Old Nov 08, 2012, 06:19 AM
Justin C is offline
Find More Posts by Justin C
Adelaide, Australia
Joined Aug 2010
Hello,
I am wondering if anyone has replaced or hardened up the flaps and/or ailerons on the Cularis? Maybe use some other material that does not flex or torque as much under load? Any ideas would be great. I may have to take it over to scratch builders to see what they say, but thought I might try here first.
Justin C is offline Find More Posts by Justin C
Old Nov 08, 2012, 09:01 AM
garryk is offline
Find More Posts by garryk
Corsair Captain
United States, AZ, Mesa
Joined Oct 2010
Using live hinges would help with that along with maybe a carbon fiber strip along the middle of the control surfaces.
Garry K.
garryk is offline Find More Posts by garryk
Old Nov 09, 2012, 12:27 AM
4446 is online now
Find More Posts by 4446
Greece
Joined Jul 2010
One thing you can do is use a dremel tool and carefully groove the surfaces you want to stiffen.
In there you can add a carbon rod of your preference. I'd start with the ailerons as they're more susceptible to bending and flexing under load, which in time damage is permanent. Don't use a hobby knife to cut grooves. You'll ruin the surfaces.
As for the hinges I'd also start from the ailerons and rudder.
I would not recommend doing the flaps as their top surface is hinged with the wing's top surface and it would spoil the surface; Except of course if you have plenty of time and are very careful.
4446 is online now Find More Posts by 4446
Old Nov 09, 2012, 03:39 AM
Weysoar is offline
Find More Posts by Weysoar
United Kingdom, England, Weymouth
Joined Mar 2009
I used some carbon sheet that I had made up on a sheet of glass, a piece either side and overlapping the flap control horn, stuck with cyano. I hadn't planned on doing the others, at present.
Weysoar is offline Find More Posts by Weysoar
Old Nov 10, 2012, 03:46 PM
Justin C is offline
Adelaide, Australia
Joined Aug 2010
Thanks for the tips. Carbon rod seems the simplest method. And for me simple is best I might check hobbyking.
Justin
Old Dec 26, 2012, 02:39 PM
k8zfj is offline
Find More Posts by k8zfj
risoaringclub.org
United States, RI, Providence
Joined Sep 2005
Happy Holidays All, and special thanks to Santa for placing a new C next to the tree.
Since i knew it was coming, i've read this entire thread along with instruction manual online.
I've built many balsa & epp foam aircraft and always like to test out how any glue works on scrap before beginning assembly.
using thick CA (like ZAP CA) on scrap from the packing i'm finding that it just doesn't seem to really adhere well. By this i mean after letting it cure for a few hours, it's quite easy to pull apart the two glues pieces. I've tried this using the great planes kicker, water, and no kicker. 'have also experimenter with Gorilla glue brand CA with same results.
Am i missing something, or just being too critical?
I'm tempted to go the hot glue route, but CA seems lots more friendly for a "field" fix.
Thanks to all who have contributed to this topic
rgds, Randy
k8zfj is offline Find More Posts by k8zfj
Old Dec 26, 2012, 04:29 PM
AirBornOne is offline
Find More Posts by AirBornOne
I'm All Thumbs
AirBornOne's Avatar
S.F. Bay Area
Joined Aug 2002
Maybe give it a good wipe with some rubbing alcohol?
J
AirBornOne is offline Find More Posts by AirBornOne
Old Dec 26, 2012, 04:48 PM
mikeruth is offline
Find More Posts by mikeruth
The "Foaminator"
mikeruth's Avatar
Joined Mar 2007
rgds, Randy
Do not use thick. Indeed it will not adhere as well. I have bult a few of these now and Thin Regular(the kind that eats foam) CA is the ticket. Elapor bonds best with that. It's not your typical foam and I don't think there is another manufacture that uses it, if I'm not wrong it's a properitary formula by Multiplex.
mikeruth is offline Find More Posts by mikeruth
Old Dec 26, 2012, 06:53 PM
k8zfj is offline
risoaringclub.org
Joined Sep 2005
Problem solved, I wasn't using enough ca to adequately create a good bond. I should have comprehended the earlier statements in this thread re. Using a lot of CA
Old Feb 12, 2013, 01:51 PM
socalsteve is offline
Find More Posts by socalsteve
Huntington Beach CA
I recently finished a Cularis build and I am less than happy with the results. The tail is not correct - the horiz stab is not square with the vert stab. I sent an email to Cularis and received a very prompt reply from Mike Mayberry (Customer Service Team Manager for Hitec/Multiplex USA) stating that it was a build problem attributable to me. I have the two halves of the fuse match up perfectly and I do not recall any "adjustability" in the internal structure pieces that mounts the horiz stab.
