Old Nov 05, 2002, 06:26 AM
Takao Shimizu is offline
Find More Posts by Takao Shimizu
Tokyo, Japan
Joined Nov 2002
Simple Li+ charger schematic
May be, this is the cheapest Li+ charger.
Because, I have ordered FREE samples of MAX 1811 USB powered Li+ battery charger chip to Maxim semiconductor.
Need the magnifier lens for senior guy to solder this SMALL chip.
Takao Shimizu is offline Find More Posts by Takao Shimizu
Old Feb 17, 2003, 07:35 PM
Pierre Audette is offline
Find More Posts by Pierre Audette
RPV builder & operator
Pierre Audette's Avatar
Canada, QC, Gatineau
Joined Jan 2001
I just got some samples of this chip today. Is it suitable for lithium polymer cells?
Pierre Audette is offline Find More Posts by Pierre Audette
Old Feb 17, 2003, 08:11 PM
Tokyo, Japan
Joined Nov 2002
Pierre,
Basically, "Yes".
The charge current 500mA. So, do not use less than 500mAh
Lipo.
The 5V power source can be replace to
http://www.rcgroups.com/forums/showt...threadid=91780
And you may need the power diode on the power input line to protect reverse battery +- connection.
Old Feb 17, 2003, 11:36 PM
Joined Jan 2001
I was actually thinking on setting it on the 100 mA charge current for use with 145 mA cells, and a wall wart for the supply voltage.
Old Feb 18, 2003, 10:50 PM
Tokyo, Japan
Joined Nov 2002
Pierre,
My schematic shows 500mA charge.
You must change the current adjust pin2 connect to GND(pin6).
And your wall transformer peak voltage, include ripple peak must be less than 7V.
Old Feb 19, 2003, 10:49 PM
meteor is offline
Find More Posts by meteor
meteor's Avatar
Ontario, Canada
Joined Nov 2002
Good idea...
This is exactly the kind of charger I am referring to in my "Multi-Channel charger" thread...
If someone were to pursue this commercially, you could make a 4-channel Li-Poly charger for about $20.00!
The Maxim 1898 might be a little better choice. Although it's not quite as simple an implementation (the 1811 has one resistor, 1 cap, that's SIMPLE!), it's a FET-controlled linear Li-Ion charger, with adjustable charge current (up to 2A+).
see: http://www.maxim-ic.com/quick_view2.cfm?qv_pk=3250&ln=
Good stuff!
meteor is offline Find More Posts by meteor
Old Feb 20, 2003, 01:17 AM
Tokyo, Japan
Joined Nov 2002
My explanation was INCORRECT!
Originally posted by Takao Shimizu
Pierre,
Correct;
And your wall transformer peak voltage, include ripple peak must be less than 7V, if you do not use DC-DC converter with 100mA charge.
Old Feb 20, 2003, 10:11 AM
meteor is offline
meteor's Avatar
Ontario, Canada
Joined Nov 2002
Not as bad as it looks...
Although Takao's schematic is very complete, it really makes it look a lot more complicated than it is!
See the attached image for the default implementation (even this one makes things a little confusing with the hi/low input settings)
Takao includes a DC-DC converter to allow a variety of input sources. But, any simple 5V supply (wall wart) would suffice.
Up to a 6V source can be used, but the chip may not be able to dissipate to power difference between the Li-Ion and supply at the 500mA setting. Best results would be achieved by having a power supply as close to 4.35V as possible (no lower).
For those who don't believe it... Yes, this is a COMPLETE Li-Ion charger, all you need to do is add a 4.4V-6V DC supply and one resistor and one capacitor!
see: http://pdfserv.maxim-ic.com/arpdf/MAX1811.pdf
Thanks.
Old Feb 20, 2003, 10:25 AM
meteor is offline
meteor's Avatar
Ontario, Canada
Joined Nov 2002
Cheap, free and tiny...
Forgot to mention...
Maxim will send two free "development" samples out to -anyone-, and for anyone who's interested, they sell for about $1.50 ea.
Takao alluded to a small size, he wasn't kidding! See attached...
Old Feb 21, 2003, 07:42 PM
Tokyo, Japan
Joined Nov 2002
Re: Cheap, free and tiny...
Meteor,
Thanks for your assist.
here. compare to AA size battery.
Old Feb 22, 2003, 09:05 AM
Tokyo, Japan
Joined Nov 2002
PC has +5V power supply
Take a look the inside of your PC.
The power supply may have +5V to GND(Black) instead of wall wart.
Free: Automatic Li-ion Charger schematic glewis Batteries and Chargers 12 Mar 15, 2004 12:01 PM
Simple Li-poly charger? tabbytabb Batteries and Chargers 6 May 28, 2003 07:28 PM
High Capacity Li+ Battery Charger Schematic Takao Shimizu Batteries and Chargers 4 Nov 09, 2002 07:04 PM
