Old Jun 25, 2007, 10:34 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Spitfire Mark XVIII or Seafire plans?
Well?
I'd love to have a Seafire.. Maybe I should modify and existing kit..
Anyone?
Jeff
www.CommonSenseRC.com
Tram is offline Find More Posts by Tram
Old Jun 25, 2007, 11:36 PM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Hi Tram, take a look at K&A models Ken made a nice looking spit for speed 400..its near the bottom of that page...I have been eyeing one also..I want to do the coaxil motor set up!
Scott
Old Jun 25, 2007, 11:41 PM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
That is a nice bird.. I had no idea he made that bird.. Nor did I know about his Me-163..
The Spit is a little smaller than I'd like.. I'd like to find something 36" to say 50" or so..
Latest blog entry: Wow.. 3 years..
Old Jun 26, 2007, 12:06 AM
mrdj is offline
Find More Posts by mrdj
Dog is my co-pilot.
mrdj's Avatar
United States, GA, Brooks
Joined Mar 2005
There are some Spitfires here.
https://sslrelay.com/s84068217.onean...dex.shopscript
Warpaint book #20 is dedicated to Griffon Seafires (including several diagrams and colour options)
The neat thing about the Spitfire family is that it was evolutionary. Nearly every change was first tried out on a previous version. By finding out where your version is in the family tree, you should be able to put together most of the airplane with plans of other versions, and only have cosmetic changes. Stay away from Spiteful/Seafang. A completely new aircraft.
The Seafire XVII could be done with the following:
Wings- The planform is roughly the same in all Spitfires until the 20 series. Minor cosmetics can finish this out.
Engine- Early model Griffon, same as a Spitfire XII or Seafire XV. It seems slightly shorter than later versions.
Fuselage- A low back Spitfire should be made to fit
Tail- Horizontal should be the same for all but the latest versions. The vertical tail seems to be a small fin and large rudder.
Mixing and matching plans should help you get most of it. Should be an interesting project.
DJM
mrdj is offline Find More Posts by mrdj
Old Jun 26, 2007, 09:32 AM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Hi Tram, yes a bit larger would be nice! I did build one of Kens 163...neet plane also..Its tiny at 24in ws...I am trying to get Ken to do larger one!
Scott
Old Jun 26, 2007, 02:11 PM
mtbrider is offline
Find More Posts by mtbrider
Ay up it's warped
mtbrider's Avatar
Derbyshire UK
Joined Feb 2003
There are free plans on the internet for the Alex Padashenko Mk XVI Spitfire at 29" but obviously upscalable. There have been a thread on it some time back, Mickey did it if I recall correctly.
mtbrider is offline Find More Posts by mtbrider
Old Jun 26, 2007, 03:19 PM
thomanie is offline
Find More Posts by thomanie
thomanie's Avatar
Trondheim, Norway
Joined Jun 2003
I was just going to suggest the Pedashenko Mk XVI plans from '97 as a starting point as well. Nice plans.
Thomas
thomanie is offline Find More Posts by thomanie
Old Jun 26, 2007, 04:34 PM
Work in Progress is offline
Find More Posts by Work in Progress
Light and floaty does it
Work in Progress's Avatar
Cambridge, Great Britain (UK)
Joined Sep 2004
A 16 (XVI) is basically just a low-back 9. To get a Seafire XVII or a Spit XII you will need to build a different nose for the single-stage Griffon - the rest is just scoops and radiators and spinners and stuff.
To get a Spit XIV or XVIII from a XVI you need to build a different different nose for the two-stage Griffon. And you have to start getting into fairly substantial differences in the fin as well as the rudder.
Work in Progress is offline Find More Posts by Work in Progress
Old Jun 26, 2007, 06:07 PM
Bosk is offline
Find More Posts by Bosk
Melbourne, Australia
Joined May 2005
RCME had a free plan for a 40" Spitfire MkIX in their special mag earlier this year. for a .25cu motor. I'm in the process of building one now but have modified to put a brushless in it with LiPo for power. It looks like it will have an AUW of around 900g. If you are interested PM me.
Bosk is offline Find More Posts by Bosk
Old Jun 26, 2007, 09:52 PM
Chad Veich is online now
Find More Posts by Chad Veich
Scale Builder
United States, AZ, Litchfield Park
Joined Jul 2002
Originally Posted by Tram
Well?
Hi again Tram, I too have the itch to some day build a Seafire XVII. My plans are for a much larger, IC powered model so I really can't speak to what plans might be available in the size range you seek. However, if they are of any use to you, I do have a nice set of scale drawings for the XVII. From a Spitfire starting point your best bet would probably be a MK. XII but that was a limited production Spit and is not too popular with model builders. If the K&A model recommended above is the same one I had beware that it is a Spitfire wing mated to a Spiteful fuselage and does not really represent any version of the Spit very accurately. Good luck with your search.
Chad Veich
Chad Veich is online now Find More Posts by Chad Veich
Old Jun 27, 2007, 12:04 AM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
Thanks for all the replies guys..
I guess I'll need to keep looking..
Chad - That Seafire sure had some intakes on it didn't it?
Old Jun 27, 2007, 07:20 AM
CarreraGTSCS is offline
Find More Posts by CarreraGTSCS
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Freehold Township
Joined Jan 2004
Tram-- That last photo is too sweet. Ever considered starting with a SureFlite Spitfire and bashing it into a Seafire? I have the latest version from them and it's 57" ws. They seem to have elongated the center section of the wing a little which is easily removed to give a pretty scale look. I'm working on one now. I'm going for a mk IX. It looks pretty cool. Has a reputation for good flying qualities as well.
CarreraGTSCS is offline Find More Posts by CarreraGTSCS
Old Jun 27, 2007, 11:54 AM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
Does SureFlite still produce a kit?
Old Jun 27, 2007, 02:58 PM
mtbrider is offline
Ay up it's warped
mtbrider's Avatar
Derbyshire UK
Joined Feb 2003
RCM&E did a free plan for a MK22 for a speed 600, I have the build article and plan but can not find it on their website? They did the mouldings for it as well. They are popular for the Ripmax Spit that does not come with the wing radiators.
Old Jun 27, 2007, 03:05 PM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
Yeh, maybe I can see if someone has that issue that won't use the plans..
Do you know what issue the plans came in so I can start looking?
Discussion Plans or kit for the bubble canopy Spitfire mark XVIII or XIX peterpont Fuel Warbirds 5 Sep 14, 2006 06:00 PM
1/48 supermarine spitfire mark 14 3-view plans..... Se5a-flyer Scale Kit/Scratch Built 6 Jul 26, 2004 03:13 AM
Ercoupe or Aircoupe plans, kit, ARF? MTrobin Parkflyers 11 May 29, 2002 10:07 AM
b707 or similar plans needed BioHazard Electric Ducted Fan Jet Talk 9 Feb 16, 2002 12:54 PM
Astra (Scorpio) Spitfire suggestions...3 or 4 channels? LG? Danny Troy Foamies (Kits) 7 Dec 24, 2001 05:26 PM
