Old Jun 26, 2007, 05:03 PM
G-Wiska is offline
Find More Posts by G-Wiska
G-Wiska's Avatar
Joined Jun 2007
Blackjack 26 Brushless Catamaran RTR VS. Aquacraft Supervee 27 Brushless
I was thinking about getting the supervee but then i came accross the blackjack so now im stuck becasue i dont know which one to get?? which one is faster???? i dont know anything about boats at all so plz help me anyway you can. and sorry if i annoy you with all my nooby questions.
G-Wiska is offline Find More Posts by G-Wiska
Old Jun 26, 2007, 06:20 PM
ryan_t888 is offline
Find More Posts by ryan_t888
Never Fast Enough
Hamilton Ontario
Joined Oct 2005
Not a whole lot is revealed as of now. Many people do not like the steerable outdrive including myself.
Ryan
ryan_t888 is offline Find More Posts by ryan_t888
Old Jun 26, 2007, 07:52 PM
no stick is offline
Find More Posts by no stick
Ohio
Joined May 2003
Twisted Liquid Racing here:
http://www.twistedliquidracing.com/blackjack.html
has a conversion kit for rudder as a replacement for the "U" joint drive for the Blackjack 26 nitro. It should fit the FE version.
Description: "Gain control at high speed of your Blackjack 26 by installing our "SKATER" In Line Rudder System. Increase control in turns and on the straights. This kit lets you completely remove the u-joint system on the Blackjack 26. Saving you money in the long run. Kit comes complete with everything you need to install in minutes, including new drive shaft and strut. No modifications needed to install. You have two choices with our hardware. Satin finish or Chrome finish. Same hardware, just two types of finishes.
TLR BREAKAWAY "SKATER" INLINE RUDDER SYSTEM"
Ed
no stick is offline Find More Posts by no stick
Old Jun 30, 2007, 11:34 AM
offshore1987 is offline
Find More Posts by offshore1987
United Kingdom, England, Portsmouth
Joined Nov 2006
outa intrest whats the run time of the blackjack 26?
cheers dan
offshore1987 is offline Find More Posts by offshore1987
Old Jun 30, 2007, 11:55 AM
lowdive is offline
Find More Posts by lowdive
lowdive's Avatar
anaheim, ca
Joined Apr 2005
my guess run time would be the typical average of 8-15 minutes, depending on how you're running the boat.
lowdive is offline Find More Posts by lowdive
Old Jul 05, 2007, 04:37 PM
ozoneone is online now
Find More Posts by ozoneone
King of The Moon
ozoneone's Avatar
NYC
Joined Jun 2003
Hey no stick, thanks for that info. Does that kit replace all the black plastic with metal? Have you tried it? Looks awesome!
ozoneone is online now Find More Posts by ozoneone
Old Sep 18, 2007, 12:10 PM
Jim10 is offline
Find More Posts by Jim10
Aucilla River, Florida
Joined Jul 2007
I have a SuperVee 27 electric (stock) with brass prop. My neighbor has a BlackJack 26 also with brass prop. My SV27 will out run the BlackJack.
Jim10 is offline Find More Posts by Jim10
Old Nov 25, 2007, 08:03 PM
jfelix is offline
Find More Posts by jfelix
Joined Nov 2007
THis is a very subjective question. I have the BJ 26 running 2 8.4 4000 MAH LiPo's in mine with an octura prop and I doubt there are too many Supervees that can run with it in a straight line... Radar gun show it hitting over 50MPH... My buddy has one with the same lipo's I have and he can't keep his upright.
jfelix is offline Find More Posts by jfelix
Old Nov 25, 2007, 08:50 PM
Never Fast Enough
Hamilton Ontario
Joined Oct 2005
There's no such thing as 8.4v LiPo's.
2s would be 7.4v
Ryan
Old Nov 28, 2007, 07:21 PM
jfelix is offline
Joined Nov 2007
correct, 7.2's... i called them 8.4 because they charge up to 8.4, but they are 2s...
Old Nov 29, 2007, 11:57 AM
Never Fast Enough
Hamilton Ontario
Joined Oct 2005
On another forum the guys with stock boats running LiPo's in the SV are achieving low 40's while the guys running LiPo's in the proboat cat are achieving high 30's. These LiPo's are high capacity 25C.
What are doing to achieve over 50mph?
Ryan
Old Nov 29, 2007, 12:18 PM
lowdive is offline
lowdive's Avatar
anaheim, ca
Joined Apr 2005
maybe they are using a different prop to hit 50? i can say that my friend's blackjack takes off from a dead stop while my sv27 cavitates for maybe 10' or more before hitting plane and catching (then passing) the blackjack. i expect that i can improve my performance by switching to a two blade prop but i've found my three blade gives greater top-end compared to my other friend's two blade (on a sv27).
sadly, i like both and will probably end up getting a blackjack at some point.
on an up-note, my sv27 can outrun a mud hen in flight. almost nailed on one the water. after it took off i turned and followed along side it down the length of the lake. i passed it a little then made a wide right turn while slowing. sucker almost landed on my boat! oh ducks, why are you so fun...
Old Nov 29, 2007, 12:22 PM
Never Fast Enough
Hamilton Ontario
Joined Oct 2005
An X642 was run apparently as well as the Grim props. I'm not fond of any of the Grim props, I prefer Prather, ABC, or Octura.
Ryan
Old Dec 17, 2007, 01:17 PM
sailr is offline
Find More Posts by sailr
Land O' Lakes, FL
Joined Aug 2003
fast electric cats
Check out the Samurai Cat at Mini Cat Racing USA. Runs 46 mph (gps) with their largest prop...outta the box!!
http://minicatracingusa.com/SAMURAI.html
Ryan
sailr is offline Find More Posts by sailr
Old May 06, 2008, 05:25 PM
slimpickens is offline
Find More Posts by slimpickens
Joined May 2008
i have a SV27 cane i run venom 5000 8.4 's without hearting anything?
slimpickens is offline Find More Posts by slimpickens
Discussion AquaCraft SuperVee 27 Brushless RTR SV27 tomi Racing Boats - Electric 165 Apr 26, 2010 04:16 PM
Discussion BLACKJACK 26 Brushless Catamaran RTR Diegoboy Racing Boats - Electric 42 Dec 04, 2009 09:27 AM
For Sale (SOLD) - SuperVee 27 Brushless RTR - YELLOW Lift Boats (FS/W) 2 Aug 28, 2007 01:21 PM
Sold Aquacraft FE SuperVee 27 RTR with Battery tomi Boats (FS/W) 5 Nov 03, 2006 12:52 AM
