Old Jun 24, 2007, 09:22 PM
Doug101 is online now
Find More Posts by Doug101
Doug - AMA 2234
Upstate NY
Joined Feb 2006
Charging 10s A123 cells w/ 2 chargers
I am making several 10s A123 packs that I need to charge and balance with 2 5s charger/balancers. Can I hook up the chargers as shown in the diagram below (using the common between the 5th and 65th cell. Or, do I have to actually make the pack 2 5s packs for charging and then connect them is series later to make 10s.
I did not show balance connections to simplfy the drawing.
Doug
Doug101 is online now Find More Posts by Doug101
Old Jun 24, 2007, 10:48 PM
Probedude is offline
Find More Posts by Probedude
Probedude's Avatar
Ventura, CA
Joined Jul 2006
You can IF you use two separate ISOLATED from each other power supplies.
If you can't guarantee that, then you would need to have the pack as 2 separate 5s packs for charging.
Probedude is offline Find More Posts by Probedude
Old Jun 25, 2007, 11:40 AM
Doug - AMA 2234
Upstate NY
Joined Feb 2006
Thank you for the information. I will not be using isolated power supplies, so I will seperate the pack into 2 5s packs and charge that way.
Doug
Old Jun 25, 2007, 12:54 PM
RC Toys USA is offline
Find More Posts by RC Toys USA
Kansas
Joined Sep 2003
be sure to cut the ground wire off the power supplies as well ( where it plugs into the wall), this will also be a common point and things will smoke if ya don't.
RC Toys USA is offline Find More Posts by RC Toys USA
Old Jun 25, 2007, 02:38 PM
Doug - AMA 2234
Upstate NY
Joined Feb 2006
Ok, then will this work. I could use a shorting plug between cell 5 and 6 to create a 10s pack for flying. I would remove the plug and connect as shown for charging. That would amount to charging 2 5s packs.
I would be using a single power supply for both chargers.
Doug
Old Jun 25, 2007, 03:06 PM
Probedude's Avatar
Ventura, CA
Joined Jul 2006
Doug
Yep, that'll work!
Old Jun 25, 2007, 03:29 PM
Doug - AMA 2234
Upstate NY
Joined Feb 2006
Thank You
Doug
Old Jun 25, 2007, 03:48 PM
d_wheel is offline
Find More Posts by d_wheel
Old fart. VAAATSP
d_wheel's Avatar
Deep in the Heart of Texas
Joined Jun 2004
Doug
If you haven't already bought your chargers, you might consider this . I have one and it works great for up to 13s A123 packs. I charge my 10s2p packs in 20 minutes and can charge faster if in a hurry.
Later;
D.W.
d_wheel is offline Find More Posts by d_wheel
Discussion Help soldering a123 cells w/o tabs!!! reefboy Batteries and Chargers 18 Apr 17, 2007 10:53 AM
Discussion Charging loose A123 cells? snackboy Batteries and Chargers 0 Apr 10, 2007 07:02 PM
Discussion Charging a 10s2p A123 Pack w/Astro 109 FlyingW Batteries and Chargers 5 Jan 19, 2007 02:41 PM
2 chargers of 2 cells to charge 3 cell shlomi_dar Batteries and Chargers 2 Feb 18, 2004 05:44 AM
