Old Jun 24, 2007, 03:28 AM
ajroahkni is offline
Find More Posts by ajroahkni
PWP!
ajroahkni's Avatar
USA, HI, Makawao
Joined Oct 2002
Contest
SSDC: ICBING 60" Racer * now with video
60" EPP racer
ajroahkni is offline Find More Posts by ajroahkni
Old Jun 25, 2007, 05:10 PM
PWP!
ajroahkni's Avatar
USA, HI, Makawao
Joined Oct 2002
Why EPP?
Why EPP sucks
  • Not smooth = you can see tape lines
  • Soft building material requires large chords = not sexy
  • Building strong tends to mean building heavy
  • Gets bashed, gets spongy/floppy
  • Promotes careless pilot mentality
Why EPP good
  • Anti-hangar rash
  • Easier to transport - no blankets needed
The Icbing will be a 60" racer-type model. Inspired from current design styling, the goal is a model that I hope will meet the gold standard "as good as glass" objective.
To do this, I feel the model will need:
  • a strong, stiff spar
  • thin chords
  • thin, smooth, stiff fuse
  • to be ballastable
  • good clean looks (no "panty lines")
Specs:
  • area: 345 sq inch (bird60/Mini NYX/Nemesis=356 sq inch)
  • foil: mh43 (as used on ScorpionII)
  • length: ~35"
  • loading: Goal 12-15 oz/sqft
Old Jun 25, 2007, 05:19 PM
Brian Courtice is offline
Find More Posts by Brian Courtice
Free as a bird now.
Brian Courtice's Avatar
United States, FL, Punta Gorda
Joined May 2002
Looks great John! Sorta kinda Shrike-like. Love the upturned tips. Get 'er done!
Brian Courtice is offline Find More Posts by Brian Courtice
Old Jun 25, 2007, 05:54 PM
I'm Rick James is offline
Find More Posts by I'm Rick James
Nucking Futs
I'm Rick James's Avatar
Southern Killafornia
Joined Jan 2005
BNF? (blunt nose fetish!)
Looks good. Looks like a bit of a PIA to keep the fuse in line and keep that Vtail incidence correct.
Please keep us posted.
IRJ
I'm Rick James is offline Find More Posts by I'm Rick James
Old Jun 25, 2007, 07:09 PM
Ryan Archer is offline
Find More Posts by Ryan Archer
United States, AZ
Joined Aug 2004
AWESOME
looks Great,
were can i get rc cad?
ryan
Ryan Archer is offline Find More Posts by Ryan Archer
Old Jun 25, 2007, 07:18 PM
A10FLYR is offline
Find More Posts by A10FLYR
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
Originally Posted by Ryan Archer
AWESOME
looks Great,
ryan
You can download a freebee copy for trial..
A10FLYR is offline Find More Posts by A10FLYR
Old Jun 25, 2007, 08:45 PM
Mike Furcolow is online now
Find More Posts by Mike Furcolow
Mike Furcolow's Avatar
Paonia, Colorado
Joined Sep 2004
You mean, kinda like this?
All EPP construction
Fuselage; EPP with CF central longeron
Wing; 60" span, airfoil RG14-7% thickness, EPP w CF spars and X-pattern taping to resist twist, upswept "winglets" for reduced drag, better roll control for landing
AUW; 22 oz
This plane likes LOTS of ballast...I end up taping lead to the top of the wing, 'cause I made the fuse so small for low drag. If I was doing it over again, I would build it MUCH heavier...that's easier than light, anyway...
Mike Furcolow is online now Find More Posts by Mike Furcolow
Old Jun 25, 2007, 08:48 PM
PWP!
ajroahkni's Avatar
USA, HI, Makawao
Joined Oct 2002
Thanks for the interest guys. I am excited. This was inspired on Friday after seeing Kawika's Bird60...I love to build, and until I get a vac system, won't make the jump to carbon bagged...so scratching out in EPP it is!
I got the cores going thanks to Nauga, and have placed my orders around the net for balsa, CF, etc. I hope to start by next week! Can't wait.
Wingtips and tail feathers will be balsa and I am going use a RAPTR DLG boom from atlantahobby to keep it stiff/light out back. The fuse will be wrapped in foam to some extent, though I may have to substitute foaming PU glue for EPP where it gets real skinny.
