1
hg1
hg1's Avatar
Joined May 2007
Here's an update - I built a new airframe using poplar strips. The weight balance between top and bottom is still wrong - the motors are too heavy for this setup, but some lighter motors are in route. I'd like to get to the point that this can achieve a stable hover taking on the steering challenge.
I'm moving this thread over to the VTOL forum - http://www.rcgroups.com/forums/showthread.php?t=706462
Airframe/Battery suggestions for MPJet 28/7 -30D (Red) aquaflight 3D Flying 0 Nov 18, 2004 11:16 PM
Need suggestions for a small park airplane slammin Parkflyers 1 Apr 12, 2004 03:44 PM
Motor/Battery suggestions for small Su27 CarreraGTSCS Foamies (Kits) 0 Mar 11, 2004 05:51 PM
Suggestions for a small balsa biplane kit? demoman Parkflyers 2 Dec 03, 2002 09:38 AM
Power suggestions for small ex-wet kit Twmaster Parkflyers 1 Mar 14, 2002 08:52 AM
