Old Jun 24, 2007, 04:24 PM
Quacker is online now
Find More Posts by Quacker
Quacker's Avatar
United States, CO, Longmont
Joined Jul 2001
Multiplex Cularis Construction Tips and Tricks
Hi everyone! I have started this thread so we all have a place to share what we have learned or want to learn about building the Cularis. As the thread starter, I guess I'll start by saying--WOW. If you have not been lucky enough to see one yet, you are missing out on the next generation of well-engineered kits. Everything fits with near total perfection and the engineering is nothing short of superb!
I'll be building mine as a video platform so look for this later in the thread.
Everyone please post what they've found or ask a question! This thread should be a blast!
Q
Quacker is online now Find More Posts by Quacker
Site Sponsor
Old Jun 24, 2007, 04:41 PM
Quacker's Avatar
Joined Jul 2001
I got my Cularis on Wednesday and have just gotten started. For servos I chose the following:
HS-55 Ailerons
HS-65 Flaps (I got the MG 'cause they were in stock. Carbonite is cheaper). Note: I don't think the HS-55 has guts enough for flaps and the HS-81 is a bit large to cram in there. The '65 is a good compromise.
HS-81 for the tailfeathers.
The first issue that I ran into was the instructions where they say:
The spar tubes are glued in the wing by applying thick cyano
over their full length - but taking care not to allow excess glue
to escape and soil the wing surfaces. Check that the spar
cover 10 fits accurately - initially without gluing it. When you
are satisfied, the joint areas can be “painted” with thick cyano,
and the spar cover pressed into the recess.
Work briskly here, but don’t be too anxious - thick cyano gives
you ample time to complete the task properly without too
much haste. Press both the tubular spars down simultaneously
while the glue is hardening, taking care to keep them
perfectly straight. This stage is important, as it determines
whether the wing is usable or not.
Apply thick cyano to the remainder of the spar cover contact
surface, fit the cover and press it down over its full area.
I found this very confusing since it seems to me that they are saying that the spar cover gets glued and then is somehow available to glue down again. After some study, I came up with the following method that worked perfectly. (I still have no idea if this way is what they intended):
I started by getting each spar and spar extension to the right length and tacking them at the correct length with a small amount of CA.
Then I fit and refit the spar cover over the spars and insured that the edges fit down flush with the wing bottom. When I was satisfied (make sure the spars stick out the right amount), I ran just a thin bead of medium CA down the middle of the spar trough in the wing from root to tip.
I then, with the wing in the cradle, dropped the spars in and pressed down with my fingers along the entire length. Using my other hand, I sprayed the spars with kicker and continued to press while they kicked. The cradle insured that the wing did not get warped or crooked in the process.
The spar cover was then glued in and here is the sneaky part. Having built an EasyGlider, I knew the problems people had when the spar cover CA kicked while lowering the covers in place—I did the following:
Spray kicker on the spar cover and set aside for a few minutes.
Run a bead of glue on the top of the spar and on the long, flat faces of the entire spar cavity, but I DID NOT run the CA up the vertical walls of the trough. This is so no CA will hit the kicker until the spar cover is all the way down. Then lowered the cover into place and immediately pressed firmly on it until the CA kicked. Then I ran CA into the crack where the spar cover meets the wing and did not apply kicker. The CA seeps into the crack and sets up slowly. I spread the seam with my fingers and released it a few times to get the glue down into the crack. It is not important that the glue get to the bottom of the crack. So don’t use too much and don’t try too hard. Wipe up the glue on the surface before it sets. Here's an interesting variation. If you are going to sand the wing to get rid of those unsightly bumps, continue to sand along the seams and resist the urge to blow out or wipe away the sanding dust that gets into the crack. Then apply thin CA and the dust will act as a filler and bond the whole thing. Surface sand the seam when finished.
That’s it.
Site Sponsor
Old Jun 24, 2007, 05:19 PM
Quacker's Avatar
Joined Jul 2001
Getting more Flap travel.
It's not a flaw, it's a preference. Most guys in the US, at least those flying open class ships, want their flaps to deploy a full 90 degrees. This is because our contest rules require much tighter landings and the full flap deployment means a very steep and slow approach. Not so in Europe so it is no surprise that a European design like the Cularis would not satisfy my appetite for landing flap angle. To get more flap, would require a few simple modifications:
First I sanded the lower, forward edge of the flap using a very coarse nail file board. I sanded it a good amount and continued to test the flap angle until it was quite steep. Not a full 90, but way beyond stock.
Then I did something really funky—I glued the flap control horn in backwards. Yes that seems all wrong, but it needs to be backwards if the geometry is going to work out.
I also drilled 2 small holes on the horn mounting flange toward the trailing edge of the flap. I will use these to attach to a reinforcing plate on the top of the flap. The forces on the flap will be significant and the horn will likely rip loose without it.
The flap geometry will require a computer radio. With the servo at 100% of travel, the flap angle will be zero. With the servo centered, the flap will be at about 45 degrees. At 100%+ of travel in the continuing direction, the flap will be fully deployed.
Reflex (slightly negative [up] flap) can be reached by about 110% of travel in the other end of travel.
