Old Jun 23, 2007, 12:45 PM
Nigelp is offline
Find More Posts by Nigelp
Brit in Bahrain
Nigelp's Avatar
Bahrain
Joined Mar 2004
SE5a Full Fuselage 3D Maiden report
Quite a time ago I sent a private message to pjmass - designer of the 'Baby Baron', Big Baron', Das Ugle-stick etc. to ask if he was going to design a full fuz SE5a (my all time favourite aircraft !). This is the result ! I took a while to build it and whilst it is 'stand off scale' I admit I got a little bit carried away with the details (just a tad LOL).
Maidened it yesterday - it flew perfectly !!!!!! (having said that, Peter is an accomplished 3D flyer and I am strictly a mediocre sport flyer !)
High rates rapidly scared me to death ! It goes exactly where you point it and it rolls like a drill!!!! So, switched to low rates, and as usual with Peter's designs, it flew like a pussy cat (even I could handle it LOL!) Wild to mild.
Being slightly anal, I had checked and re-checked everything during the build and fitting out to be sure everything was as it should be....however, did the usual wiggle of the sticks immediately before opening the throttle for the maiden ROG ..only to discover (thank goodness !) that somehow - even after all that checking - that the rudder was reversed !!!!!!!!
During the maiden the motor cut ! (that has never ever happened to me before with an electic motor !!!!!!!) Result - dead stick landing. Checked it out - couldn't find anything wrong - relaunched and after 5 minutes - it did it again !!!!! Another dead stick landing - couldn't believe it !.....I am now troubleshooting cos I found that my CC Phoenix esc was red hot ! Maybe too many amps but I suspect not enough cooling air - the air temperature at the time was 45C / 112 F + (!) and the esc is inside the fuz!
The dead stick landing were a testament to the strength of the model and actually a bit of a confidence booster for me ! Anyway, back to troubleshooting the esc. I just can't wait to get this machine back into the air!
I have attached a couple of photies.
Nigel
Nigelp is offline Find More Posts by Nigelp
Last edited by Nigelp; Jun 25, 2007 at 01:02 PM. Reason: forgot to attach the pictures (Sheesh)!?
Old Jun 23, 2007, 12:48 PM
youth must fly is offline
Find More Posts by youth must fly
feel no remorse
youth must fly's Avatar
underground
Joined Jun 2004
I cant see the pics
youth must fly is offline Find More Posts by youth must fly
Old Jun 23, 2007, 01:52 PM
rab is offline
rab
Find More Posts by rab
rab
Grounded in Arlington
rab's Avatar
Arlington, Virginia
Joined Aug 2004
Looks good. Are the plans available somewhere?
- Allen
rab is offline Find More Posts by rab
Old Jun 23, 2007, 01:53 PM
Nigelp is offline
Brit in Bahrain
Nigelp's Avatar
Bahrain
Joined Mar 2004
Try sending a PM to pmjass - he's a member.
Nigel
Old Jun 23, 2007, 02:09 PM
Nigelp is offline
Brit in Bahrain
Nigelp's Avatar
Bahrain
Joined Mar 2004
Some details of the plane:
SE5a Full fuselage – 3D. Designed & drawn by pmjass who also designed:
– Fokker Dr1 (indoor version “Baby Baron)
– Fokker Dr1 (outdoor version “Big Baron)
– Das Ugl-e-stick & others.
From plans - 6mm Depron.
4 channel biplane Aileron / Elevator / Rudder
Full fuselage with Flat wings - NO WING SPARS - honest - flying wires only !
Wing span: 840mm / 33”
Chord: 180mm / 7.1”
Total chord - both wings: 255mm / 10.03”
Wing area: 436 sq. ins. / 3.02 sq. ft.
AUW 627g / 22.12 oz
Wing loading 7.32 oz / sq.ft.
CG back from LE of top wing:
25% = 63.75mm / 2.5” back
30% = 76.5 mm / 3.01” Ditto
33% = 84.15 mm / 3.31” Ditto
Length (inc. rudder): 746mm / 29.3”
Wheels: 83mm / 3.26” dia. (19g / 0.67 oz each)
U/C: ‘Bamboo’ chopsticks with 4mm / 0.15” dia CF rod joiner.
Music wire stub axles 1.5mm / 0.06” music wire – bound & CA’d to C.F. rod.
Motor: Komodo 283 v2. (23.8 mm double stator outrunner)
Winding 11T x 23 SWG (?) around Kv 500
Swings an GWS 11 x 4.7 at 5745 rpm pulling 10.8 amps
Approx 117 W in / 89 W out. Efficiency: 76%
805g / 28.4 oz thrust Pitch speed 25.57 mph
(All manufacturers figures)
Weight: 65g / 2.29 oz. including engine mount.
Watts per pound = 64.5
Receiver: Schultze Alpha 435 – 35 mHz 4 channel (9.5g / 0.32oz.)