Where is the issue here? Did I make a mistake? Mike stated that I "test fit the stab and check the alignment... during the gluing process" but I am not sure how one does that with hot CA between to pieces of foam. He now suggests that I "will probably have to cut something to fix it now" which I am not sure is something I want to take on.
Anyone have any suggestions of ideas? How to repair? Should I lean harder on Mulitplex for a resolution? I'm considering rebuilding the fuse so maybe some type of discount or better on the parts? Any comments or input would be appreciated.
socalsteve is offline Find More Posts by socalsteve
Old Feb 12, 2013, 03:14 PM
mikeruth is offline
The "Foaminator"
mikeruth's Avatar
Joined Mar 2007
Sorry to hear that Steve. I do aggree it is a building issue though and part of building any of these kits is making sure things line up as they are supposed to before gluing and thats up to us, unless of course there is a major problem with the kit. Something broken etc.
I have built two of the cularis models and when installing the tail feathers I had blocked up the fuse and wing flat and level then attached the horizontal stab and vertical fin using Epoxy allowing time to set the parts correctly. I did do a repair of one with CA for another fellow and on that I did the same but got every thing lined up "dry" then applied the CA and quickly made any small adjustment before it set.
It's jsut the nature of the beast here. How bad is it? can you post a picture to show us>
Maybe we can help in coming up with a better plan than just cutting the parts off for reatttachment.
Old Feb 12, 2013, 06:44 PM
Huntington Beach CA
Sure I can put up some pics. I've built a few planes, mostly stick built balsa. I lined up the outside of the fuse perfectly thinking that the molded pieces would follow along. I guess I was wrong.
Old Feb 13, 2013, 03:15 AM
Nachobud is offline
Find More Posts by Nachobud
Joined May 2008
I have an old cularis, and it have happened with her loads of things. I have to admit that it even flies better now than when I built it first time! I would suggest give it a try to fly your machine. Maybe you just need to put the rudder to the left about 2 cm to stop the machine from turning right too much (specially at high speed). For the elevator I would not worry much (mine is quite similar to yours now). If you tend to make loopings and acrobatic manouvres possible you will feel the instability of the plane, but for relax and quiet flies without strong wind I think you will learn how to fly her beautifully!
(when I glued the two halves it happened something similar, bended the tail to one side, and then the elevator also as the parts to fix it are inside the tail).
Nacho
Nachobud is offline Find More Posts by Nachobud
Old Feb 17, 2013, 12:13 AM
mikeruth is offline
The "Foaminator"
mikeruth's Avatar
Joined Mar 2007
As mentioned, striaghten things up as best possible and see how it fly's,
I've had one that looked pretty funky yet flew well
Also I had one that got pretty tweaked in a hot van, So i figure if it can twist in the heat, why not twist it back? It worked amazingly well. People could not beleive how much opposite twist I was applying without breaking the foam.
Mike R
Old Feb 18, 2013, 09:35 PM
FabioBrazil is offline
Find More Posts by FabioBrazil
Joined Mar 2009
Hi everyone, IŽd like to know this plane gliding ratio ??? anyone knows it??? Easy Glider has a 10:1 meters ratio, but seems that no one knows this info about cularis, not even multiplex... yes, I mailed them....
FabioBrazil is offline Find More Posts by FabioBrazil
Discussion herr mustang 42 construction tips? surfer Scale Kit/Scratch Built 10 Feb 06, 2009 01:11 AM
Herr 1/2A J-3 Construction Tips and Mini Review DryFly Parkflyers 11 Apr 15, 2002 02:21 PM
Chubby Lady Construction Tips DryFly Parkflyers 4 Mar 25, 2002 03:05 AM
Construction tips- Gary bblaske Parkflyers 0 Sep 08, 2001 07:39 PM
Twin boom construction tips MtnGoat Power Systems 5 Sep 07, 2001 11:40 AM
