Old Jan 28, 2008, 01:44 PM
Nigelp is offline
Find More Posts by Nigelp
Brit in Bahrain
Nigelp's Avatar
Bahrain
Joined Mar 2004
Ah, now I see.....you mean there are a few degrees of dihedral (wing tips raised) on the original.
Dihedral would give you more "self righting" ability - you probally wouldn't need more than 3 degrees - 5 degrees maximum, if you are building to scale and need the stability....Peter's design uses NIL dihedral - that way you get a "keeps going in the last direction you put it in" type plane which means that you really can't take your eyes off it whilst flying !
If you need the stability, plus slow flying you might want to use Rab's method of 2 sevos on the ailerons so that you can also use them as flaps to change the wing camber (curve) and slow down but still keep control.
Take care,
Nigel
Nigelp is offline Find More Posts by Nigelp
Old Feb 13, 2008, 01:55 AM
Talajouy is offline
Find More Posts by Talajouy
Australia, QLD, Gold Coast
Joined Aug 2007
Hi
It finished and ready for first flying.
640grams including 2100mAh lipo.
Talajouy is offline Find More Posts by Talajouy
Old Feb 28, 2008, 10:52 PM
Talajouy is offline
Joined Aug 2007
Hi
After about 12 flights I gave this plane to a girl in our flying range that she said likes my plane.
Now I plan to make another one a bit more scale but still using same plan with smal changes.
I will cut the wings out of fome with airfoile and make movements area on wing and tail smaller.
Wish finish it soon and send some photo.
Habib
Old Mar 31, 2008, 03:25 PM
turt1e_b is offline
Find More Posts by turt1e_b
Mableton, GA USA
Joined Nov 2005
So any of you guys still flying your Se5a? I'm currently working on mine and I'm to the stage of installing servos and need to decide on best CG placement. Of the three locations NigelP listed which one do find yourself using most; 25%, 30, or 33%? My build balances great at the 30% mark and gives me the most range of battery placement, but I'm afraid this CG location will end up being to tail heavy. For 25% to work for me I have to place the servos in the battery compartment and use a heavier battery in order to have it just a touch nose heavy for maiden.
turt1e_b is offline Find More Posts by turt1e_b
Old Mar 31, 2008, 03:55 PM
CA'ed fingers is offline
Find More Posts by CA'ed fingers
CA'ed fingers's Avatar
Montreal, Canada
Joined Feb 2003
hummmm, might have to build one...
CA'ed fingers is offline Find More Posts by CA'ed fingers
Old Mar 31, 2008, 05:24 PM
bubbafusion is offline
Find More Posts by bubbafusion
bubbafusion's Avatar
Oak Ridge, TN
Joined Jun 2002
I'm still enjoying flying mine. I'm not sure of the CG, but it's a bit aft of what was called for on the plans (85 mm =3.3 inches from leading edge of top wing) I received. So, I guess my CG is further back than 33%, and it flies great.
bubbafusion is offline Find More Posts by bubbafusion
Old Mar 31, 2008, 10:46 PM
rab is offline
rab
Find More Posts by rab
rab
Grounded in Arlington
rab's Avatar
Arlington, Virginia
Joined Aug 2004
I fly mine often, I am happy with it. - Allen
rab is offline Find More Posts by rab
Old Apr 01, 2008, 06:55 PM
turt1e_b is offline
Mableton, GA USA
Joined Nov 2005
What Center of Gravity location do you fly with most often. Have you tried the three different location provided by NigelP?
Old Apr 01, 2008, 06:58 PM
turt1e_b is offline
Mableton, GA USA
Joined Nov 2005
Thanks bubafusion, that's good to know. I've made some slight changes in the build and didn't think things through completely before building up the fuselage. Because of that, putting the servos in the battery compartment would have been a pain. I think I'll go with them in the tail section and hope for the best.
Old Apr 01, 2008, 09:54 PM
rab is offline
rab
rab
rab's Avatar
Arlington, Virginia
Joined Aug 2004
I think my CG is about 3 inches or a bit more back from the leading edge of the top wing. I figured I had the CG and the down thrust about right when inverted flight did not need input to remain level.
