Old Nov 11, 2012, 04:50 PM
Banjofrog is offline
Find More Posts by Banjofrog
Geez That's A Big Fly
Banjofrog's Avatar
Australia, WA, Parkerville
Joined Sep 2011
Originally Posted by Watdazit View Post
Good question. Yes I have had a problem and broken one prop with a heavy landing. I have not changed the wheels although I have thought about changing the front one only. However at this stage I have left the rear wheels spread a little (from my heavy landings,) which has the effect of lifting the nose. I also put a lot of effort into making perfect landings!
An alternative is to go to a 300mm 3 blade prop. I have looked at posts on sizing these and need to get my grey brain around the maths to work out an equivalent size.
I have used 12x6x3 and 12x8x3 MAS props and both worked well, my maiden was with the 12x6x3 and 12-14min flight times on a 3300mah, currently I am using a 12x10x2 apc electric, imho you will get prop strike with anything bigger.
Shaun.
Banjofrog is offline Find More Posts by Banjofrog
Old Nov 11, 2012, 09:21 PM
scirocco is online now
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
viagra day
Thanks, it was good enough to do my Bronze wings yesterday. My instructor had me do a 2 loops at the end, (celebration??) and the Boomer handled it well. I have done loops, flips and rolls with 800mm wing span HK crash dummy planes so I can do them but doing it with a balsa/ply 1500 ":real" plane was a little bit nerve racking.
Are you going to the Viagra Glider day at Namadgi on Friday? I will be taking my Bixler and Radian Pro. I like gliding but am not very good at it.
Only heard about it at the club yesterday but it's real tempting to take the day off. Might bring an easy glider and a 2m floater
scirocco is online now Find More Posts by scirocco
Old Nov 12, 2012, 01:29 AM
wobblygts is offline
Find More Posts by wobblygts
Australia, VIC, Golden Square
Joined Jul 2009
Had a giggle at "Viagra" glider day.
wobblygts is offline Find More Posts by wobblygts
Old Nov 12, 2012, 03:27 AM
Watdazit is offline
Find More Posts by Watdazit
A geriatric flier
Watdazit's Avatar
Australia, NSW, Braidwood
Joined Nov 2008
It's all to do with keeping it up.......
Watdazit is offline Find More Posts by Watdazit
Old Nov 13, 2012, 12:22 AM
peterreebok is offline
Find More Posts by peterreebok
Australia, VIC, Ferntree Gully
Joined Nov 2010
tried the 13 x 8 prop today. full tilt was 52a and 770 watts.
have bought a tacho, so when that arrives I will document the rpm, draw, watts according to the wattmeter, then maybe some real math can be done.
peterreebok is offline Find More Posts by peterreebok
Old Nov 13, 2012, 12:35 AM
aeromaniac is offline
Find More Posts by aeromaniac
Glow 😡 no no no
Australia, SA, Evanston Park
Joined Mar 2010
Watts sound ok lol
aeromaniac is offline Find More Posts by aeromaniac
Old Nov 14, 2012, 04:48 PM
Glow 😡 no no no
Joined Mar 2010
Just tried the G46 on my emeter with a tgs 12x8 2bl, was surprised with the data, fresh rhino 3700mah 25c 4s battery, wot 15.28v, 54.7a, 837w, 9060rpm.
Old Nov 14, 2012, 06:44 PM
scirocco's Avatar
Joined Feb 2001
That current and power seems way way higher than it should be, especially for the rpm, which is not that high. Beiung higher than peter saw for a 13x8 is definitely odd. I'd have expected under 40A, even the peak value hot off charge.
I wonder whether the TGS props just eat a lot of amps? I also wonder whether the Kv on your motor is higher than spec.
Old Nov 14, 2012, 11:45 PM
Glow 😡 no no no
Joined Mar 2010
Not sure mate but the performance is certainly there to back up the amps, doing a low and slow, push wot and pull vertical until she gets kinda small. I know the auw for the plane is around 2.4kg. So I have no idea why my specs are higher?.
I am as surprised as you with the performance, way more than I expected from a 12x8.
Old Nov 15, 2012, 12:14 AM
scirocco's Avatar
Joined Feb 2001
Well if it's not cooking anything all I can say is bonus
I kinda like the gentle slow pass and pull vertical thing in a trainer too - makes the average glow Boomerang or Swift look a bit anaemic, except they do get better duration
Old Nov 15, 2012, 03:36 AM
Glow 😡 no no no
Joined Mar 2010
Well I wack 5000mah behind that motor duration should be ok.
Old Feb 19, 2013, 03:24 AM
Watdazit is offline
A geriatric flier
Watdazit's Avatar
Joined Nov 2008
After a lot of messing around I have eventually settled on a electric system for my Boomerang.
Motor is an Eflite Power 46
Batteries 4S at present I am using Zippy Compacts 25/35C 4000 mAh
Prop is an APC 13 x 8 E
On the watt meter it is returning 38 amps and 571 watts.
I am flying 7 mins at present and showing 45% to 50% left in the battery.
I am a novice so I am not pushing it but as I get more confident undoubtably my flying time will stay the same but I will be using more mAh.
The motor is working way under its potential of 800watts. The closest I have got to using this power is with a 5S setup and 13 x 6.5 prop or a 12 x 8 prop. The flying times were greatly reduced so that's why I decided to go 4S.
I still have not got a handle on all this motor vs prop vs battery thing but I'm flying comfortably at present and have a system I think can grow with me.
After suffering a few prop strikes I decided to change to 4500 5S 25C Zippy Compacts and 12 x 6 APC E prop. Sounds better and goes OK. It will pull vertical at the end of the runway and roll a couple of times. Starts to run out of puff after about 8 secs going vertical but I am happy. After all it is only a trainer.
Old Feb 19, 2013, 06:37 AM
AscotRC is offline
Find More Posts by AscotRC
Dave
Australia, QLD, Brisbane
Joined Apr 2012
I've bought the boomerang II with electric conversion and the choice between tail dragger and trike. Bought the g46 plush 70a and 4000 4s lipo. No room to start building so gathering dust in the box for bit longer...
AscotRC is offline Find More Posts by AscotRC
Old Apr 05, 2013, 09:15 PM
Joined Nov 2010
Maidened my boomer today.
G46 670 kv running 12 x 8 prop.
Able to pull verticals with three quarter throttle.
3 clicks of trim needed only, 12 minutes of flight on a 4500 4s battery with 40% remaining.
Tracks straight and true, not a single issue, very happy with conversion.
very quiet, sort of like a stealth trainer remarked one observer.
Old Apr 08, 2013, 10:35 PM
AscotRC is offline
Dave
Joined Apr 2012
How does it handle wind ?
Ripmax .40 trainer hubevolution Sport Planes 8 May 28, 2003 08:59 AM
Electrify AirCore 40 Trainer? babblefish Sport Planes 5 Feb 10, 2003 10:05 AM
For Sales: .40 Trainer (New) Engine and Radio installed!!!! Captain Carlton Aircraft - Fuel - Airplanes (FS/W) 0 Aug 06, 2002 10:57 PM
.40 Trainer + Engine for sale / Trade Danythemany Aircraft - Fuel - Airplanes (FS/W) 0 Jun 24, 2002 05:25 PM
.40 Trainer Recommendation Question Ghostbear Fuel Plane Talk 4 Jun 12, 2002 07:03 PM
