Old Jun 23, 2007, 09:30 AM
Mike cole
Mike cole
Guest
n/a Posts
Myford S7 Cross slide Help
While idly about with the cross slide handle I have withdraw the slide
too far and now it don't want to go back. Any ideals please.
Old Jun 23, 2007, 10:28 AM
Peter A Forbes
Peter A Forbes
Guest
n/a Posts
Re: Myford S7 Cross slide Help
>Mike
If you haven't dropped the adjusting gib strips out, just push it back gently
while turning the handle in the correct direction until the thread picks up
again.
Peter
Peter & Rita Forbes
Email: diesel@easynet.co.uk
Web: http://www.oldengine.org/members/diesel
Old Jun 24, 2007, 03:59 AM
ravensworth2674
ravensworth2674
Guest
n/a Posts
Mike,
Peter does provide a reason for the problem but not, I fear,
how to resolve future problems.
The Myford gibs were recommended to be secured by 'pinning through' by
the late GH Thomas when in his Model Engineers Workshop Manual, he
described the method and also how to make simple locks for the gibs on
the lathe and the vertical slide.
Old Jun 24, 2007, 04:59 AM
Mark Rand
Mark Rand
Guest
n/a Posts
On Sun, 24 Jun 2007 01:59:24 -0700, ravensworth2674
<norman@n-atkinson.wanadoo.co.uk> wrote:
>Mike,
The OP was talking about a Super 7, the cross slide Gibs on the S7 are bolted
to the cross slide and don't fall out.
Mark Rand
RTFM
Old Jun 24, 2007, 05:17 AM
ravensworth2674
ravensworth2674
Guest
n/a Posts
Mark,
True but they waggle on the S7 enough to annoy!
I pinned mine- and fitted pressure locks onto the saddles of both the
ML7 and the S7 as well as the top slides to both.
GHT and I share a particular brand of pedantry.
And Myford bloody gibs- said he in rant mood! There are better fitting
gibs.
There should be only a gnat's cock clearance in the gibs for
starters.Mumble mumble. Rant quieter now!
Norm
Old Jun 24, 2007, 04:49 PM
Charles Lamont
Charles Lamont
Guest
n/a Posts
>>Mike
>again.
If he has one of those new-fangled jobs with a power cross-feed isn't it
a bit more complicated? I don't know 'cos mine ain't.
Charles Lamont
Old Jun 24, 2007, 06:20 PM
William J Lamond
William J Lamond
Guest
n/a Posts
The message <Xn8EuFElbufGFwbM@gateho.gotadsl.co.uk>
from Charles Lamont <charles@gateho.gotadsl.co.uk> contains these words:
> >>Mike
> >back gently
> >again.
> Charles Lamont
It works OK on mine which has power cross-feed. If I remember correctly,
you may have to remove the top slide, to gain access, so that you can
fiddle with the gear wheel to get the key to engage.
Bill Lamond
Old Jun 24, 2007, 06:30 PM
David Littlewood
David Littlewood
Guest
n/a Posts
In article <Xn8EuFElbufGFwbM@gateho.gotadsl.co.uk>, Charles Lamont
<charles@gateho.gotadsl.co.uk> writes
>>>Mike
>>again.
>it a bit more complicated? I don't know 'cos mine ain't.
ISTR that GHT in the Workshop Manual described the procedure for
re-fitting the cross slide of a Super 7 with PXF. If you have such a
model, and have not got the book, ask and I will look it up for you.
(Better still, buy the book!)
David
David Littlewood
Old Jun 27, 2007, 05:53 AM
Mike cole
Mike cole
Guest
n/a Posts
O Hi Guys
As i have the power cross slide it was a bit more than just pusting
it back. There is a keyway in a gear which
must line up so the slide had to come off to remove the gear.
All back togerter now
Mike Cole
> >>again.
> David
> David Littlewood