- Allen
Old Apr 02, 2008, 10:17 AM
turt1e_b is offline
Mableton, GA USA
Joined Nov 2005
- Allen
Thanks Rab. Your CG seems to match what bubbafusion is using which is good news for me. 3 inches seems to give me a wider range of battery placement.
Old Apr 02, 2008, 06:10 PM
rab is offline
rab
rab
rab's Avatar
Arlington, Virginia
Joined Aug 2004
Yes, and so long as your plane is as light as or lighter than the spec's I don't think it is too sensitive about CG. - Allen
Old Apr 02, 2008, 10:54 PM
turt1e_b is offline
Mableton, GA USA
Joined Nov 2005
Well, I maidened mine today and it flew nicely. Below are the specs for mine.
Reciever - AR6000 (Using a DX6)
Motor - Eflite Park 450
Prop - APC 11x4.3 SF
ESC - Phoenix 25
Battery - 3S TP 1320
Weight - 15.5 oz without battery and 18.7 oz w/tp1320
First flight I lowered the flaps (using flaperons) and it took off nice and scale like as I slowly eased the throttle forward. I'd say it took off at around 1/4 throttle with the flaps set to about 15 degrees. Once I had some altitude I started trimming. It needed about 6 clicks of right aileron and about the same of right rudder to get it flying level. On slow ailerons turns I noticed a tendency for the tail to start draging and the left wing to drop suddenly. I have a bit of a downward warp to the top left wingtip, so I'm wondering if that might be causing a tip stall. Not sure on the tail dragging though. It's almost as if it's flying tail heavy when turning slow. Inverted flight takes just a touch of down elevator and it rolls nicely. Even tried to see if I could get it to hover on it's prop, but I think I need more motor for that. Or maybe try some different props. This is my first Bi-plane so it's going to take a few more flights to get used to it.
Below are some pictures of it. I made a few modifications from what the plans called for Still need to add a few things to finish it up. Side decals, cover for the front, cockpit trim, exhaust pipe and manifold, and maybe even a gun and pilot. I wanted a different color scheme than the usual solid green and came across this one on the web. It was on a model so not sure it's authentic, but seems to look period correct.
I've got a movie uploading now and will post a link to it when it's finished. Thanks guys for answering my questions on the CG, and a big thanks to Pmjass for making the plans available and NigelP for starting this thread.
Paul
Old Apr 02, 2008, 11:20 PM
pmjass is offline
Find More Posts by pmjass
Team FlightPower AUS
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
Wow,
that looks great. Glad the maiden went well.
I had often looked at the sprung suspension aircraft like this had and thought it was a good simple idea. You have done a great job "scaling" the idea.
Peter
pmjass is offline Find More Posts by pmjass
Old Apr 03, 2008, 04:56 AM
Nigelp is offline
Brit in Bahrain
Nigelp's Avatar
Bahrain
Joined Mar 2004
I'll second that ! Like the flaps - increases the versatility and love the 'sprung' u.c.
With your permission I would like to use that idea in the future....already thinking about it and how I could modify it to use 'O' rings...rubber bands don't last very long in Arabian Gulf summer temperatures.
Nigel
Article Parkfliers.coms' Edge 540T Full Fuselage Foamie 3D ARF Review aneigher24 3D Flying 12 Jul 30, 2009 03:02 AM
Yippee! ***Something New?*** True scale, full fuselage, 40" 3D Extra 300L, Built like a 35%'r Levi Jordan 3D Flying 18 Jan 27, 2005 04:50 PM
Mini Funtana - Full fuselage 3D'r hoppy 3D Flying 1 Feb 29, 2004 02:15 PM
GWS Full Fuselage Planes t-turley Parkflyers 2 May 03, 2001 08:34 PM
350 NiMH & GWS full fuselage Cub t-turley Parkflyers 2 Apr 30, 2001 06:56 AM