I'll make sure to show how I set the incidence, I've done it before w/ an EPP plane and it came out pretty good.
edit - thanks to Mike F, my dreams are shattered...
I will now move over to my alternate original idea: EPP Jart... (joking)
Old Jun 25, 2007, 11:53 PM
Paonia, Colorado
Joined Sep 2004
Uh-oh. Don't shut down your idea--make it better!!! I just posted that to "second" your ideas and your plans. I've been flyin' mine for 2 years, and I can sure tell you that you won't be disappointed with the results when you get it in the air. Your current plan for the ICBING racer is a winner! Go for it!!
Old Jun 26, 2007, 12:45 AM
Jeff Charlot is offline
Find More Posts by Jeff Charlot
Insert custom witicism
Jeff Charlot's Avatar
San Diego
Joined Jun 2001
I like it! Same foil and specs as some of the top racers, but with EPP? Cool! Go man! I wanna see you win some races with this thing!
Jeff Charlot is offline Find More Posts by Jeff Charlot
Old Jun 26, 2007, 12:52 AM
Reed is offline
Find More Posts by Reed
Vitruvian JART
Reed's Avatar
San Francisco
Joined Mar 2003
Subscribed!
Reed is offline Find More Posts by Reed
Old Jun 28, 2007, 01:21 PM
PWP!
ajroahkni's Avatar
USA, HI, Makawao
Joined Oct 2002
UPDATE: I got the word from Nauga today that my cores are in the mail - what a great guy. I also called lonestar-balsa to find out that they did take my paypal $, but lost my order - good thing I called them. Anyway, balsa shouuld be in the mail too! I may not start this weekend, but I'm a happy guy.
Old Jul 08, 2007, 06:06 AM
PWP!
ajroahkni's Avatar
USA, HI, Makawao
Joined Oct 2002
Building starts
Nauga's core cutting special offer for SSDC is/was something that anyone should take advantage of. Very nice, clean cuts. He does it for love of the hobby, an awesome guy.
I requested a spar channel of 3/16" across my cores, he did it no problem...problem is that I gave the wrong measurement - meant to say 3/8". Oops.
Some passes with a blade, some cautious, nekkid routing with a dremel, and the channels were widened for the CF Ribbon (it's the same ribbon that LJ kits come with, I'm not cutting it though).
I requested full airfoil cuts because I wasn't sure how much ailerons I'd put on until I actually saw it...anyway, cut 1 5/8" off the TE.
Ever since seeing Don Thuren's bulletproof spar, I have wanted to try my hand at one. I won't wrap it in a kevlar braid, but will end up doing some wrapping of sorts.
Cut #1 - 14 more to do. Using 1/8" and 3/16" balsa sheet, cut vertically.
It was a lot quicker than I thought it'd be to cut my wood
I put the top & bottom CF in the groove and then placed my balsa in. Going to let the wood and CF get used to the EPP, and tomorrow or Monday get to gluing and sanding. I err'd on the side of waste when cutting - quite a bit of sanding ahead, need to buy a few new masks.
Old Jul 08, 2007, 11:01 AM
Mr. Innocent is offline
Find More Posts by Mr. Innocent
Mr. Innocent's Avatar
Oceanside CA
Joined Dec 2004
I always enjoy your build threads John, keep it up!
Justin
Mr. Innocent is offline Find More Posts by Mr. Innocent
Old Jul 10, 2007, 05:00 AM
PWP!
ajroahkni's Avatar
USA, HI, Makawao
Joined Oct 2002
Vtail blanks
A buddy of mine that's a great furniture maker/woodworker ripped me some 1/8" balsa from his gigantic slab of the stuff. I'll be using this for my V-tail stock.
I will use 2 1/8" pieces, sandwiched together to make my V-tails.
Grooves pressed into one sheet of balsa
Slathered finishing epoxy on the blank sheet of balsa, wiped off, set to the side
Epoxy to the grooved side, pressed/saturated carbon tow into the grooves. Wiped excess.
Mated, pressed for the eve.
Ocelot 60 racer Daniel Mc Crae Sailplane Talk 0 Oct 23, 2002 11:50 PM
