Australia, SA, Evanston Park
Joined Mar 2010
The specs on the G46 read like this lol 4s 14x7 and 5s 12x8.
It's like scirocco said, the lower the volts the more amps you pull, the higher the volts the lower the amps, volts x amps = watts, a motor can only make so many watts before it starts to get damaged, so if you know the watts then if you know one other value you can work out the last one. |
Joined Mar 2010
I could not use my Emeter on his set up because he is using different connectors, mine is a G46 and labeled as 670kv, some motors have a 10% variation on kv in the specs. |
Australia, NSW, Braidwood
Joined Nov 2008
Sorry guys a couple of more questions if I may.
Aeromaniac Talked of a 12 x 8 x 3. What does the 3 signify. When I visited the LHS today I was told I have to use, for example, a 12 x 8"E "prop. This being a prop specifically for electric. No one has mentioned them in this thread. The "E" prop specifically says not to use on nitro. The props without the "E" do not say do not use with electric. Do I have to use an "E" prop? |
the 3 represents 3 blades. Generally used where you just like 3 bladers, or diameter is a limit and you want a bit more blade area to absorb some more power - do a comparison in ecalc to see the difference. btw, which LHS from Braidwood? |
Joined Nov 2008
Monaro Models in Fyshwick, who I see were visited by a ram raider. Nice guys there and always very helpful. As I am on the learning curve I like to double check. I also deal with Jan and Paul at Nitrodude but they are a bit far away. Paul has been very helpful as well.
Thanks for the other info. |
Joined Nov 2008
I am longing to get my Boomerang into the air but I have been beset with problems. I tried to set up the C of G to suit some batteries I already have however the position of the batteries to give me the right C of G were over the top of the servos and that will not work. All of my existing batteries are high mAh to suit power hungry helicopters. I ordered a lighter 4S and 5S from HK to test for C of G and flying. I also moved the motor back from 50mm from the firewall to 30mm from the firewall. The C of G using the HK batteries was perfect with the batteries where the fuel tank would go. I set about charging the 4S and the positive wire came away from the battery. Another HK failure!! It could not be repaired as it was the aluminium tab which came off. Soldering aluminium is not something I would trust. It is a waste of time making a warrenty claim. Firstly it will cost me about $25 in postage costs and about 4 weeks for HK to do anything. The battery is only worth about $22 so I ordered another one.
What is worse however, a friends dog put its paws through one wing and try as I can I cannot get Monokote to stick to the existing covering, even with sanding it and a primer applied first. This is my first attempt at using anyform of iron on film. Someone has told me that the Boomerang covering is such that if I am to use Monokote I will have to strip the whole wing and start again. Has anyone any experience on repairing Boomerang covering? |
United States, NY, Cortland
Joined Sep 2010
With the right kit and some care you can solder to the AL tabs without too much trouble.
I have a couple of ARFs, the covering isn't monocote or anything compatible on either, you can packing-tape on a patch of monocote or something else, or just tape over the hole. |
Joined Sep 2010
A square of anything and packing tape will, seriously, fix that right up. Or just packing tape.
If you wanted to be 'thorough' you could go from the left, go over the 1st bay and then pull the tape down and attach it to the balsa piece, then cover the next bay the same way, last bay just go over the top. heck, then mask it and spray paint it white... |
| Thread Tools | |
| Ripmax .40 trainer | hubevolution | Sport Planes | 8 | May 28, 2003 08:59 AM |
| Electrify AirCore 40 Trainer? | babblefish | Sport Planes | 5 | Feb 10, 2003 10:05 AM |
| For Sales: .40 Trainer (New) Engine and Radio installed!!!! | Captain Carlton | Aircraft - Fuel - Airplanes (FS/W) | 0 | Aug 06, 2002 10:57 PM |
| .40 Trainer + Engine for sale / Trade | Danythemany | Aircraft - Fuel - Airplanes (FS/W) | 0 | Jun 24, 2002 05:25 PM |
| .40 Trainer Recommendation Question | Ghostbear | Fuel Plane Talk | 4 | Jun 12, 2002 07:03 PM |