Servos: 2x Waypoint WO68PB (6.8g each) Rudder & Elevator (pull/pull – using 20lb braid fishing line)
1X Waypoint WO92 (Metal gears 10.8g ) on Ailerons
Aileron torque rods: Made from 1.5mm / 0.06” music wire & ‘Ball point’ pen plastic tube.
ESC Castle Creations Phoenix 25A brushless.
Battery: Align Li-po. 3S - 1900mAh (145g / 5.11oz.) 13C
Antenna: Azzar 35mHz 9” Micro-Lite antenna
Flying wires: 0.5mm / 0.019” Carbon fibre rod
Struts: ‘Bamboo’ chopsticks
Painted with: Green – water based acrylic rattle can
All others – brush – water borne artists acrylic
Pilot carved from laminated blue foam and painted with w/b artists acrylic.
Lewis Gun & mount carved from blue foam
Nigel
Old Jun 23, 2007, 03:13 PM
bubbafusion is offline
Find More Posts by bubbafusion
bubbafusion's Avatar
Oak Ridge, TN
Joined Jun 2002
That's one sweet looking design!
bubbafusion is offline Find More Posts by bubbafusion
Old Jun 23, 2007, 03:20 PM
Nigelp is offline
Brit in Bahrain
Nigelp's Avatar
Bahrain
Joined Mar 2004
Thanks bubbafusion - that Stearman bipe in your avitar looks good - how does it fly ?
Nigel
Old Jun 23, 2007, 06:15 PM
pmjass is offline
Find More Posts by pmjass
Team FlightPower AUS
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
Looks fantastic Nigel.
Plans are/will be available. For now the easiest for me will be for you to post a request in the thread and I can send a zip file. Soon hopefully I will get the plans loaded onto a server.
Peter
pmjass is offline Find More Posts by pmjass
Old Jun 23, 2007, 09:30 PM
Oak Ridge, TN
Joined Jun 2002
Nigelp,
The Stearman is a great flyer. It's a Guillows conversion. There are some posts about it in the "Show your electric warbirds" and "Guillows R/c Conversion post!!!" threads. I've flown it about 2 dozen times, but I still get nervous every time it's in the air because it took so long to build. It loops great, rolls in a very scale manner (slowly) and flys inverted well.
Old Jun 24, 2007, 02:32 AM
aerophilia is offline
Find More Posts by aerophilia
building building building!
aerophilia's Avatar
Melbourne Australia
Joined Jun 2006
Nigel, your attention to detail is excellent. That's a fantastic looking plane. Still looks very scale despite it's aerobatic prowess. Love the fact that it is full fuse. I have just finished building tony65x65's se5a, so I might have to start a squadron!
aerophilia is offline Find More Posts by aerophilia
Old Jun 24, 2007, 07:00 AM
kram242 is offline
Find More Posts by kram242
-+- PhlatBoyz -+-
kram242's Avatar
New Jersey
Joined Sep 2003
Very nice
kram242 is offline Find More Posts by kram242
Old Jun 24, 2007, 12:22 PM
Nigelp is offline
Brit in Bahrain
Nigelp's Avatar
Bahrain
Joined Mar 2004
Hi Guys,
If anyone is interested I have enough pictures to turn this into a build thread - I know Peter is interested - LOL 'cos I did a few bits umm - 'slightly differently' !
Happy landings (& hopefully not deadstick !!!!)
Nigel
Old Jun 24, 2007, 02:57 PM
Oak Ridge, TN
Joined Jun 2002
Nigel,
I'd be interested in a build thread. I printed the plans this morning and started cutting out some templates. One thing I'm confused about is the fuse cores. The plan says to make two stacks of two 6 mm pieces and one 3 mm piece and then glue the two stacks together. On the other hand, the plan says to make six 6 mm pieces and the rectangular pieces that hold the upper and lower parts together are wide enough for six 6 mm (36 mm) plus two 3 mm (6 mm, for a total of 42 mm). So, I assume the stacks should be three 6 mm pieces each, not just two?
Old Jun 24, 2007, 04:19 PM
pmjass is offline
pmjass's Avatar
Victoria, Australia
Joined Nov 2002
Two stacks of 3.
I'll check the plan and update. Thanks for letting me know.
Once Nigel post a few pics it will be easier
Peter
Old Jun 24, 2007, 05:18 PM
rab is offline
rab
rab
rab's Avatar
Arlington, Virginia
Joined Aug 2004
I would love to see some build photos.
- Allen
Article Parkfliers.coms' Edge 540T Full Fuselage Foamie 3D ARF Review aneigher24 3D Flying 12 Jul 30, 2009 02:02 AM
Yippee! ***Something New?*** True scale, full fuselage, 40" 3D Extra 300L, Built like a 35%'r Levi Jordan 3D Flying 18 Jan 27, 2005 03:50 PM
Mini Funtana - Full fuselage 3D'r hoppy 3D Flying 1 Feb 29, 2004 01:15 PM
GWS Full Fuselage Planes t-turley Parkflyers 2 May 03, 2001 07:34 PM
350 NiMH & GWS full fuselage Cub t-turley Parkflyers 2 Apr 30, 2001 05:56 AM