Here are a few shots:
Site Sponsor
Old Jun 24, 2007, 05:32 PM
Quacker's Avatar
Joined Jul 2001
The scary part: Do this only if you will be taking responsibility for the outcome! I had so much hinge resistance on the Easyglider hinges that I quickly realized that most of the stress on the servos was just bending the hinge. Soooo, I jabbed through the hinge with an Exacto like perforating it every inch or so. The result was removing about 50% of the hinge material. I was initially worried about the hinge continuing to tear at the punctures, but nope. It never in the 2 years since, has changed a bit. The Cularis with it's longer hinges was going to put even more stress on the servos, and by doing so, much more stress on the BEC because of higher servo current. I have repeated the above punctures on the Cularis.
Q
Site Sponsor
Old Jun 24, 2007, 06:13 PM
kitebugy is offline
Find More Posts by kitebugy
Chilliwack Dan
kitebugy's Avatar
Chilliwack B.C.
Joined Feb 2003
Excellent Quaker, I picked up mine yesterday and was hoping some one would start a build thread. Will be watching and learning.
Thanks Chilliwack Dan
kitebugy is offline Find More Posts by kitebugy
Old Jun 24, 2007, 06:20 PM
Joe Pierson is online now
Find More Posts by Joe Pierson
Joe Pierson's Avatar
USA, CA,
Joined May 2001
Cularis Build Looking real Nice!
Hi Quacker,
I am in on this build. Always nice to have some one go first! CA is great, but every think had better be right on before you press it togeather! Gorilla Glue now has Quick
Cure Dries White. Works on foam. After I test it out first, I might use it on this build. Looking good !!
Joe Pierson
Kerman Ca.
USA
Joe Pierson is online now Find More Posts by Joe Pierson
Old Jun 24, 2007, 07:06 PM
Quacker's Avatar
Joined Jul 2001
I like how CA works. I just rehearse a lot ;>)
I will not be first for long. I can get pretty busy with business, so I hope others will post to this thread as well.
Q
Site Sponsor
Old Jun 24, 2007, 08:11 PM
USA, CA,
Joined May 2001
Right on "Q" I am with You!!
Joe
Old Jun 24, 2007, 11:20 PM
Fred Sanford is offline
Find More Posts by Fred Sanford
Fred Sanford's Avatar
United States, FL, Punta Gorda
Joined May 2003
Got my Cularis last week so I'm "signing on". Will be curious about power options other than the Multiplex one which is not available from Hobby Horse at the present time.
Fred Sanford is offline Find More Posts by Fred Sanford
Old Jun 24, 2007, 11:48 PM
Popsflyer is offline
Find More Posts by Popsflyer
Oldie but goodie
Popsflyer's Avatar
United States, CA, Orange
Joined Jun 2003
I saw these at the local Hobby People store last week. Nice looking.
Popsflyer is offline Find More Posts by Popsflyer
Old Jun 24, 2007, 11:56 PM
Quacker's Avatar
Joined Jul 2001
If this helps, I'm planning to use a Hacker A30-8XL with 4 A123 cells. The Hacker fits perfectly
Site Sponsor
Old Jun 25, 2007, 11:01 AM
Duck! is offline
Find More Posts by Duck!
It flew...nearly!
Norway
Joined Apr 2006
Thanks for starting the thread, Quacker, I ordered mine the other day and know nothing about sailplanes (I'm just an rc addict).
Am looking forward to the tips and tricks from you experienced blokes. Pictures would also be much appreciated since I have limited building experience and they really help to clarify things for us nitwits..
Cheers,
matthew
Duck! is offline Find More Posts by Duck!
Old Jun 25, 2007, 01:27 PM
Quacker's Avatar
Joined Jul 2001
Hi Duck,
From one fowl to another: I think you will find the Cularis surprisingly easy to build correctly. The kit is that well thought out and precise. Welcome to the thread! I'm sure your wits are no less knitted than any others here ;>)
Q
Site Sponsor
Old Jun 25, 2007, 04:30 PM
USA, CA,
Joined May 2001
Cularis Build
Hi Q,
I am going with a Mega 22/30/3 The holes in the motor bulkhead Part#46 are right on the money! A Jeti Spin 44 and a 3S-2100 I tried a 3S-3700 and it fit.
Joe Pierson
Kerman Ca.
USA
Old Jun 25, 2007, 05:24 PM
USA, CA,
Joined May 2001
Cularis Build
HI Q,
I just used some 400 wet dry sandpaper on the rudder. Then I sprayed two light coats of the new Krylon H20 Latex, Artic White. Looks really nice!! It dries very fast! It's worth the effort if you want a nice looking finish. !!
Latex, Water Clean up!
Joe Pierson
Kerman Ca.
USA
Discussion herr mustang 42 construction tips? surfer Scale Kit/Scratch Built 10 Feb 06, 2009 01:11 AM
Herr 1/2A J-3 Construction Tips and Mini Review DryFly Parkflyers 11 Apr 15, 2002 02:21 PM
Chubby Lady Construction Tips DryFly Parkflyers 4 Mar 25, 2002 03:05 AM
Construction tips- Gary bblaske Parkflyers 0 Sep 08, 2001 07:39 PM
Twin boom construction tips MtnGoat Power Systems 5 Sep 07, 2001 11:40 AM
